Between my tx and crashed aircraft
Joined Mar 2006
http://www3.towerhobbies.com/cgi-bin...&I=LXCUCV&P=ML I see: Eagle Tree Systems Guardian 2D/3D Inertial Stabilizer Stock Number LXCUCV Retail Price‡ 74.99 Tower's Low Price $65.99 Stock Status (Estimated) Late Nov I had put in a back order with Tower for this and asked them to send me an email when it became available. No email on shipping or availability yet. Nov. 24, 2012 UPDATE: Tower still shows the Guardian at 2D/3D at $65.99 Stock Status (Estimated) Late Nov But I also just got notified that my backorder just shipped. |
Ashtabula, OH USA
Joined May 1999
United States, CA, Santa Clara
Joined Mar 2011
Guardian is constantly computing and correcting which way is down based on gravity. In 2D it can use this to hold a camera level but only at the sacrifice of heading-hold. 3d makes no attempt to hold anything level but with HH active works to hold each axis constant so the camera should stay level only if it started that way. The longer version: I hope to build a dedicated camera plane similar the the Exposure. Since the plane only uses elevator and rudder, it seemed like the Guardian should be able to manage those two channels and also a third channel on the roll axis to keep the camera level, independent of the plane. To test this theory, I Jerry-rigged a really rinky-dink testbed on a Slow Stick. Among other things, it was necessary to disable heading-hold. In 2D mode the Guardian turns the plane by banking and this defeats the intended leveling of the camera. This setup works as intended but the plane lacks the ability to hold a course other than the usual trimming, not a fatal flaw. I did not test this out but one way to achieve leveling and heading-hold would be to use 3D mode with HH enabled. In 3D each axis is independent so the rudder should keep the plane on course, the elevator keeps the attitude, and the servo on the aileron channel keeps the camera level. The difficulty here is that the Guardian will hold the camera in whatever position it was when 3D was activated, not necessarily level. Drift could be a problem, I haven't tested it. If the camera comes off level from any cause, one way to level it would be to switch to 2D to straighten everything out and then back to 3D. But it's hard to tell if the camera is off level by looking at it from the ground, the plane could be at considerable distance. And you can't count on 2D to have it level when you switch back to 3D because if is making course corrections it may have "banked" the camera. Suggestions: This could be made simpler and more effective if Eagle Tree provided a software switch to tell G to use the rudder to hold course and not the aileron, and/or other gimbal optimized firmware. What would be really nice is for the firmware to fly the plane normally using all three channels, and output a fourth signal on the aux channel to keep a camera level. Even nicer would be to use two channels for pitch and heading (rud or ail) and the other two channels for a 2 axis gimbal. Therefore: Quote:
Joined Jul 2012
If I use a 'Y' cable with my Flaps, I'll have two free Rx channels that I can use with a 3-position switch and Knob. That's what appears to be the minimum to support both Gain and Mode control on Guardian 2D/3D.
I also have one free Mix, so I could combine the 3-position switch with the knob to produce a combined signal on one Rx channel. That would free up one channel to run Flaps on two channels instead of the 'Y'. I wonder why Eagle Tree doesn't support this kind of Guardian 2D/3D control on just one Rx channel? Barry |
Ashtabula, OH USA
Joined May 1999
Flying season's over here (snowing hard today) - so next week I'll put a camera stabilizing Guardian into my FPV car - and see what it's good for. |
Joined Mar 2011
By the way, even if you did all that, it still wouldn't track a target. That requires inputs for ground speed and altitude and a complex algorithm which would still be faulty if the target was not at the takeoff altitude. The best you could get from a 2 Guardian setup and 3 axis gimbal is to point the camera along a steady vector eg: camera level to horizon, 30° azimuth, 20° down, independent of aircraft motion within limits. |
Joined Mar 2006
Joined Aug 2007
Receiver killer
I lost signal from my receiver when I hooked up the Guardian. All had been working fine before hand.
However when the plane was moved (roll or pitch) the servos functioned yet the tx would not control the servos. Thus the Guardian was controlling the servos but the tx could not. Now when I test the receiver output signal to the servos I get 0 micro second pulses only. When I set the rx up in the simplest form ie. battery to rx and one servo connected and no Guardian, the rx still issues no signal. I can only conclude that the Guardian must have destroyed my receiver. Has anyone else experienced this?b |
Ashtabula, OH USA
Joined May 1999
Hopefully, you already have extra channels on your receiver and transmitter, else add that to the cost as well. So, we're looking at $105 to stabilize your camera independent of your platform vehicle (car, plane, quadcopter, etc), as it's bumping about. People do this in quadrotors today - it's quite fascinating to see the target video in the display remain steady while various parts of the quadrotor frame visible at the edges of the picture are jumping about. |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
