This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jan 19, 2013, 05:56 PM
TheBum is offline
Find More Posts by TheBum
TheBum's Avatar
McKinney, TX
Joined May 2007
I flew my first Guardian in my PZ P-51D BL today in a bit of wind (10 mph or so). So far, I'm very happy with it. I first thought that I didn't see any difference...until I was halfway through the first flight and realized that I hadn't done any trimming. I had reset all my trims and transitioned from one aileron channel to two at the time I installed the Guardian, so my odds of getting perfect trim were slim.
I still have to tweak the gains. I don't have a free channel for a master gain control yet, so I'm having to figure out the optimum gains the hard way. That's a task for a calmer day.
TheBum is offline Find More Posts by TheBum
Old Jan 20, 2013, 06:16 AM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Originally Posted by Deerslayer View Post
Once again, I ask:
What is the range of Master Gain?
Details:
We understand that at Servo travel = -100%, the Master Gain is 0, effectively being an OFF setting.
I take it from the Guardian manual that at Servo travel = 0, the Master Gain is 1.0 and therefore anything from 0 through +100 would then yield a Master Gain of from 1.0 to (2.0?).
Elsewhere in here, it was suggested that the Master Gain maximum is 1.0,
which would occur at Servo travel = +100%.
Which is true?
Despite what has been suggested elsewhere in here, I am not over-thinking this. It is a simple and obvious question and I have a very good reason to want to know. I see no reason why ET wouldn't want to make things as clear as possible.
BILLPA, can you help?
I'll give it a stab. It has to do with scale's. Similar to Inches vs. Metric on a rule(r).
Your servo endpoints go from -100 to +100. The Guardian's Master Gain on the other hand goes from 0% to 100%.
So if you where to take a paint stick and start carving on tick marks on one edge that went from -100 to +100, and on the other edge 0% to 100% then you would find that at 0 travel the Master Gain equals 50%.
Using percentages is much nicer in describing your setting for the Master Gain. Using a scale that goes from 0 to 1.0 to 2.0 would be awkward at best.
Silverexpress is offline Find More Posts by Silverexpress
Old Jan 20, 2013, 09:16 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by choochoo22 View Post
This discussion of gain is prompted by what seems to be an unfortunate choice of nomenclature by Eagle Tree. To begin with "percentage" of what, exactly are we talking about? In my mind it's percentage of maximum gain, which by definition is 100%. So with pots and master at max, this is the most gain we can get and should be 100%. Calling this 200% doesn't make much sense, but also doesn't make much difference.
Both the pots and master gain are uncalibrated analog knobs. When you turn them up you get more gain, down is less. Does it really matter what number is associated with the gain you are using? Typically you will adjust the gains for max gain short of oscillation and probably leave it there, perhaps dialing down the master occasionally. About the only time it seems to matter is when trying to communicate settings to someone else. If we communicate both the pot and master positions we should be fine.
The section of the manual quoted by ricoalonso stopped short of the line that says "The ranges given above apply when the Guardian gain dials are set to about +-50° from center", which is less than half travel. How does that alter the discussion? Also contributing to the confusion, it is rather difficult to determine with any accuracy how much gain you are actually experiencing. It might be interesting for someone with an uninstalled Guardian to set up a bench test. For instance, ET says with the gain plug disconnected, you get 40%, of 100%, or 200%? How does the gain change when the wire is plugged in and master at half, full position?
Deerslayer, you seem like the perfect person to set up such a bench test and determine how these settings actually translate to percentage figures.
ChooChoo,
+1. I totally agree. The master gain and three on board pots are uncalibrated analog controls. In my opinion the master gain is simply like have a master volume control over three speakers. It ranges from OFF to full ON.
Prof100 is offline Find More Posts by Prof100
Old Jan 20, 2013, 09:36 AM
Andre Germain is offline
Find More Posts by Andre Germain
Joined Mar 2011
Pulsing surface in elevon mode
Greetings,
I have an Airfield 64mm F18 which I have configured as elevon (ailerons used as flaps) on a Turnigy 9X, working fine for 2 years. I then removed the elevon feature, installed the 2D-3D (new from HK, first time used, recent batch [waited since August 2012]) and enabled the Eagletree elevon mode. Everything works fine except that inexplicably every minute or so, one of the surfaces (elevator) pulses about 2 second intervals to near maximum, and this goes on for about 20 seconds, then it stops. I doubt it's the receiver or transmitter as they worked fine when the 2D-3D was not in circuit.
Firmware 1.17, Data recorder 10.43
Cheers
Andre Germain is offline Find More Posts by Andre Germain
Old Jan 20, 2013, 09:37 AM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
Master Gain and Guardian gain?
Has anyone ever considered that maybe (just maybe) the ET programmer who did their firmware code had it so that when the Master Gain is not connected, the maximum gyro gains is only at 50% when the gain pots are at the maximum position? If this is true then that explains the updated entry in the manual.
ricoalonso is offline Find More Posts by ricoalonso
Old Jan 20, 2013, 10:41 AM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Hi there,
Can someone help me with initial setup of the guardian.
I have it in the model and the controls etc are working fine, the gains are set and the compensation works fine. There are a few problems that interest me. Do you set up your aircraft on the tx with 0% subtrim and zero trims, I ask as this model flew before and in the previous model memory there was sub trim set to get the servo arms at 90 degs, then the rod was adjusted to get level trim etc. If subtrim is used with guardian does this get interpreted as a control input and subsequently try to execute the subtrim as a command to turn or elevate. If so what is the best way to get your servo,s set prior to using the guardian. I can't find reference to this in the manual.
Also changing the gain knob on my dx8 to control master gain seems to move the control surfaces as well this does not seem correct, have I got some thing set up wrong?
Busher is offline Find More Posts by Busher
Old Jan 20, 2013, 10:58 AM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
Numbers again. As near as I can tell, master gain (-100% to +100% in the tx) simply allows you to go from zero gain (off) to guardians pot setting as max. The pot setting being the available max gain.
Have the tx master gain at +100% and need more gain? Increase the pot setting.
t.edwards is offline Find More Posts by t.edwards
Old Jan 20, 2013, 01:15 PM
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
Originally Posted by Busher View Post
Hi there,
Whatever trims and subtrims you had in your aircraft before the Guardian 2d/3D was installed, should remain BUT, you need to let the Guardian know about it by doing the Reset Trim procedure as detailed in the Guardian manual. The same procedure should be done after everytime the amount of trim/subtrim is changed. The Guardian's Reset Trim procedure is to tell the Guardian that your neutral sticks postion contains some trims to add into considerations and NOT to interprete that amount of trim/subtrim as a command to turn or elevate.
As for your master gain affecting the control surface deflection as you change it, it could be caused by not doing the Reset Trim procedure and the Guardian is currently interpreting any trim as a command. Try performing the Reset Trim procedure first and see what happens. I know there are a few other ways this can happen depending in what mode (ie: 2D or 3D HH) you are in but let's do this one step at a time.
Old Jan 20, 2013, 01:56 PM
Busher is offline
Joined Apr 2011
Thanks for your help I will get back to the aircraft and see what is required to sort the trims etc.
Old Jan 20, 2013, 02:44 PM
HenryLe is offline
Find More Posts by HenryLe
Sweden, Västra Götaland County
Joined Nov 2012
Eagletree. Turnigy 9x Frsky, Setup
Hi There! :-) Can someone PLEASE help me, I'm going CRAZY! :-)
I have googled for a week now but can't get my settings right. Here is what I have:
Turnigy 9X with Frsky module (Mode 2)
Guardian ( 2D & 3D)
My problem:
1.) Don't know which radio input method I must use.
2.) Ch6 (of the Rx) is pluged into Aux & Ch7 into mod & Ch8 into Gain, . Is that correct?
Looking forward to ANY reply.
Henryle
HenryLe is offline Find More Posts by HenryLe
Old Jan 20, 2013, 02:57 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by henryle View Post
eagletree. Turnigy 9x frsky, setup
hi there! :-) can someone please help me, i'm going crazy! :-)
i have googled for a week now but can't get my settings right. Here is what i have:
Turnigy 9x with frsky module (mode 2)
guardian ( 2d & 3d)
my problem:
1.) don't know which radio input method i must use.
2.) ch6 (of the rx) is pluged into aux & ch7 into mod & ch8 into gain, . Is that correct?
Looking forward to any reply.
Henryle
me too!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 20, 2013, 03:22 PM
Deerslayer is offline
Find More Posts by Deerslayer
Kingston Ontario Canada
Joined May 2006
This made sense to me ... until I read what it says in the manual (Version 1.7, Page 6):
~0% to 100% (1.9ms servo pulse, 200% Overall Gain)
thereby making the maximum overall gain possible of 2x whatever is set on the pots, right?
It does state at the first of this section:
When this feature is used with 2D mode,
which could mean that perhaps what happens in 2D mode is different than how things are interpreted in 3D mode?
I probably should apologize for whipping a dying horse and wasting everyone's time on this matter. I fly year round up here in the Great White North (+90F down to -10F and often windy as hell, with or without some snow to make it more interesting); knowing the intimate details of my radio gear is probably a lot less important to me than remembering to wear warm socks when I head out to the flying field. But then, there are those occasional days when the weather is poor, so I end up thinking about this stuff.
Deerslayer is offline Find More Posts by Deerslayer
Old Jan 20, 2013, 03:58 PM
Joined Aug 2005
No, it just means from -100 to +100 is a range of 200.
2D is different in that its self stabilizing, resets the plane to it's pre-set attitude which it doesn't do in 3D
I think you're just getting tangled up in some "less than ideal" wording in the manual. I think it needs to be looked at as just "more" or "less". The numbers are relative and are simply a numeric way to say "more" or "less".
Old Jan 20, 2013, 04:15 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Yes, the convoluted and near psychotic word salad numbering scheme is simply confusing! "More or higher" gain when turning clockwise and "less or lower" total gain when turning it counter or anti clockwise.
Old Jan 20, 2013, 04:22 PM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
Guardian ( 2D & 3D)
My problem:
Henryle
Have you read post #2792? It helped me. but my 9X is stock standard.
Grantham Kid is online now Find More Posts by Grantham Kid
Latest blog entry: A bit about me
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
