United States, CA, Ridgecrest
Joined Dec 2011
Flaperons
I've searched this thread but I'm still confused about the Guardian and flaperons (two separate servos driving left and right ailerons). I'm building a plane now and considering using full span flaperons but I'd also like to control it with the Guardian. Is that possible or not, i.e. in addition to rudder and elevator will it drive two aileron servos without a Y-cable?
Sandy Springs, GA
Joined Jul 2008
One question. I currently use a gyro on a number of tail tragers for take off. I use heading hold mode during the takeoff switching the gryo off as soon as the plane leaves the ground. During the takeoff run the tail rises due to speed, I feed in up elevator when the plane reaches takeoff speed. Will 3D mode hold the tail on the ground causing a premature takeoff? Will I have to force the tail up during the run? 2D mode will not help since I assume it just rights the plane. Turning the Guardian off will cause me to loose the benifts of the gyro control on takeoff. Again the question: what is the effect of taking off a tail drager in 3D mode?
Bruce |
Durango Colorado
Joined Sep 2001
I want one of these for my FPV Sky Surfer. |
Latest blog entry: FPV mQX
Katy, TX
Joined Dec 2009
No i was talking about the slider on the side of the radio, to cycle thru Off/2D/3D. I use the flight mode 3 way switch for various throws, ie N = Hight rates for launch and landing, FM1 = Low rates for normal flying around, FM2 = Ulra low rates for High speed passes FCA |
With DX7 with Flaperons enabled you can not use the Flap /3Pos. Sw. for the Guarduian thus why I changed to a Y -cable for thre duel Ails. I have requested another Wing mix. in the Guardian and that is what Bill mentoined in his post above. Charles |
landeck
In 3D mode the Guardian only holds last position of the aircraft when (if)sticks are centered.You have comple control or you can let Guardian maintain heading and keeping wings level. It will hold the takeoff heading (rudder) if there is a cross wind or motor torgue, the Elev. will be completely under your control . Guardian will also control Ails. to keep aircraft level. I have performed many take offs and landing in 3D mode and the Guardian make it easier but does not interfer in any way. Snip from an earlier post of mine. Quote:
Charles |
Trying to get the most programing wise is going to be interesting for many of us. I spent many hours trying different mixes on the DX7 and decided that it was just impossible to have Transmitter System Flaperons for duel Ali. servos and anything but 2D and 3D for the Guardian on the Gear switch.
When I put a Guardian in one of my larger planes most likely I will use one of my Ace MicroPro 8000 Transmitters that way I will not be so limited.These Radios are 20 plus years old and still more advanced in most ways than the latest and greatest ones. Charles |
After flying this a handfull of more times it just keeps amazing me I can hover,KE, w/o help but its nice to be able to cut it off to see how much it can help you out.
It remembers last thing you was doing in 3d mode. I played with this other day I put plane in hover. then lowered the throttle to where it could not hold a hover it fly mostly straght as it could while wanting to go back to a hover as soon as i gave half or more throttle it poped right back into a hover. amazing. |
Guardian 2D/3D basic programing.
Let me try and explain setting in simple terms.
Guardian goes between receiver and control surface servos. Spektrum DX7 with 6Channel receiver ( as many have this one). Rec. Thro. connects to ESC Rec. Alie. to G. 2D/3D Alie. (this is a 3 lead standard servo lead and supplies power) Rec. Rudder to G. 2D/3D Rudder Rec. Gear can be used . to select 2 of the 3 flight modes. Rec. Aux.1 can be used as second Aile. output but requires System Flaperons to be enabled which caputers the Flap Mix. 3 pos. Sw., G 2D/3D has two special inputs which connect to receiver channels. 1 is the 2D -Off - 3D Mode selection. -100% (1.1m) =2D 0% (1.5 ms) = Off + 100% (1.9ms) = 3D Note: + / - are dependent on servo direction settings. Initial Guardian set up for straight level flight (mode 2) requires toggling Transmitter output from one extreme to the other. Reseting Trims memory requires toggling also. Second special input remote is over all gain. 2D mode active Master gain (Transmitter slider,knob etc.) -100% Off -100% to 0% Medium stabilization. -0% to + 100% Maximun stabilization. Note: If external overall gain is not used the default is 40%. Also A default of 2D or 3D can be set so selection by Transmitter is not required. Above is accurate to the best of my somewhat limited knowledge / experience. OT Anyone else noticed that since Silverexpress 's aphots are unavailable their computer is acting flakey,screen flashing? Update OK now they are back for me also and things seem normal.Thur . 11:56 AM Charles |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
