This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jan 22, 2013, 01:43 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
Originally Posted by John.T View Post
The simple explanation is that the Master Gain channel is a multiplier on the gains set in the potentiometers for each axis. When it is set to servo deflection = -100%, then that turns stabilization OFF. When you set it to +100%, then stabilization will be set to HIGH, assuming that your potentiometer gains are set to non-zeroed values. When the Master Gain channel is left disconnected, it defaults to just under what you'd get when the dial is set to 0% servo deflection (1.5ms).
I've talked with Billpa about creating a community editable document / manual for the Guardian that would compile all of the things that have been arrived at in this thread. Does anybody have any thoughts here? Many of these questions have been touched upon a long while ago, but it's easy for conclusions and advice to be lost in the discussion. A Google Doc or wiki would be an obvious idea. We want to have something that can be contributed to openly but that would be robust against vandalism. Of course, we continue to update our official manual with errors as they are reported but I'm always amazed by what the community is capable of coming up with.
Seems part of the confusion stems from using the term "multiplier". Appears it is being assumed "multiplied" always means "more" as in "multiplied" by a number >1. Multiplied is technically correct but would seem to maybe not be the best choice of wording?
Mater Gain allows you increase or decrease overall gain.
Pot settings allow you to increase or decrease gain for individual axis.
Pot settings and Master Gain work in series.
About right?
"A Google Doc or wiki would be an obvious idea" and a good idea. Would need some kind of "revision subject to approval".
t.edwards is offline Find More Posts by t.edwards
Old Jan 22, 2013, 02:19 PM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
After the first couple of sentences I thought that I had understood it.
Then BAM!!! "When the Master Gain channel is left disconnected, it defaults to just under what you'd get when the dial is set to 0% servo deflection (1.5ms)." Now I am lost again.
How do you get less than 0%?
Galand is offline Find More Posts by Galand
Old Jan 22, 2013, 02:22 PM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
0% means "Neutral"
I think that, by "0%" is meant the equivalent of a "neutral" servo position; i.e., the mid-point between -100 and +100, or msec range, or degrees of rotation.
Michael
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Jan 22, 2013, 02:33 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Hi All, sorry for the long silence!
To all discussing the meanings of the Master Gain vs the individual axis gains: Sorry for the confusion here and thanks for the repeated iteration on the best explanation. This can either be a confusing or a very simple topic, depending on how you approach it. The simple explanation is that the Master Gain channel is a multiplier on the gains set in the potentiometers for each axis. When it is set to servo deflection = -100%, then that turns stabilization OFF. When you set it to +100%, then stabilization will be set to HIGH, assuming that your potentiometer gains are set to non-zeroed values. When the Master Gain channel is left disconnected, it defaults to just under what you'd get when the dial is set to 0% servo deflection (1.5ms).
For those that are looking for a "calibrated" answer, I'm afraid that this is where it is honestly a little arbitrary and likely the source of the confusion. Originally, we specified that "centered" would correspond to 50% Master Gain while full deflection would yield 100% Master Gain. The channel being disconnected would equate to about 40% Master Gain, leaving stabilization on, but less likely to cause strong oscillations in the case of an accidental channel disconnect.
Upon seeing people trying to grok this nomenclature, we decided to change the language in the manual to instead make the Master Gain 100% when the slider or knob was centered, with a maximum possible Master Gain of 200%. The intention here was to help clarify that leaving this channel disconnected (giving about 80% Master Gain) would still allow for normal operation. Again, this is an arbitrary scale. I'll be the first to admit that I'm not a fan of the current nomenclature. I'm happy to help with any further questions on this and hopefully we as a group can come up with some concise language that clarifies this.
Finally, some answers from a Guardian representative.
Second, your design team has created an engineering marvel.
Third, you design team is clueless about creating user friendly documentation.
Why in the world would disconnecting the MASTER GAIN provide 20% less gain? And, of course, the inverse is true. What is the rationale of doing so? The progression of setting up a Guardian most likely has a user or customer first setup the Guardian with three channels and the mode switch. Later, when a radio with a slider or proportional knob is available and enough channels are available on a receiver the MASTER GAIN would be connected. This progression takes a working setup and can quickly be a problem because invidual gains increase when Master Gain is connected. This could drive the plane into oscillation when the MASTER GAIN IS CONNECTED with the MASTER GAIN AT FULL. Your logic escapes me.
Prof100 is offline Find More Posts by Prof100
Old Jan 22, 2013, 02:36 PM
stegl is offline
Find More Posts by stegl
stegl
Kelowna , BC
Joined Nov 2008
manual
A manual change would be the best for me, also. I was a little fustrated when I found out I had to use a matchbox to use a 2 servo split elevator setup when they show an auxilliary input and output which, the way I saw it, could be used as either an extra aileron servo or an extra elevator servo when in fact it looks like it is only for ailerons and should have been stated so rather than an aux in/out . The extra touch is gonna be another 65 plus bucks to make it work.
stegl is offline Find More Posts by stegl
Old Jan 22, 2013, 02:47 PM
Joined Aug 2005
Negative numbers, like -100%.
What your tx is sending to Gauardian to control master gain runs from ~1.1ms, -100% (gain off) to ~1.9ms, +100% (max gain). You tx ouputs to Guardian just like it's running a servo.
If you don't have a master gain hooked up just adjust Guardians' pots.
Old Jan 22, 2013, 02:55 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
I agree. Great product, 'A' for effort on the documentation (I didn't have to download it, and it's more than half a page), but 'C' for achievement (just look at this thread for proof!).
But what will make it better is feedback
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Jan 22, 2013, 03:04 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
So the Gaurdian is working again? We now have factory support?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 22, 2013, 04:10 PM
OldeMan is offline
Find More Posts by OldeMan
Faster is Better
OldeMan's Avatar
United States, AZ, Gilbert
Joined Jul 2012
The dark clouds are dissipating, the sun is peeping through, and birds are chirping happily in gently swaying trees. Clarity has been achieved... and the world spins upon its axis, oblivious, sublime.
OldeMan is offline Find More Posts by OldeMan
Old Jan 22, 2013, 04:17 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
I have three. I fly the thing all the time, set-up, pots gains, master gain etc...
Works great, I just hate poorly written documentation!
Old Jan 22, 2013, 04:33 PM
Deerslayer is offline
Find More Posts by Deerslayer
Kingston Ontario Canada
Joined May 2006
An experience report
I am very impressed with my Guardian, and my second unit just arrived. Buckets of fun to come!
I wrote up a report on my experiences to date and posted it in my Club's forum.
In case anyone here is interested:
http://krcm.mywebnow.org/index.php?t...sg1705#msg1705
Deerslayer is offline Find More Posts by Deerslayer
Old Jan 22, 2013, 04:59 PM
Joined Aug 2005
I agree. I think the (confusing) 0-200% description of Master Gain will haunt ET quite a while.
Master Gain is like a volume control, with off, max, and everything in between. The only value asigning numbers has is to make it easier to repeat a setting.
Old Jan 22, 2013, 05:54 PM
John.T is offline
Find More Posts by John.T
Guardian Stabilizer
Joined Feb 2012
Thanks for the feedback, All.
I'm going to try again on the Master Gain stuff, if you'll bear with me. I want to try and get this as clear as possible for inclusion in the manual.
The Master Gain can be treated like a master volume slider on an audio mixer board. In this example, you have three channels, one for each axis on the Guardian. Each has its own "volume" slider. Then, the Master Gain slider controls the final output volume on the entire mixer.
I can see how "multiplying" could be seen as confusing word in this context. Does "scaling" seem more intuitive?
Regarding the use of percentages, let's try different units: On a standard servo, the PWM pulse width of the signal is roughly 1.1ms for -100% deflection, 1.5ms for centered and 1.9ms for +100% deflection.
So, here is a set of ranges:
  • 1.1ms: Master Gain = 0%; Stabilization disabled
  • 1.5ms: Master Gain = 100%; recommended starting point for tuning
  • 1.9ms: Master Gain = 200%; useful for 3D maneuvers where high stabilization is needed. Strong oscillations usually happen here unless you have your individual axis gain pots turned down, are flying very slowly, have very limited control surface ranges or have a very inertial airframe.
  • Disconnected: Master Gain = 80%; Failsafe / Default; This (reduced) value was chosen to help mitigate possible spontaneous oscillations in the case of a disconnected Gain wire.
Prof100: Thanks for your feedback on the Master Gain's disconnected behavior. The intention here was to allow the Guardian to operate in as many applications as possible. Having a default Master Gain value of 80% allows for a beginning user to push their starting gains without the possibility of going wildly out of range and introducing oscillations. The expectation is that most people will fly with a Master Gain of around 100% (1.5ms), but will be able to push their performance if they want some slow speed maneuvering or similar. Getting that wire yanked at high speed and having the Guardian default to full 200% Master Gain could trigger a spontaneous and violent oscillation depending on many factors. While the Guardian detects and dampens out these oscillations, this takes a few seconds and it is still not fun to fly through that.
goldsworthy: The Guardian 2D/3D Stabilizer has always been supported by its manufacturer, Eagle Tree Systems, and even in context to this conversation about the Master Gain, it has always been "working" for its users. From what I understand, any frustration is from our documentation which I hope to remedy.
stegl: Sorry about the confusion here. This is a feature that we would love to add in future revisions of the Guardian. Stay tuned!
John.T is offline Find More Posts by John.T
Old Jan 22, 2013, 06:27 PM
TheBum is offline
Find More Posts by TheBum
TheBum's Avatar
McKinney, TX
Joined May 2007
These two are telling me that, if I have the gain input permanently disconnected, I should just crank the pots all the way up from the get-go. If that's really the case, it would be nice to say something to that effect in the manual.
Oh, and "scaling" would be a good term for what Master Gain does.
TheBum is offline Find More Posts by TheBum
Old Jan 22, 2013, 06:33 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Bold and blue needs to me inserted in v 1.8 of your manual as well as the logic behind it (your response to me). It would permit users to take the right steps as they progress from no Master Gain to using Master Gain (channel and radio permitting). Assuming 50% on Master Gain (mid point) needs to be clearly stated in your manual. I would start with full open if I consider it as a master "volume control" that only atttenuates and does not multiply or amplify the pot settings. BE CLEAR please.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
