This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jan 28, 2013, 08:28 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Originally Posted by goldsworthy View Post
I am starting to build my Freewing SU35 its a expensive plane for sure!. The Guardian will be installed in this plane for my piece of mind. I hope my 8 channel reciever will be enough to use both the Gaurdian and all the stuff on the 35.
You should be able to do it Gold but you will probably have to lose some of the functions, i.e. "y" the yaw (rudder tv) to the rudder channel. That would free up a channel. If you want to hook both the 2d/off/3d and be able to change gain from the radio you will need two empty channels on your receiver. Again this is doable but you will probably have to y one of the other tv axis to it's corresponding channel. What you lose when you y them in is the ability to turn that tv function off.
DamonH is offline Find More Posts by DamonH
Old Jan 28, 2013, 08:40 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
I do not want the TV to be used at all anyway!. I wish there were a way just to disable the TV compleatly!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 28, 2013, 08:54 AM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
I believe that will free up three channels then. There is a way you can disable it completely. You just have to set the tv nozzles to their neutral positions and lock them in place by screws or whatever means you want to use. The key is to ensure you have them set to neutral and it is probably best to fix them with something that can be removed in the future if you decide to use them or you need to adjust them for some reason.
Old Jan 28, 2013, 09:03 AM
Joined Mar 2012
I wish there were a way just to shut the TV down without having to jam something into them. I wish this jet never had TV in it. I only wanted this to fly in a circle nice and under control. I have no interest in all the 3D stuff. But you would think there would be a way to just turn the TV off without all that other stuff having to be done to the jet.
Old Jan 28, 2013, 09:48 AM
CurrentDude is offline
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
Can any one tell or give me a solution to my question below :
Question : Does Guardian needs a three position switch in the transmitter?
I'm sure this question has been asked before but I can't see it.
In my transmitter (futaba ff7), I need almost all the stitches as I use mixing and landing gears.
I am really not prepared to buy a 12g futaba or any other transmitter. It takes too long for me to programme and getting used to a new tx.
Any help wud be much appreciated.
Cheers
CurrentDude is offline Find More Posts by CurrentDude
Old Jan 28, 2013, 09:51 AM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Its not as hard as it sounds to disable the tv. There is marks on the tv units that you can use to line them up to the neutral position. All you really have to do is disconnect/remove the control linkages from the tv servos to the tv units. Once that is done its just a matter of fixing the tv nozzles to neutral. I would think the easiest way would be with small screws. Plus this gives you the ability to remove them and make adjustments if necessary.
Old Jan 28, 2013, 11:15 AM
choochoo22 is offline
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
Originally Posted by JayY View Post
RX aileron output to Guardian aileron input, Guardian aileron output to Radian rudder servo. It works as expected, during my testing at home, rolling the Radian left causes the Guardian to compensate with right rudder and vice-versa. I will let you know how it works for real when I perform the flight tests this week.
I've used it on a rudder only plane, it works as you would expect.
choochoo22 is offline Find More Posts by choochoo22
Old Jan 28, 2013, 11:52 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Answered across various posts:
*If you do not need to adjust the mode or gain while flying, no.
*If you have 2 position switches available, some posts talk about how to switch between 2D and 3D or turn the gyros on (some gain) and off (0 gain) while flying.
*If you need to make adjustments on the ground, some posts mention temporarily using a channel to program the Guardian (or use the micro-USB port with a PC). Or another way is to use a servo tester (my post #2984).
flying-llama is offline Find More Posts by flying-llama
Old Jan 28, 2013, 12:38 PM
Joined Jun 2011
Thanx Flying llama for your quick reply. I'll look at your post
Cheers
Old Jan 29, 2013, 08:15 AM
gatorb8 is offline
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
The more I experiment with the Guardian, the more I love it!
Remote Tx control of 2D/off/3D and gain is a must have for me!
gatorb8 is offline Find More Posts by gatorb8
Old Jan 29, 2013, 08:27 AM
JayY is offline
Find More Posts by JayY
Foam Temple Pilot
JayY's Avatar
United States, NC, Raleigh
Joined Sep 2012
Deleted
JayY is offline Find More Posts by JayY
Old Jan 29, 2013, 02:06 PM
Joined Jun 2011
Cudn't wait any longer so ordered mine today ;~). Hopefully it will be with me in a day or two.
Another silly question - will it work with rudder ele model?
My sacrificial lamb is going to be a pz Super Cub. I cud knock up an aileron model, if needed.
Seeing Beaver report here convinced me "I want it NOW" so I can use it in my Beaver too.
Thanx guys for help so far and wait to see your reply.
Cheers
Old Jan 29, 2013, 02:17 PM
Joined Jun 2011
Sorry posted twice.... my high speedo fingers
Old Jan 29, 2013, 02:33 PM
TheBum is offline
Find More Posts by TheBum
TheBum's Avatar
McKinney, TX
Joined May 2007
Cheers
The aileron connection into the Guardian is required. However, JayY mentioned a few posts above that he connected his receiver's aileron channel to the Guardian aileron input and then connected the aileron output to the rudder servo. I don't see why you couldn't instead connect the rudder channel into the aileron input if you're more comfortable using rudder stick movements.
TheBum is offline Find More Posts by TheBum
Old Jan 29, 2013, 02:47 PM
Joined Jun 2011
Thanx a bunch "TheBum" :~ /
I read the post just this mo.
Cheers
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
