This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Dec 14, 2012, 12:15 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by ImJeffW View Post
I find that once my plane is dialed in I only adjust the gain knob based on the speed I'm flying. My Reno racer does 100 mph+ and I was constantly fiddling with the gain control. Rather than assigning the gain to a POT (knob) I have my gain mixed with throttle position and use a custom curve to set gain end points and lower stabilization at higher speeds. I also set-up a slowed response on down throttle to avoid over-stabilization if I drop the throttle at high speed. It took a little doing, but once set-up my gains are automatic so I don't need to make consent adjustments.
Nice way of doing it
hendrnk is offline Find More Posts by hendrnk
Old Dec 14, 2012, 03:49 PM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Care to share settings?
Bugbitten is offline Find More Posts by Bugbitten
Old Dec 15, 2012, 04:15 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Originally Posted by Jakethedog View Post
Thanks for the response when the unit is on (plugged in) I have no led light even if I switch from 2d off and 3d 2d being down on the three position switch , and yes I considered it working because when I move the plane around it response to the movement with no light , I did black out my garage to insure that the light was not just dim. I flew it a couple hours ago it seemed to respond to what ever what I put it through for the exception with the switch in the up position didnt seem to get much correction. My understanding is 3d is the up position and I really didn't see much help from it when in flight thanks again for your help I hope I answered the question George
Hi George,
Please email EagleTree directly for technical support. You may need to send in your unit so they can inspect it thoroughly. No one else here seems to have experienced the same thing....at the moment.
Silverexpress is offline Find More Posts by Silverexpress
Old Dec 15, 2012, 10:36 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
I can see why people new to the Guardian sometimes get confused or have trouble. I have been reading and contributing to this thread since last spring and I still found some behavior I can't sort out.
Has anyone noticed creep/drift in their Guardians? I have one unit which, no matter how many times I reset it, exhibits creep in both modes. In 3D the rudder slowly creeps left, it would probably take two minutes to reach full deflection. In 2D the rudder is fine but the heading very slowly creeps left, evidenced by the ailerons. If left to do so, it would probably take 10 min to fly a full circle. Neither of these has much impact in the air, the rudder is constantly being reset by any stick movement and the heading creep is too slow to notice. Still, it's disappointing that these can't be eliminated.
Another unit does not exhibit this creep but seems to perceive major trim settings that aren't actually present during the first few seconds after connecting the battery. If the Guardian is in either mode when powered up or is switched on in the first couple of seconds, it drives all three channels to the stops. This effect fades away in about 10 sec. To do a reset, it's necessary to wait as long as possible in the 15 sec window or the imaginary trims will mess up the setting.
Has anyone else experienced problems like these? I'm not completely convinced that these symptoms are being caused by the Guardians but I haven't been able to identify any external problems either.
choochoo22 is online now Find More Posts by choochoo22
Old Dec 15, 2012, 11:20 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Yes, there is some creep drift in the four that I fly. I don't worry about it. It only means there is only so much you can expect out of a $75 system.
I always connect the battery with the Guardian off and then turn it on. I used to have the surfaces drive to max until I limited the servo throws in the Guardian.
Bill
Prof100 is offline Find More Posts by Prof100
Old Dec 16, 2012, 12:21 AM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
I never experience any creep/drift in my 2 units but I also make sure the model is acclimated to the sorrounding where I am flying., for at least 10 minutes, before I power it ON. Not sure if that helps but just an old habit when dealing with electronics and gyros.
ricoalonso is offline Find More Posts by ricoalonso
Old Dec 16, 2012, 12:38 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
With Guardian expander,
Heading hold feature will make the control surfaces travel to their endpoints.
If you hit the sticks, they will seek neutral, until you move the model sideways, tilt it, or move it backwards. then you hit the sticks and it seeks neutral again.
Other people like that mode, but it gives me the creeps, so I keep heading hold off...
Also:
another thing to consider with creep and drift, is if you are using a foam airframe, it will change shape with different temperatures.
This could cause the symptoms that you describe.
m_beeson is offline Find More Posts by m_beeson
Old Dec 16, 2012, 07:14 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
This is the Guardian 2D /3D stabilization thread which often gets confused with othe Eagle Tree devices.
Thre Guardian 2D/3D is a stand alone device and does not support at present the advanced feactures of other ET device used in FPVC.
Charles
Old Dec 16, 2012, 08:45 AM
WILLIAM M is offline
Find More Posts by WILLIAM M
GOTTA FLY STRIGHT UP
WILLIAM M's Avatar
United States, FL, Lake City
Joined Jun 2012
ImJeffW
I have just installed a 2D3D In my Senior Sportwin http://www.rcgroups.com/forums/showt...767479&page=14
I have a fataba 10c TX and was wondering if anybody knows if this mixing can be done on it??
Since my plane is in the 100mph class. I need to adjust the gain with the slide lever on the left side of the TX .
Bill
WILLIAM M is offline Find More Posts by WILLIAM M
Old Dec 16, 2012, 12:54 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
From what I have read about single-axis (tail) gyros for heli's, this slow creep in head holding mode is fairly common in gyros. The usual solution was to either buy a more expensive head holding gyro (over US$100 for a single-axis gyro) or just put-up with the slow drift.
This I have experienced, as well as gyro drift from temperature changes (a heli that is warming-up while flying, or falling temperatures with sunset).
flying-llama is offline Find More Posts by flying-llama
Old Dec 16, 2012, 02:06 PM
Rick
Joined Mar 2011
Thanks guys. I guess you're right that that there is only so much you can expect. It doesn't seem like temperature could be a factor though. The planes are stored in my garage and the observations were made in the garage on a table not touching the plane after the battery is plugged in.
Old Dec 16, 2012, 02:36 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I'm not confused, but if you feel that this is not a posibility, then disreguard it as being a possibility.
-Mike
Originally Posted by everydayflyer View Post
This is the Guardian 2D /3D stabilization thread which often gets confused with othe Ragle Tree devices.
Charles
Old Dec 16, 2012, 03:58 PM
ZDAD is offline
Find More Posts by ZDAD
Discovery Bay, Calif
Joined Mar 2006
I now have two quotes printed out above my desk
"We make a living with what we get. We make a life with what we give."
Churchill
“I'm not confused, but if you feel that this is not a possibility, then disregard it as being a possibility”
Mike m_beeson RCGroups
Mike is it OK to quote you?
Keith
ZDAD is offline Find More Posts by ZDAD
Old Dec 16, 2012, 04:13 PM
Your customer
Joined Dec 2009
Like what others have already stated - what I've read and experienced is the same with hh gyros
The creep in HH can be caused by...
1. The system senses a minute rotation and starts adding a correction. It continues to do this expecting feedback - roll, pitch, and or yaw. It will continue to add more correction until it senses the counter rotation or the servos reach their limit or you switch to rate and back or you move and then recenter the sticks. The latter two sets or resets a new heading
2. User added trim.
3. No dead band.
Whats interesting is that the AS3x is the only system with software I know that keeps the system off until you increase the throttle.
More primitive alghorthims make it detrimental to rog and takeoff in HH. Not so with the Guardian.
Old Dec 16, 2012, 04:40 PM
Galand is online now
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
USB Connector
Bad crash yesterday. Something slammed into the front of the Guardian and broke loose the USB connector from the board.
Cut open the celluloid to have a look at how this could be fixed.
It looks like a combination of two crimp and maybe two solder points.
Beyond my capabilities. What a poor setup!
Is this a lost cause?
Galand is online now Find More Posts by Galand
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
