France, IdF, Paris
Joined Nov 2008
Between my tx and crashed aircraft
Joined Mar 2006
I think this figure came from this page:
http://item.taobao.com/item.htm?spm=...id=16029430702 The price numbers have a ¥ in front of them, so it is not US$. It seems to be Chinese Yuan . |
United States, CA, Santa Clara
Joined Mar 2011
Based on nothing but casual observation and assumptions, in other words not worth much; For casual sport flyers the Guardian is probably the better choice, it's cheaper, better supported, field proven, lighter, smaller, does all the sport flier needs and does it well. If I were shopping for a device for an FPV or camera plane, however, I would give the Dos a closer look. The altitude hold and return home features are very appealing. I believe the circling and return home features only work with the gps module but altitude hold is standard. It would be interesting to see some comparative tests. |
Joined Mar 2006
What you are looking for is interesting, but there does not seem to be a "home" for discussing gyro systems for airplanes in the current RCG forum set-up (unlike gyro systems for multi-rotor heli's, for example). There is some discussion in the FPV and aerial photography forums, Guardian is discussed here in a vendor forum, AS3X (limited as it is) is discussed in micro-RTFs, and I have seen versions of KK for airplanes (as opposed for multi-rotors) discussed somewhere. The closest that I have seen to such a "home" is a thread on using gyros in airplanes in general: http://www.rcgroups.com/forums/showthread.php?t=1035605 From what I have seen so far, one feature this particular Guardian device has that other stabilizing systems that I have read about do not seem to mention is detecting oscillations from too high a gyro gain and automatically turning down the gyro gain to stop those oscillations. |
Joined Apr 2012
Ipoh, Perak Malaysia
Joined Jul 2006
I think the confusion with the 200% multiplier comes from ricolanso (I think?) setting up his ET with the master gain set in the middle. When he dials the plane in using the pots for this middle setting, he refers to this as his base reference. So, when he turns the master gain towards 1.1ms, he is reducing the gain. However, when he turns the master gain towards 1.9ms, then he is multiplying the gain.
In actual fact, he had his master gain set such that the ET firmware is only taking 50% of the total gain allowed as set by the pots when his master gain knob is at 1.5ms. When his master gain is at 1.9ms, then it would appear to him that his gain is multiplied by 2, when in actual fact the firmware is only taking 100% of the gain as set by the pots. I hope I am making sense...? regards, chewy |
Kelowna , BC
Joined Nov 2008
Not always. Dual/split aileron servos work but dual/split elevators do not, according to ET. Not sure why the Aux could not be used for either.
According to them; the only way is a Y connector with servo reverse on one side or a $65 JR servo match box. Sooo simple but yet so complicated. |
No Chewy go back to the original post when the question was initially raised. I was simply repeating what the Manual Ver 1.7 is saying. Anyway, this subject has been beaten enough, even from the middle of last year. I think everyone already has understood the basic concept I think...Cheers. |
Joined Feb 2012
Hi All, sorry for the long silence!
To all discussing the meanings of the Master Gain vs the individual axis gains: Sorry for the confusion here and thanks for the repeated iteration on the best explanation. This can either be a confusing or a very simple topic, depending on how you approach it. The simple explanation is that the Master Gain channel is a multiplier on the gains set in the potentiometers for each axis. When it is set to servo deflection = -100%, then that turns stabilization OFF. When you set it to +100%, then stabilization will be set to HIGH, assuming that your potentiometer gains are set to non-zeroed values. When the Master Gain channel is left disconnected, it defaults to just under what you'd get when the dial is set to 0% servo deflection (1.5ms). For those that are looking for a "calibrated" answer, I'm afraid that this is where it is honestly a little arbitrary and likely the source of the confusion. Originally, we specified that "centered" would correspond to 50% Master Gain while full deflection would yield 100% Master Gain. The channel being disconnected would equate to about 40% Master Gain, leaving stabilization on, but less likely to cause strong oscillations in the case of an accidental channel disconnect. Upon seeing people trying to grok this nomenclature, we decided to change the language in the manual to instead make the Master Gain 100% when the slider or knob was centered, with a maximum possible Master Gain of 200%. The intention here was to help clarify that leaving this channel disconnected (giving about 80% Master Gain) would still allow for normal operation. Again, this is an arbitrary scale. I'll be the first to admit that I'm not a fan of the current nomenclature. I'm happy to help with any further questions on this and hopefully we as a group can come up with some concise language that clarifies this. lud: I'm sorry for your confusion and thanks for the feedback. There are many ways to set 2D or 3D Mode as the default modes. Our PC app is very powerful and easy to use. This option is available in the main screen of the Guardian's config page. If you can't use the PC software, you can also set the default flight mode by following the instructions in the manual to enter and use the Stick Menu. Using the Stick Menu requires either a 5-channel Tx/Rx combo or re-routing either the Throttle or Rudder signals to the Mode channel to simulate the Mode switch. Once the unit is configured, the default will be chosen whenever the Mode channel is disconnected. If either of these methods aren't working for you, then our Tech Support guys can be contacted here. Andre Germain: That is very strange. It sounds like you may be seeing an extremely rare bug that. The behavior should go away after a reboot. If it doesn't, could you please open a ticket with our support team? I've talked with Billpa about creating a community editable document / manual for the Guardian that would compile all of the things that have been arrived at in this thread. Does anybody have any thoughts here? Many of these questions have been touched upon a long while ago, but it's easy for conclusions and advice to be lost in the discussion. A Google Doc or wiki would be an obvious idea. We want to have something that can be contributed to openly but that would be robust against vandalism. Of course, we continue to update our official manual with errors as they are reported but I'm always amazed by what the community is capable of coming up with. |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
