This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Dec 03, 2012, 05:47 PM
Ralph E is offline
Find More Posts by Ralph E
Miami, Florida
Joined Oct 2006
I read the manual and found that in order to install the remote gain adjust feature I need an variable "rheostat" type knob on the transmitter or a "slider" switch. I have the Spektrum DX7 which does not have an adjustable knob but does have and Aux2 toggle switch with a momentary (sliding) switch next to the toggle. Can I use those switches to hook up the gain function?
Ralph E is offline Find More Posts by Ralph E
Old Dec 03, 2012, 06:18 PM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Hovering like a pro
Today, flying a foamy called the Unique, I hovered like a pro using Guardian 3D - never hovered more than a few seconds before. Not only that, I could spin the plane about the roll axis, while hovering. Until it got old (about 20s).
The Guardian can get in the way though, sometimes. Two instances readily come to mind ...
For instance, if the space for landing is tight, having the Guardian on can result in turns that are wider than the available space.
Another issue, the airspeed is no longer indicated by the lift the plane is exhibiting - since the Guardian dampens the planes response to its own lift. And this can make landings interesting.
Bit all in all, it's just pure fun, learning what it can do, and how to take advantage of it. But me hovering - my stars - what's the world coming to. I'm basically a glider pilot, not a stuntman.
Tim Green is online now Find More Posts by Tim Green
Old Dec 03, 2012, 10:21 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
You can use a two position switch to set high/low gain, or a 3 pos switch for low/med/high. I find the remote gain is useful on some planes but is not really necessary once you have a good gain set on the pots.
choochoo22 is online now Find More Posts by choochoo22
Old Dec 03, 2012, 10:27 PM
Rick
Joined Mar 2011
This is definitely true in 2D but if you are experiencing this in 3D you may not have the settings optimized.
On landing, I like 2D mode. If I kill the throttle and just steer with gentle aileron, Guardian will hold the plane in a slower glide than I could ever manage and automatically correct for turbulence as well. It may take a few tries to get the angle set right to make this work to your taste.
Old Dec 03, 2012, 10:30 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
+1 on the above.
Prof100 is offline Find More Posts by Prof100
Old Dec 04, 2012, 01:57 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
I find the 2D level seems to change from day to day. 1 day its perfect for straight flying, the next day its either climbing, descending or turning. Its not consistant from day to day for some reason.
Not sure if anyone else is finding this.
hendrnk is online now Find More Posts by hendrnk
Old Dec 04, 2012, 10:19 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Are you adjusting radio trims and not resetting trims in the Guardian?
Old Dec 04, 2012, 01:23 PM
andy335touring is offline
Find More Posts by andy335touring
United Kingdom, England, Long Eaton
Joined Nov 2012
Just setting up the Guardian, i've got the control surfaces deflecting the right way but i seem to be getting less Guardian deflection in 3D than 2D, is that normal ?
Also i've played around with the pot gains but the rudder doesn't seem to move as fully as the elevator does ?
I've might just have the wrong settings ?
andy335touring is offline Find More Posts by andy335touring
Old Dec 04, 2012, 06:33 PM
Ashtabula, OH USA
Joined May 1999
Neat.
I get my kicks out of being able to hand launch in 2D or 3D modes without touching the transmitter - until I choose to stop the ascent, I can just watch it go up in a straight line. (My 2D mode works for launches, as it has an upward pitch built in, since I like my recoveries to pitch up a bit).
And the easy hovering on the prop using 3D as I said
And kiting down in steep landings - using 2D to keep it level. Especially in strong winds.
Old Dec 04, 2012, 07:16 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Give us some details on how you installed it and were in the fuselage.
Also are you toggling the mode switch right after you've plugged in a battery?
Silverexpress is offline Find More Posts by Silverexpress
Old Dec 05, 2012, 08:34 AM
Joined Apr 2012
No, but if I do a do the trim reset.
Old Dec 05, 2012, 08:41 AM
Joined Apr 2012
I had it on my SBACH 342 on the COG, but its totally destroyed now!.
Not touching the switch within the 15 seconds unless resetting trims from the flight before.
I could reset it via the laptop in the evening and in the morning it would be not be level again on the artificial horizon and after 10 min you could see it drifting around. SO I stopped using 2D as it was never consistent.
Old Dec 05, 2012, 05:17 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
3D control surface only need to move enough to maintain flight path (heading) prior to centering the sticks.
2D they have to move more to correct to straight and level flight from any heading as in a severe dive or very hard banked turn.
Does your Rudder as as much throw as the Elevaator when Guardian is switched Off?
Charles
Old Dec 05, 2012, 05:37 PM
Your customer
Joined Dec 2009
Ugh! What happened???
Old Dec 06, 2012, 10:02 AM
Joined Apr 2012
I'm learning aerobatics on a SBACH & a 3D parkflyer MX2, I will do some stuff with the Guardian turned on & then try with it turned off.
Anyway the guardian was off and doing a relatively low pass up side down at high speed, hit the ground. I suspect I pulled back instead of pushing forward. 2 steps forward in this case 3 steps back in the learning process.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 01:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 10:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 10:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 05:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 01:19 AM
