This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Oct 28, 2012, 12:48 AM
alros_100 is offline
Find More Posts by alros_100
Great White North
Joined Jun 2008
Originally Posted by MichaelT1960 View Post
But it did work! What would the difference be?
Michael
It worked because you were able to reverse the guardian contol surface correction direction. When you do remount it in the correct orientation, you will have to use the pots to reverse them again!
If all you are doing is flying sedate 2d mode without direction hold, it probably works ok. But if you do anything more complex with the guardian, suggest you mount it in the correct direction
Al
alros_100 is offline Find More Posts by alros_100
Old Oct 28, 2012, 09:57 AM
Spectremaster is offline
Find More Posts by Spectremaster
United States, IN, Crown Point
Joined Nov 2011
Originally Posted by WILLIAM M View Post
Hi guys
I just got my 2d3d, 3 days ago. I have seen that this unit can be changed from plane to plane.
From eagle tree [Our PC software also allows you to save and restore model profiles, making it easy to move the Guardian from plane to plane without reconfiguration!]
So I built this snug fitting holder for each plane to make it fit level. It will not slip out.
The holder will be screwed/ or glued in.
what problems do you all think I will encounter, moving it from plane to plane??
Bill N
I'm Just wondering how well the USB connection is. The micro USB connector on my daughters Kindle seamed to get loose after 8 months of plugging and unplugging for charging. I realize that this would not be as often but....
I have not liked all these small/micro connectors for a while on any device. They just seam so fragile.
I will be installing mine some time this winter in anticipation for next season, and hoping that I never have a problem with it. I will be ordering the short USB cable to mount to the 2D3D and running the other end to some type of USB panel mount (most likely home made) to make plugging into the laptop at the field easier.
Just say'n.......
Spectremaster is offline Find More Posts by Spectremaster
Last edited by Spectremaster; Oct 28, 2012 at 10:02 AM. Reason: Adding a statement
Old Oct 28, 2012, 12:23 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
Bill N
Aside from the hassle of moving all those plugs I should think the biggest problem would be setup. Different planes will likely need different direction and gain settings and possibly some advanced settings. They will probably need level and trim changes which can take several flights to get right. If you take care you may be able to zero your trims and tweak the level physically in each plane so resetting the Guardian can be avoided.
choochoo22 is online now Find More Posts by choochoo22
Old Oct 28, 2012, 02:06 PM
DavidN is online now
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Bill N
Possibly connector wear leading to loose connections if it is very frequent swapping. I maybe worrying over nothing
DavidN is online now Find More Posts by DavidN
Old Oct 28, 2012, 03:58 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
In addation to what others have posted , it is true that you can save a setup to your computer and then reload it latter however you still have to adjust the pots so that the saved and present setting match. Everything is not saved in a file and flashed to memory as some may think.
Charles
Old Oct 28, 2012, 04:32 PM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Too bad I don't have one yet. The next day or two might be the perfect time to really test it out.
Tom
RCPtero is offline Find More Posts by RCPtero
Old Oct 28, 2012, 06:29 PM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
Charles
Now I understand why the software shows 2 sets of pot images!
Galand is offline Find More Posts by Galand
Old Oct 28, 2012, 07:46 PM
WILLIAM M is offline
Find More Posts by WILLIAM M
GOTTA FLY STRIGHT UP
WILLIAM M's Avatar
United States, FL, Lake City
Joined Jun 2012
Originally Posted by Tatonka View Post
How snug is snug?....If it's too tight I think constant wear and tear of it being stuck in there and taken out again plus getting kicked around moving from plane to plane will take it's toll eventually.
Tatonka
If you look at the plastic case of the D2D3 if it is like mine it is a parallelogram.
I made the holder square. this is the thing that holds it in my holder and it don't shake out. however it slides out with little push.
I will be using the servo mounting double sticky sided foam between the plane and the mount to isolate vibrations. I have purchased extra servo connection cables from ET
I was hoping that I could use the adjustable gain knob on my tx to adjust from plane to plane.
I may have to reverse some servos and then put the push rod on the opposite side of the servo, and I may have to change some throw settings on the plane.
Or I can save plane programs on the comp. using the program I downloaded, and then reload the correct plane.
Guys I just can't put them on all my planes I have 45 flyable planes.
I can only fit 22 planes in my trailer. see pict.
Bill
WILLIAM M is offline Find More Posts by WILLIAM M
Old Oct 28, 2012, 07:59 PM
WILLIAM M's Avatar
Joined Jun 2012
Tom
Tom
I just bought one from this company.
http://hobbywireless.com/index.php?m...roducts_id=822
Bil
Old Oct 29, 2012, 03:57 AM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
I just bought a couple of these for my EDFs. One jet has a single elevator lead, but the other utilises a servo each side with a tx mix on an aux channel. I do have a spare JR Multibox - can I use the multibox with the Guardian?
Dan.
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Oct 29, 2012, 07:01 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Dan.
Dan,
This should be an interesting response. I don't use a JR Multibox but I would think it should work.
Bill
Prof100 is offline Find More Posts by Prof100
Old Oct 29, 2012, 08:33 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
Bill
t-turley is offline Find More Posts by t-turley
Old Oct 29, 2012, 09:03 AM
dodlestonian is offline
Find More Posts by dodlestonian
Chester UK
dodlestonian's Avatar
Joined Mar 2006
Why not sell some planes and use the money to buy the guardians?
(hands over eyes awaiting a reply on this one :-)
only joking
dodlestonian is offline Find More Posts by dodlestonian
Old Oct 29, 2012, 09:19 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Originally Posted by John.T View Post
The_RattleSnake:
First unit - That is very frustrating to hear. Every unit is hand tested to ensure that it's ready to operate before it is shipped. There have been reports of issues with the USB connector. We have since increased the reinforcement on that part, but still recommend that you do not apply any upward force when inserting or removing the cable from the header. A minority of USB cables have been reported to have an extra tight fit. The one we sell has been tested to fit reliably.
What I dont understand is why both the first units had almost no corrective input, the 2nd unit just started with the corrective input out of the blue.
then the nest time it wouldnt turn on.
Second unit - This might be a misconfiguration issue if it was not stabilizing as you expected, but if you want to contact us through our ticket system as well, referencing this post, please do so and I can try and walk you through the setup procedure or issue a replacement if the unit has a problem with it. The same goes for your first unit.
Your friend's (third) unit - Out of curiosity, did this "unexpected behavior" manifest shortly after power on? Remember that switching the Mode channel back and forth quickly within the first 15 seconds of flight will reset the zero attitude and trims of the Guardian. If this had happened shortly after takeoff, it could definitely explain the behavior your friend saw.
Was your friend able to reproduce this behavior? Feedback, whether positive or constructive is always welcome!
John T
This happened Mid Air but thats all I know really.
Ill have to ask for more info.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Oct 29, 2012, 10:39 AM
paul kelley is offline
Find More Posts by paul kelley
3d nut
paul kelley's Avatar
United States, CA, Stockton
In need of help
Hi I am in need of some help. I just bought a Eagle Tree 2d/3d gyro. I hook it up to a ar6115 according to the instruction. Here are some question. What do I do with the Mod plug, is the flap switch automatic assign per program to change Mods, if not how do I set it up to my flap switch? I have a DX8. The way it set up now, the gyro is aways on, with no way to turn it off are change Mods. WHAT AM I DOING WRONG? Oh ya with the way I have it set up the Ale, and elevator dose work, the rudder move just a little. It seem to me that I need a 7 channel RX for the Mod plug.
paul kelley is offline Find More Posts by paul kelley
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
