United States, CA, Santa Clara
Joined Mar 2011
To test 3D, try this. Put the plane on a table and activate 3D in heading hold mode with max gain. Now rotate the plane on each axis one at a time. In all cases the relevant surface should move the same way you move the plane and will probably reach max deflection in perhaps 30° of rotation (depends on servos and linkage). For instance, push the tail right and the rudder should move right. It's not clear that you have a problem. In any case you have an off switch. Do a reset with the plane sitting on its wheels, switch Guardian off, and fly it! In flight, switch on 3D and see what happens. If it does something unexpected switch it off and tell us about it. |
United States, IN, Crown Point
Joined Nov 2011
Not sure if changing the stock settings will cause this to work differently or not, Forgot about that part of the manual. With the stock setting on my eflite apprentice 15e, this thing ROCKS. I call it my training wheels. As I get more flying in next year, I'll turn the gains down. Takeoffs and landing in 2D makes me look good. |
Joined Aug 2005
Linking airspeed to gain control
James. |
Joined Aug 2005
James. |
United Kingdom, England, Long Eaton
Joined Nov 2012
The rud/elv move a similar amount when moved via the TX, the rud movement by the guardian when waving the plane around is down roughly 1/3 of what it can travel. Thanks |
Ashtabula, OH USA
Joined May 1999
3D rudder corrections for yaw will be obvious, if the pot and xmitter gains are turned on enough - as the 3D Guardian uses rudder for yaw corrections and ailerons for roll corrections. |
United States, CA, San Diego
Joined Nov 2012
Help
Hi I have a 2d-3d stabilizer have it all plugged in and it is working but the led won't light up ,did I miss a step I have two plugs left over gain and the one for having duel aleron servo , also my gear is dx7 can some one help I have watched the video 20 times and have read the instructions , and now have my self so confused thanks I really need your help. George
You say "it is working", but I'm wondering if, by "working", you mean the control surfaces move correctly in response to you moving the TX sticks? Or do you say "working" because you can shake and roll the airplane... and the control surfaces move on their own? Unlikely: If you can shake and roll the airplane... and control surfaces start moving on their own to counteract your motions... then some form of stabilization is activated and the LED should *not* be "solid off". It should be either "solid on" (3D mode) or "blinking" (2D mode). More likely: If you shake and roll the airplane, and control surfaces stay completely quiet, then the unit is "disabled"... and a "solid off" LED is correct. If this is the case... then, yeah, your TX either isn't configured right... or you haven't flipped the TX switch that activates the Guardian's stabilization. Let us know what you've got... and we'll go from there. |
Joined Nov 2012
Thanks for the response when the unit is on (plugged in) I have no led light even if I switch from 2d off and 3d 2d being down on the three position switch , and yes I considered it working because when I move the plane around it response to the movement with no light , I did black out my garage to insure that the light was not just dim. I flew it a couple hours ago it seemed to respond to what ever what I put it through for the exception with the switch in the up position didnt seem to get much correction. My understanding is 3d is the up position and I really didn't see much help from it when in flight thanks again for your help I hope I answered the question George
So... your LED is borked... that's a shame. There are a variety of error messages you won't be able to see without it (e.g. brownout). However, mine is buried in fus... so I never look at it anyway.
You mention that 3D mode (sw-up) response doesn't seem very strong. Simple gain adjustments? Without the gain plug connected, you'll need to dial this up on the ground. It'll be hard to tell where the right settings are without a gusty day to challenge the Guardian a bit. |
Germany, Berlin
Joined Jan 2012
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
