This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Dec 19, 2012, 07:20 PM
RickerG is offline
Find More Posts by RickerG
Joined Feb 2005
Yes, only with GuRdian connected byes, verified Set Level Trim ok. No on PC stuff. I do not have PC. I use Mac and it appears that Eagle Tree does not support it.
If this is the case, and I must have a PC to make this product work as designed, then they should state this prior to purchase.
Anyone looking to purchase a new and perfectly good Guardian Stabalizer?
RickerG is offline Find More Posts by RickerG
Old Dec 19, 2012, 07:50 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
You do not need a computer to access most of the functions. It is nice to select centring stick only in 2D & sub-mode in 3D. I didn't use the computer for either installation for first flight.
DavidN is offline Find More Posts by DavidN
Old Dec 20, 2012, 08:22 PM
RickerG is offline
Joined Feb 2005
Update- it works. Needed to reset trims and zero everything out using PC connection and update the firmwear.
On the bench, it looks like it is working very well. Getting a bit excited to see how it does in the large Cub.
Thank you all for your help. I will let you know how it flys soon.
Merry Christmas.
Old Dec 20, 2012, 10:14 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Merry Christmas.
RickerG-
That's great. By the way, netbooks and used laptops are pretty cheap these days. I take a netbook to the flying club to help others setup their Guardians.
That said, my first flights with a Guardian were all done without adjusting anything via the computer.
Bill
Prof100 is offline Find More Posts by Prof100
Old Dec 21, 2012, 05:10 AM
dyn376 is offline
Find More Posts by dyn376
Joined Dec 2010
can i mount it directly to a receiver?
or will it cause interference
i want to mount one in my stryker F27Q
dyn376 is offline Find More Posts by dyn376
Old Dec 21, 2012, 07:59 AM
sinowace is offline
Find More Posts by sinowace
Joined Feb 2007
When you want to reset the trims after the first flight using the G in 2D mode do you have to level the plane before you connect the battery and move the mode switch?
sinowace is offline Find More Posts by sinowace
Old Dec 21, 2012, 01:43 PM
choochoo22 is offline
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
No, but you may want to. You have 15 sec to execute the reset after plugging in the battery so if you move or pick up the plane while plugging the battery (some go in the bottom), that's OK as long as you set the plane down level and flip the switch within 15 sec. That doesn't leave much time for fiddling around, however, so you should have the position pre-planned.
choochoo22 is offline Find More Posts by choochoo22
Old Dec 21, 2012, 02:40 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
In stock at Towerhobbies
I just notified that it is in stock at Towerhobbies for US$65.99 :
http://www3.towerhobbies.com/cgi-bin...&P=IA&I=LXCUCV
flying-llama is offline Find More Posts by flying-llama
Old Dec 21, 2012, 02:42 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
We now have Guardians in stock.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Dec 21, 2012, 03:09 PM
Gadget99 is online now
Find More Posts by Gadget99
Missouri
Joined May 2010
Atlanta Hobby has guardian 2D/3D in stock.
http://www.atlantahobby.com/store/pc...7&idcategory=0
Gadget99 is online now Find More Posts by Gadget99
Old Dec 21, 2012, 03:52 PM
Joined Mar 2006
Originally Posted by cambradjones View Post
Looks like the problem may be the Hitec telemetry???
Video shows the rx pack going as low as 4.2v on the tx display, but the voltmeter never drops below 4.7v. I guess the telemetry system is receiving inaccurate voltage drops?
It may be that the voltmeter does more averaging of the readings before finding the minimum than the telemetry.
Old Dec 21, 2012, 04:39 PM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Mac and Guardian
I run several OS, but carry around a small MacBook Air. To handle my Guardian (and FMA PowerLab 8 units), plus a few other things, I installed Parallels along with a cheap Windoz 7 basic OS.
Absolutely no problems updating the Guardian firmware, installing the PC software, or running it. Works great with the FMA PL8s; quite seamless.
Might be cheaper than a netbook or used laptop as there always seem to be specials on Parallels. :-)
Michael
Originally Posted by Prof100 View Post
RickerG-
Bill
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Dec 21, 2012, 06:43 PM
Rick
Joined Mar 2011
With Tattletales you can select the period from 100ms down to 10ms.
Old Dec 22, 2012, 04:34 PM
RickerG is offline
Joined Feb 2005
Update - it works.
I did what the manual said, set level flight, turned giardiasis off, took off, climbe and then turned guardian on. POP! Right to level flight. Rolled inverted and hit the switch again. POP! Right back to level flight. Adjusted the Gaian bit and decided to shoot an approach with guardian on. Wow, now that's cool. Using only throttle to adjust decent rate I pulled off a nice landing, again, again and again.
Lots of fun.
Thanks for your help now time to get creative with it.
Old Dec 23, 2012, 12:07 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Update - it works.
Lots of fun.
Try setting level flight inverted, making sure the angle of attack is enough for level flight. So when you want to impress the lads at the field, just flip the switch to 2d and fly around inverted...
hendrnk is online now Find More Posts by hendrnk
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
