This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Nov 27, 2012, 02:37 PM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
/\ ...+1
Bugbitten is offline Find More Posts by Bugbitten
Old Nov 27, 2012, 02:43 PM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Guardian Maiden
I concur with Charles.
I posted a message about a maiden flight for my eFlite Habu 32 EDF. I used the Guardian, medium rates, lots of taxiing up/down runway to get a feel, then went for it and had zero problems.
I had tried to get more experienced members to do the maiden flight, but landings were disasters (broken retracts, one broken wing, etc.) The Guardian allows one to focus primarily on throttle and descent rate management.
I still would prefer a new bird have the kinks removed by an experienced pilot, but I have now performed the maiden flight on three birds, with a Guardian in 3D mode, medium gain settings, and all successful.
I make practice approaches to judge speed, descent rate, etc., and it is a pleasure to watch the Guardian keeping the bird flying smoothly as I focus on what's important to develop confidence for a successful landing.
Michael
Originally Posted by everydayflyer View Post
The Guardian 2D/3D as long as it is correctly installed and setup does in fact make first flights easier ,period.
There are many who's first RC flights were with ready to fly e Flite planes with their
AS3X stabilization system and many were with aircraft which were really a bad choice for a new flyer yet they were sucessful. The AS3X has made many of the difficult to almost impossible to fly models flyable by most. IMO the Guardian 2D/3D works a lot better .
Charles
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Nov 27, 2012, 05:29 PM
cactus is offline
Find More Posts by cactus
Micro Fpv=BVLOS around couch
United States, CO, Durango
Joined Sep 2001
What kind of master gain and axis gains have you guys found was useful for the first flight? I may be able to maiden my RMRC Penguin FPV plane this weekend and will not have much time to tweak it. I have the master gain set to my gear switch with full travel 100 to -100. As I understand it that translates to 100% gain and 0% or OFF. My axis gains are setup for the right direction at 40 on each one. I have the AUX 2 (3 way) switch hooked up to the MODE.
cactus is offline Find More Posts by cactus
Old Nov 27, 2012, 05:44 PM
Michael
Joined May 2008
Initial Gain Settings
My initial settings depend upon the potential speed range of the model; e.g., a park flyer vs. an entry EDF (e.g., PZ Habu 2), vs. a wider speed range EDF (e.g., eFlite Habu 32 Fiberglass).
If a typical trainer, park flyer, sport scale, etc., I set the POTS to fairly close to 100% in the proper direction (CW/CCW). I then use the default gain of 40% if my reading of the manual is correct (either set the knob, or leave GAIN channel disconnected as many of my birds do not have two spare channels for the Guardian.)
If a middle of the road model, then I cut the POTS down to about 60 - 75% (judgement call - rely upon automatic desensitizing of the Guardian). If a wide speed range, then I err on the lower side: typically 40 - 50% for the POTS.
If I have BOTH MODE and GAIN channels available, then I leave the POTS set to 100%, and set the GAIN to middle or slightly below. I then crank it up/down as a function of what the surfaces are doing, but have found that mid gain settings seems to have worked on all except my Carbon-Z Yak 54 where I had to go a little lower for the ailerons.
After six units in about eight models (relocated a few after comfortable flying with Guardian off), I feel pretty good about setting the Guardian up and judging the approximate gain settings. As I indicated, only the Carbon-Z caught me a little by surprise, but quickly tamed by cranking the gain down.
The great thing about the Guardian is that, even if the gain is too high, the bird is stable enough to take my hand off the stick, crank the gain knob down, then be ready to resume stick movement for a turnaround...
The only difference is wind: moderate, then 3D all the way. Strong (20 or more, gusts, cross-wind), then 2D for TO and L.
Michael
Old Nov 27, 2012, 07:55 PM
choochoo22 is offline
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
There are many who's first RC flights were with ready to fly e Flite planes with their AS3X stabilization system and many were with aircraft which were really a bad choice for a new flyer yet they were sucessful. The AS3X has made many of the difficult to almost impossible to fly models flyable by most. IMO the Guardian 2D/3D works a lot better .
Charles
Originally Posted by Snowflake6515 View Post
I concur with Charles. I agree with
Without a doubt, if you are on your own, or determined to do it yourself, a Guardian can improve your chances of a successful outcome. If help is available, however, it would be foolish not to use it. The "correctly installed" part is more likely to be accomplished for one thing. I agree with Prof100 that the first flight on a new plane should be made with Guardian off, trimmed properly, landed and Guardian trims reset. Most first-timers aren't able to do that alone. I've also recommended activating the Guardian for the first time at a safe altitude. If the pots are wrong or it's hooked up wrong, better to discover that there than at full throttle 3' off the ground.
Remember, those AS3X planes come out of the box with the deflections correct, linkages correct, CG correct, and stabilizer installed and adjusted properly for the plane. And Snowflake, it doesn't sound like that Habu was the first plane you flew.
It's probably not too much of a stretch to say that all of us have made at least one mistake installing a Guardian, usually caught and corrected in short order but it's not generally our first plane ever.
choochoo22 is offline Find More Posts by choochoo22
Old Nov 27, 2012, 09:51 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I truely wish that some would stop trying to make it sound like the Guardian 2d/3D is complicated to setup in a basic configuration.
Forget the remote gain, set pots to 10 Oclaock or 2 O clock depending on the direction the servos need to repsond, do the set level drill , move the plane around by hand to double check servos correction movements are correct and fly the plane.
The only issue I had with a Guardian was during early beta testing when there was a very serious bug in the firware and I caught it on the bench and to the best of my knowledge I was the only one testing that beta version as it had a mix. addation I had requested.
Charles
Old Nov 27, 2012, 10:19 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Charles
Charles,
I don't know who you are referring to regarding setting up a Guardian as being complicated. I have not said so but I do recommend that new RC flyer have teacher or tutor to help them learn how to fly RC planes. A Guardian will make things much easier for a newbie by reducing "pilot workload." Experienced flyers get a similar benefit.
Bill
Prof100 is offline Find More Posts by Prof100
Old Nov 28, 2012, 06:22 AM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
Anybody know of an Australian distributor of the Eagletree Guardian.
It seems HK can't supply nor give any indication as to when stock may become available so I cancelled my order/backorder there.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Nov 28, 2012, 07:41 AM
miksterr is online now
Find More Posts by miksterr
Melbourne, Australia.
Joined Jul 2006
Originally Posted by Prof100 View Post
Charles,
Bill
Hi Grantham,
Mongrel gear is an Aussie distributor. Haven't bought from them however.
Mike.
http://www.mongrelgear.com.au/the-mo...&category_id=8
miksterr is online now Find More Posts by miksterr
Old Nov 28, 2012, 12:31 PM
thaus is offline
Find More Posts by thaus
United States, FL, Vero Beach
Joined Aug 2007
Holy cow, this product really works. I flew a 39" foamy with the Guadian installed today and it held heading far better than I expected. It really locked on to the attitude the plane was in when the sticks were centered and would immediately released when the sticks were moved. I was really impressed. Thank you Eagle Tree.
thaus is offline Find More Posts by thaus
Old Nov 28, 2012, 02:19 PM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
I purchased mine from Mongrel. Had a little mixup with the order, but that was fixed quickly with a few emails. You may still have a problem with availability. Their next shipment isn't due until December, and many (if not all of these) may be already spoken for.
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Nov 28, 2012, 02:50 PM
andy335touring is offline
Find More Posts by andy335touring
United Kingdom, England, Long Eaton
Joined Nov 2012
Sorry if i've caused a bit of a debate or confusion by may be not getting my point accross well.
I am going to get the plane/Gaudians settings properly checked over by some one experienced at the club who will most likley carry out the maiden for me.
I will hope fully be buddied up/supervised to the point where i'm judged to be able to fly on my own.
I'm using the Guardian to help speed up my experience or learning curve not by trying to cheet on the amount of hours i would need to do but using it to enable me to fly more hours over a shorter period of time due to lost time due to wind.
This is really the wronge time of year to start flying over here being winter.
I've read this entire thread and lot of you experienced guys in this thread have stated you can fly in more windy conditions now you have the Guardian, the wind represents an even bigger chalenge to a learner who's trying to grasp the basics.
When i get to the stage i can fly on my own i'll have a partial safety net by flicking onto 2d, this might mean i can be slightly more adventurous than i would be with out so it could help me learn slightly quicker ?
Thanks very much for all your input and opinions so far.
andy335touring is offline Find More Posts by andy335touring
Old Nov 29, 2012, 12:52 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
If your in the Detroit, Michigan, USA area, Prop Shop Hobbies has a few instock (-1, hehehe). I was surprised to see them in the tx/rx counter.
Silverexpress is offline Find More Posts by Silverexpress
Old Dec 01, 2012, 02:11 PM
conrad95037 is offline
Find More Posts by conrad95037
Joined Aug 2011
Problem with software
I connect my new Guardian 2D/3D stablilizer in my PC via mini-USB port. I clicked on the Eagle Tree icon (version 10.43) which brought up the "Recorder Configuration Wizard". The LED flashed 3 times indicated it was connected. On the 2nd page of the wizard the "Next" button remains gray. In the background it brought up the "Data Recorder" screen which remained locked because the "Next" button remained gray. I read the troubleshooting tips but they were of no use.
Should I have my airplane battery connected?
conrad95037 is offline Find More Posts by conrad95037
Old Dec 01, 2012, 02:29 PM
Michael
Joined May 2008
PC Connection
Power to the Guardian comes via the USB connection, so you do not need the receiver battery connected for the PC interface to work.
It does sound as if the driver was not installed; hence the gray "Next" area.
Did you follow the directions about downloading the driver and the proper sequence of connecting the USB device and the ET Data Logger SW?
When I bring up the ET Data Logger SW, if the USB connection has not yet been established, I get a list of possible devices that it is expecting to have connected; one of them, of course, is the Guardian...
Michael
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 01:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 10:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 10:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 05:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 01:19 AM
