Between my tx and crashed aircraft
Joined Mar 2006
It works within standard receiver voltage range ,as I posted above it is powered thru the ail. channel input leads from the receiver.
It will drop out at 4volts I believe(from memory ) and ET recomends using a seperate BEC if the one in your ESC is marginal / questionable. As to the max. voltage I have no idea as I only use nonimal 5 and 6V servos. Power consumption is listed as 50 mA. FYI The manual is still in flux and even us beta testers do not have all of the specs. Quote:
Great White North
Joined Jun 2008
!!!their 3D mode is really natural - for non FPV - I can see myself flying that mode 95% of the time!! Al |
2D mode is great for when you need to swath a bug,adjust your sunglasses cap etc.
3D Mode is like it is not even there except the wind does not blown the plane all around , motor / prop torgue is no longer an issue, knife edges and four points can be tweaked with little effort. Charles |
Joined Mar 2006
It sounds like some testing is in order if I also run a Guardian at that voltage. |
Joined Mar 2006
What is kind of unusual (to me) is that even with other Eagle Tree products, I cannot seem to find a listing of the allowed voltage range. |
Well for the past 50 years nonimal 5V (4 cell Ni) has been the standard for reveivers and servo and for the past 35 years or so some have been also rated nonimal 6V (5 cell Ni).Some servos even today are listed for 4 Ni cell only.
It has only been fairly recently that 1 and 2S Micros have start to be a bit more common. My first 1S was only a little iover two years ago and most that fly ultra micros on 1S do not want to add even 1/2 grams much less the 11 grams of a Guardian 2D/3D. The higher voltage recievers are also fairly new as well as higher voltage servos. Designing a device foreveryone / all purposes is not the norm and extra voltage regulation / sperate circuits would add extrea cost ,weigh and size,These are just my opinons / observations.. I believe there are Match boxs that are used in larger models that seperate receiver and servo power supplies as well as syncronize multi servos on a single flight surface. No expert in this are as I not not fly $3,000 plus models.. Charles |
Joined Mar 2006
I was just hoping to be told what acceptable voltage range is, like what I told for my older GWS 72Mhz receivers. Then I will know when and what type of voltage "games" to play. My main thing is that I have 4g or less servos that may be unhappy much over ~4.2V, so if I need to run the Guardian at 5V, I can either drop the supply voltage by ~0.7V to each servo using a silicon diode or run a separate ~4.2V voltage to all the servos. |
Yesterday I decided that I really needed to break down and put a bit more powerful motor on the Lil-Banchee,especially as I had purchased the motor over two years ago.
So with new motor installed. A snip from another post Quote:
Flys like it should now and no doubt will get flown a great deal more now. I only had 24 flights on it in 32 months and have added 19 since installing the Guardian 2D/3D. FYI Six flight with Guardian aboard was on March 22 nd. six whole days ago. http://www.rcgroups.com/forums/showp...&postcount=194 Charles |
Al posted video many pages back. All a video could show is an aircraft being flown in 3D that looks like just another 3D flight with the exception that the sticks are not being move nearly as much for minor course corrections, wing rock free harries,hands off hovers,knife edges etc. and unless they are semi to professionally done with pix. in a box showing transmitter and aircraft on the screen real time how can you gage the difference in pilot's ability sans Guardian and Guardians abilities?
In someways I hate to do this but best examples I am aware of are over ing the RTF Micro Forum. There everyone is raving about the AS3X system and how great it works and how they are able to fly a 3D Micro Beast in up to 28 MPH winds. I have seen the videos of the aircraft being parked in a 20 MPH or so wind ,being flown backward when throttle is reduced and forward when throttled back up. Now consider that most of these pilots leave there 4 foot and larger 3D planes in their vechiles and fly the Beast 3D in such winds as it handles it better. AS3X will not maintain a hands off hover or a knife edge or straight and level flight ,inverted flight etc. It does not have multi modes, can not be tweaked,or turned off. Perhaps go back and read this post again by someone with Beast V1 (no stabilization) Beast 3d with and larger 3D aircraft. He also is an active poster with videos in the ARFT Micros Beast Thread. http://www.rcgroups.com/forums/showp...&postcount=197 My son got to fly my Lill-Banchee for one 6 min. flight(he had someplace else he had to be) and he will likely post his comments when time is available. I hope he gets many more flights on it soon as he is moving out this way and infact 5 miles closer to my flying site than I am..\\A snip from his post #211 Quote:
3-31 Added Link to a feather weight Micro being flown in some rather stiff wind . Not Guardian 2D/3D equiped but rather AS3X and while very good for providing dampening does not provide near the flexibilities.
5:45 into video is where it backward flight is first shown. I have madet he comment several times that HH / E Flite is doing a great job of making the masses aware of flight stabalization . Microcs can now be flown in a much wider wind speed range ,flown by less experienced pilots etc. Just imagine what kind of conditions a decent pilot can fly a larger aircraft in with a Guardian onboard. Charles |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
