This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Oct 26, 2012, 02:04 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Berkie, sorry to hear about your slow support response! I want to understand what happened here - could you share your ticket #, either by posting here or through email? We should have a 1-3 day max turnaround on tickets, depending on the nature of the ticket (some need to go through engineering) and present workload. Our goal is certainly to get that response time lower.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Oct 26, 2012, 02:16 PM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Guardian Maiden Habu 2 EDF
This is the third successful maiden of a bird for me with a Guardian unit installed. Being older than dirt, I usually try and have the maiden flights accomplished by someone else before I attempt flight with or without a Guardian installed (depends upon speed, complexity, anticipated winds, etc.)
I did not want to change out the RCVR (six channel) so only had one spare channel and used it for 2D/OFF/3D with default gain setting as shown in manual. Verified correct operation, did level/trim set. I followed prof100's installation photos (thanks for sharing) and it worked perfectly.
Set 3D mode and the bird tracked perfectly (heading hold engaged) on a very rough grass strip. I experimented with 2D and OFF a couple of mistakes high. Practiced approaches knowing that the Guardian would handle the control surfaces leaving me with throttle, pretty much.
The only surprise was how quickly the bird jumped off the runway (holding full up because of rough grass strip), but relaxing the elevator resulted in a smooth climb out.
As with other posters, I've flown in quite strong winds (15-20 mph, with gusts) and just don't worry about it. It is fun to do a low pass down the runway and watch the Guardian manipulating the control surfaces to keep the bird level.
I now own six units and have gotten in the habit of installing one in a new bird if it has any degree of complexity or if I am unsure of finding another pilot for the maiden flight.
Michael
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Oct 26, 2012, 02:32 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Michael good to hear about your success with the guardian units
I currently have 3 units, 1 in a PZ T-28 that has been turned into a night flyer, and light fun jet, 3rd will be installed in a heavy fast FunJet
The last one will be set up as the others, but with less gain due to the higher speed envelope, this will be a very interesting maiden
For the price the guardian is cheap insurance
Have Fun
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Oct 26, 2012, 05:13 PM
jedorme is offline
Find More Posts by jedorme
Joined Jul 2009
I just finished installing my 3rd Guardian in a 2 year old Sig Kadet LT-25 taildragger that I stopped flying due to its squirrelly takeoff behavior. My 1st is in my testbed PZ T-28, which if it wasn't my most enjoyable A/C before, post Guardian it is just an absolute joy to fly in many conditions I wouldn't have thought possible before. A 2nd one was just installed in an Advance 25e which I have had to abort the last few times out to the field due to high winds. Didn't want to try the Advance without first testing it in more normal conditions, but had no hesitation in flying the T-28 these days when most guys more experienced & better than I were not flying.
Also just ordered 5 of the 5" USB connection cables from New Egg to put in my planes so I don't have to remove the units to change their settings. Finally, I have 2 more Guardian units on back order & await their arrival to put in a couple more of the planes I don't fly as often as I would like. These things are really very addictive!
Jed
jedorme is offline Find More Posts by jedorme
Old Oct 26, 2012, 06:30 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
Next time try this; Point the plane straight down the runway, wings level, at the climb angle you want. Then set 3D mode. Wiggle it around to confirm the surfaces are moving properly. Put the plane down and hit the throttle without touching anything else. Guardian will track it down the runway, rotate, and fly the climb path and angle where you pointed it. When you get to pattern altitude, take over simply by flying it. As soon as you move the aileron or elevator you are back in charge. It's fun and amazing to watch a takeoff or hand-launch flown completely hands-off.
choochoo22 is online now Find More Posts by choochoo22
Old Oct 26, 2012, 08:21 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Michael
Michael,
I find your experience a delight to read. The Guardian sure does what it promises.
Bill
Prof100 is offline Find More Posts by Prof100
Old Oct 27, 2012, 04:23 AM
Flyindude is offline
Find More Posts by Flyindude
Dirtnap Certified
Flyindude's Avatar
Joined Aug 2012
A very blustery day in Melbourne today. What a pleasure to fly in 2d and 3d today with this etg. Even the President was impressed. Reckon I sold at least 4 more. Cheers
Flyindude is offline Find More Posts by Flyindude
Old Oct 27, 2012, 05:06 AM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Thanks Billpa. I have received a reply now
Kev
Berkie is offline Find More Posts by Berkie
Old Oct 27, 2012, 11:14 AM
MichaelT1960 is offline
Find More Posts by MichaelT1960
Mooresville, NC
Joined Dec 2004
Test flew my first Guardian 2d/3d yesterday.....
It seems to be working well and may need a few more tweaks to get it even better...
However I noticed later on last night that I mounted it backwards (the front of the airplane on the case is towards the rear of my plane!
Would this make any difference how the plane flies....do I need to reverse it??
Update: According to Eagle Tree they said that it would still work as long as all the control surfaces are checked and working properly when the airplane is moved around. That is what I did before flight.....made sure that when the model was moved by myself the control surfaces had a negative feedback to correct the movement.
Thank you,
Michael
MichaelT1960 is offline Find More Posts by MichaelT1960
Old Oct 27, 2012, 04:22 PM
al_voisine is offline
Find More Posts by al_voisine
Canada, NB, Drummond
Joined Mar 2010
Good catch!
You will have to turn it around or it will not work properly.
Cheaper to do it now.
al_voisine is offline Find More Posts by al_voisine
Old Oct 27, 2012, 05:00 PM
Mooresville, NC
Joined Dec 2004
Will not work properly?
Originally Posted by al_voisine View Post
Good catch!
But it did work! What would the difference be?
Michael
Old Oct 27, 2012, 07:50 PM
WILLIAM M is offline
Find More Posts by WILLIAM M
GOTTA FLY STRIGHT UP
WILLIAM M's Avatar
United States, FL, Lake City
Joined Jun 2012
Hi guys
I just got my 2d3d, 3 days ago. I have seen that this unit can be changed from plane to plane.
From eagle tree [Our PC software also allows you to save and restore model profiles, making it easy to move the Guardian from plane to plane without reconfiguration!]
So I built this snug fitting holder for each plane to make it fit level. It will not slip out.
The holder will be screwed/ or glued in.
what problems do you all think I will encounter, moving it from plane to plane??
Bill N
WILLIAM M is offline Find More Posts by WILLIAM M
Old Oct 27, 2012, 09:04 PM
Tatonka is offline
Find More Posts by Tatonka
Buffalos have wings
Tatonka's Avatar
Vancouver Washington
Joined Nov 2007
How snug is snug?....If it's too tight I think constant wear and tear of it being stuck in there and taken out again plus getting kicked around moving from plane to plane will take it's toll eventually.
Tatonka is offline Find More Posts by Tatonka
Old Oct 27, 2012, 09:21 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Nice looking mount. I think you will still need to use the servo mounting double sticky sided foam between the plane & your mount to isolate vibrations.
We used to move receivers from plane to plane; but now that seems a hassle with the cheaper electronics.
DavidN is offline Find More Posts by DavidN
Old Oct 27, 2012, 10:04 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
Yeah highly recommend that you use double sided tape to reduce vibration
The housing may actually amplify vibration
FCA
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
