United States, OH, Loveland
Joined Feb 2007
It seems to me that unless you have a radio with 3 position switches and mixing that you cannot use your transmitter to change settings, etc. This requirement should have been stated in the info for the Guardian. Not everyone has an advanced radio. Some people only have the basics. If I would have known this I would not have wasted my money on this stabilizer. Not everyone has access to a computer and needs to use their transmitter to adjust their plane.
United States, CA, Santa Clara
Joined Mar 2011
Ah fotoflyer, I know your pain. I waited months for HK to come good and eventually got a refund and they still haven't got any. Then I missed out on stock at 2 other places, so I bit the bullet and placed on backorder with Tower Hobbies. I never dealt with them before as I live in Australia, but be blowed, 2 days later I got notification that my Guardian was on the way. I also bought some HK Orange V2s and they work pretty well for the money but one of them has a dud Yaw pot. Not that it worries me as ailerons are the main usage for me. If I want rudder I can turn the unit over and use aileron outlet as yaw.anyway. The Guardian makes up 4 gyros for me including an old JR G410T Piezo gyro that I love. I see there is an extended harness for the Guardian that could be useful and I will probably order that in the future. Worth a thought. |
Joined Feb 2007
Sorry for this basic question-
I am using a Futaba Tx- My 2 position switch does not have -100/+100 settings. It only goes from 0% to 100% in either the up or down position. It does not have - numbers. How do I set it up for 2D/3D? Sorry to be so dense. |
United States, ME, Wells
Joined May 2008
Futaba vis-a-vis 2D/OFF/3D
I no longer have a Futaba radio, but IIRC the pulse width emitted is equivalent; i.e., 0 - +100 emits the same pulse as, say, a Spektrum Tx going between -100 and +100.
That is the key; i.e., the numbers aren't what the device is seeing - only the pulse widths matter. Is there a Futaba expert who can help? This is all from memory and, being older than dirt, my memory is the first thing to go - forget what is the second... :-) Michael |
Joined May 2008
Plug A Servo???
You should setup the plane without the Guardian; i.e., the plane is ready to fly prior to Guardian installation. This means that you have identified the correct port/channel assignments, correct FWD/REVERSE, sub-trims, etc.
If you would rather do this "blindly", then a quick method is to bind the receiver to your transmitter. Plug a servo into the outputs while moving the sticks (aileron, elevator, and rudder) and you will see which receiver channels are associated with the three primary controls; Guardian only controls those three flight surfaces. The only wrinkle might be if you use two aileron servos without a "Y" - then just be consistent with which channel is the first aileron channel (plug the Guardian aileron lead into that port) and which is the second aileron channel (plug the Guardian AUX lead into that port.) Michael Quote:
United States, AZ, Tucson
Joined Mar 2012
Joined Mar 2011
The center is considered 0% and each extreme is -100% or +100% by default. Unless you have done something to change it your switch is going from -100 to +100. This will switch Guardian from 2D/3D. Most transmitters made in the last 20 years have the ability to set the travel limits in each direction and reverse the direction. You could adjust the travel in one direction to zero, for instance, and then you would have 0% to 100% which would switch Guardian from off/2D or 3D. The actual numbers are not important, just for reference. Guardian mode channel has a wide tolerance for each position so there is no need to fine tune this.
Joined Mar 2011
You need to know which channel is which to install the receiver in any plane, with or without a Guardian. Snowflake gave you a process to figure out the channel order by simply plugging in a loose servo on the bench and trying each channel one at a time until you know what they all are. This should work fine. Programming comes later.
France, IdF, Paris
Joined Nov 2008
Hello, I recently bought a guardian and installed it inside a parkzone striker. I bought another one yesterday for more test in other planes.
It so far precisely act as intended in both 3d and 2d modes. No issues at all. Easy to install, easy to use. I hope i will not discover any problem or dysfunctions later as such problems could cause plane crashes... Only 2 things I regret, - Eagle Tree should set a new function to trim the 2d level mode in flight, as some of their competitors do as it is very difficult to get a perfect level flight attitude recordd when set on the ground !!! Bad point. - then I also regret they do not offer any gps option such as their competitors including return to home option. Thanks to you all for the 183 pages I read on this forum topic !!!!! |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
