This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Nov 16, 2012, 09:57 AM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by choochoo22 View Post
Try it as-is. You will probably want 2D mode to keep the camera level, or at your selected angle. For best results disable heading hold and zero the derivative gain to minimize jitters. That should stabilize fairly well on the roll and pitch axes. You might experiment with the Guardian mounted on the gimbal vs. the platform. The yaw axis is problematic as 2D mode rolls the plane to hold heading so with heading hold on you will get tilt as the heading changes and with heading hold off you will get nothing with heading changes.
You could try 3D mode, using rudder for pan and elevator for tilt. Once the camera is pointed where you want in 3D mode - let go of the stick controlling the camera orientation (resets 3D mode to current orientation) - and the camera will track that point (without any roll correction).
I suppose you could add a third roll axis to the camera gimbal - and use the roll in 3D as well.
Tim Green is online now Find More Posts by Tim Green
Old Nov 16, 2012, 12:23 PM
lud is offline
lud
Find More Posts by lud
lud
Making mischief in the air
lud's Avatar
Berkshire UK
From Eagletree's site tonight
Guardian 2D/3D Inertial Stabilizer
BACKORDER. Batch 4 completely sold out! All new orders will be allocated from batch 5, which is anticipated to ship approximately January 2013
From this i assume that Eagle tree is going to fullfil it's own orders first before those of you at Hobbyking etc get a sniff of a unit. - guess I'm gonna cancel my order @ HK
case of demand absolutly outstripping supply
What was the name of that alternate supplier ??
lud is offline Find More Posts by lud
Old Nov 16, 2012, 12:41 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
Yes, 3D can work also and on all 3 axes but you have to keep track of the current orientation which may be difficult in a plane. Of course you could always switch to 2D momentarily when you want to level it. It would be nice if ET would release specific gimbal firmware.
choochoo22 is online now Find More Posts by choochoo22
Old Nov 16, 2012, 12:49 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Boy oh boy did I nail that one. After first beta testing the unit I informed Bill that there was no way they would be able to keep up with demand.
Charles
Old Nov 16, 2012, 03:04 PM
lud is offline
lud
lud
lud's Avatar
Berkshire UK
Bit of a bummer for those of us that are eagerly waiting for a unit..
I guess I'll hold off now till some stock appears but the downside is that funds tend to get reallocated ....
Old Nov 16, 2012, 03:26 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
No it means that both retail(individuals) & wholesale(companies) orders together maxed out batch 4 at the time they posted. So any RC supplier that has not presold all their allocation is open to your business.
DavidN is offline Find More Posts by DavidN
Old Nov 17, 2012, 10:02 AM
higharc is offline
Find More Posts by higharc
Joined Jul 2004
I just received by 2D/3D stabilizer and have a couple of questions. Refering to the individual gain dials on the unit itself, if I fully turn a dial clockwise or counterclockwise, would this be 100% gain? Are the graduation marks proportional? I set up a Mode/Config switch on my radio, but not as yet a gain knob. Thanks
higharc is offline Find More Posts by higharc
Old Nov 17, 2012, 10:49 AM
Southern Pride
Without remote gain the max. gain available by way of the pots is approx. 50%. I many cases 50% is to much. It is best to start with the pots set at approx. the 10 or 2 Oclock position depending on which way the servos need to respond.
Perhaps this post will help.
http://www.rcgroups.com/forums/showp...&postcount=954
Here is another one
http://www.rcgroups.com/forums/showp...&postcount=974
Charles
Old Nov 17, 2012, 11:46 AM
higharc is offline
Joined Jul 2004
everydayflyer: Thanks. I'll try that.
Old Nov 17, 2012, 07:22 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Ryan installed 2d/3d in his wing a while back. It has been a dream for him to fly.
Today I saw him flying, and decided to chase him with the Hexacopter.
It was pretty fun.
fpv chase (5 min 49 sec)
m_beeson is offline Find More Posts by m_beeson
Old Nov 17, 2012, 09:11 PM
higharc is offline
Joined Jul 2004
I have another question refering to dual ailerons. In my Futaba radio I am using the Aileron Differential function and the Flaperon function is not activated. The second aileron servo plugged into the Guardian's output channel Aux dosen't work because of my radio mix, I assume. The PC Software still has the Flaperon Inputs Unmixed box checked. I'm trying not to revert to using a "Y" connector in Channel 1. Can I still connect the two ailerons with this mix in my radio?
Old Nov 18, 2012, 06:17 AM
higharc is offline
Joined Jul 2004
To answer my own questions: After unchecking the Flaperon Inputs Unmixed box, everything seems to be working correctly in all modes even with the Aileron Differential activated in my radio. When using Ail Diff, the second or left aileron in plugged into Channel 7. In the reading, I was under the inpression that the Ail-Diff mix wasn't compatible with the Guardian. Any comments please. Thank you.
Old Nov 18, 2012, 06:46 AM
Southern Pride
Please see the
Wing Type Configuration in the maual and the Explanations in the four blocks below it. Also the Dual Ailerons / Flaperons explanations below the blocks.
Fair amount of information to dijest and for many of us it takes numerious reads and a bit of trail and error before things begin to click.
Charles
Old Nov 18, 2012, 08:38 AM
higharc is offline
Joined Jul 2004
Your help is greatly appreciated Charles. I also find that just using the "search this thread" feature leads me to an answer of a question that has already been asked.
Old Nov 18, 2012, 02:25 PM
Southern Pride
You are welcome and Crtl F (Find) works well also.
Charles
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
