This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Oct 30, 2012, 01:26 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
+1 Charles and Bill
Rick
choochoo22 is online now Find More Posts by choochoo22
Old Oct 30, 2012, 04:43 PM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Originally Posted by everydayflyer View Post
Read all of the post in this thread and you will see that there are many of us using the Guardian 2D/3D and having excellent results. Charles
The first problem I had of thge unit(s) not applying the correct level of corrective input had not 1 person being able to say why.
The 2nd problem of the usb granted was probably my fault but it still shouldnt have happened. It should have been designed much stronger then it is. I have never broken any other device with usb and it has been admited
that its a weak spot in the design.
Still noone has been able to explain why the 2nd unit went from not working to working without me changing anything , then back to not working again.
Also noone has been able to explain why another club member had one setup
and working whit it failing mid flight almost resulting in a crash.
He has now removed the guardian from his plane.
Originally Posted by Prof100 View Post
Agreed. The lack of knowing how to program a radio is more of a problem than I realized. Like you said, the new user tries to use too many features to begin. The motto should be to start simple and then experiment.
Bill
Instructions arent hard to follow, I'm not a dumbass, clubmembers also couldnt get them working
Im not sure why you stated " to many features" when you have no idea of my setup. I wouldnt have said 2d /off / 3d on the flap switch in a vtail plane is a complicated setup
The way I understood it is basic programing for the TX and all the mixing is done
on the 2d3d unit itsself.
I had the mode switch all working as intended and all correct inputs , outputs were correct when it was working.
The orange 3axis worked better then these units have so far.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Oct 30, 2012, 05:49 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Did you contact Eagletree and get help? They do have customer service.
Prof100 is offline Find More Posts by Prof100
Old Oct 30, 2012, 05:54 PM
lud is offline
lud
Find More Posts by lud
lud
Making mischief in the air
lud's Avatar
Berkshire UK
from all the positive feedback i've seen here - i'm happy to spend the cash on one ..but have couple of questions ...
I have a JR 2610 I'd like to set up with this...
no 3 way toggle switch, anyone help me how to setup the flap/gear to enable this?
2d/3d/off?
Do i only have the option of setting it up with 2d/3d switched and no ability to turn it off? (not that it seems like i'd want to anyway)
Also no rotary switch -so no in flight gain adjustment - i dont think it's an issue but how do setup the pots - what % ?
Are they easy to setup as the initial video certainly seems lke they are almost plug n play
any pointers would be helpfull
cheers
lud is offline Find More Posts by lud
Old Oct 30, 2012, 06:13 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
2d/3d/off?
cheers
I have Guardians on multiple planes and two different Spektrum radios -- a DX7 (old style) and a DX6i which has no 3 position switch. I use the DX6i flap switch for 2D and 3D and slave the Aux switch for off. It is just programming your radio.
No master gain is no problem. You just land and make adjustments to each pot. Start with pots set to 50% and fly it. If it oscillates, then turn down gain.
Old Oct 30, 2012, 10:23 PM
paul kelley is offline
Find More Posts by paul kelley
3d nut
paul kelley's Avatar
United States, CA, Stockton
The problem may be not knowing how to program my radio. I am going to give spectrum a call and tell the what I am trying to do, the give eagle tree a call what is gmt-7
paul kelley is offline Find More Posts by paul kelley
Old Oct 30, 2012, 10:45 PM
Rick
Joined Mar 2011
Greenwich Mean Time minus 7 hours. That would be California and west coast depending on daylight savings time.
Old Oct 31, 2012, 07:29 AM
WILLIAM M is offline
Find More Posts by WILLIAM M
GOTTA FLY STRIGHT UP
WILLIAM M's Avatar
United States, FL, Lake City
Joined Jun 2012
just search for greenwich time http://wwp.greenwichmeantime.com/time-zone/usa/
WILLIAM M is offline Find More Posts by WILLIAM M
Old Nov 01, 2012, 02:34 AM
3d nut
ha choochoo22 do you fly a rancho san antonio?
Old Nov 01, 2012, 02:49 AM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Mine arrived in the mail yesterday! Gonna put it in an old Phase 3 F-16 for starters. A touchy little jet that I've lost orientation on a few times lately, and the wrong input gets things out of shape pretty quick. Should be a good test for the unit.
Cheers,
Dan.
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Nov 01, 2012, 02:52 AM
Rick
Joined Mar 2011
Rarely, I usually fly at Baylands or Los Banos.
Old Nov 01, 2012, 03:10 AM
Rick
Joined Mar 2011
Cheers,
Dan.
Sounds like a good application. Let me suggest that you sort out the throws, trim, and CG before you install the Guardian. It may be able to overcome these shortcomings but it will fly better if it doesn't have to, and a lot better when you switch it off.
Another suggestion; I recently had an "energetic arrival" flying a plane with a Guardian that I know pretty well. I was flying inverted, fairly low, and headed in the general direction of a small hill, when I accidentally flew behind a tree. There are at least three ways the Guardian could have saved my bacon but it didn't because I panicked and tried to manually fly and recover a plane I could not see. If you are expecting it to save you, Guardian won't help unless you are prepared to engage it in an instant. You need to learn what it can do, trust it to do that, and be ready with your finger on the switch when you recognize dicey situations arising. In this regard it might be best to try it out in a more well behaved plane first to get the feel of it. OK, three suggestions.
Old Nov 01, 2012, 04:10 AM
Joined Aug 2008
Thanks Choo.
I've been flying this one for five years now, so I'm pretty comfortable with it - except when I can't tell which way it's banked - e.g. fast, going away, getting small and some gust deflection.
The plan is to fly it slow, closer and high while I'm testing and familiarising with the Guardian. I'll do drills until I'm comfy with it, then start to expand the envelope again. One drill will be one like you described: manual inverted, to 2d recovery, to manual climb.
Thanks for the advice. Still have to program it, install it, re-read the manual and troll through 150 pages of thread before I commit to aviating.
Cheers,
Dan.
Old Nov 01, 2012, 07:50 AM
JDougherty is online now
Find More Posts by JDougherty
JDougherty's Avatar
United States, AR, Benton
Joined Jul 2007
P3 F16 Gx 2D3D
Thanks Choo.
Cheers,
Dan.
I will be very interested in your setup and results. I have installed Guardian in a new F16 (predecessor totalled in a "through the sun - loss of orientation" crash. The small F16 can become a stealth jet in a hurry. I decided to run elevons with Guardian rather than in the Tx, per instructions. Weather has prevented a test flight. I set pots to 40%, Master Gain to 100%, checked proper correction direction. Everything appears to be working. Plan to fly initially with Gx disabled, activate at altitude. This worked with Gx in EFlite Super Cub, anyhow. Our flying season here has been cut short by Sandy - winds even the Guardian wouldn't handle and you need floats at our field!
Good Luck,
Jim
JDougherty is online now Find More Posts by JDougherty
Old Nov 01, 2012, 09:13 AM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Jim - I suggest that you turn the pots down to 30%, I'm guessing that even with a modest power setup you are hitting at least 100, the faster you go the less gain you need
Having a camera rolling
FCA
FLAME747 is offline Find More Posts by FLAME747
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
