This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Oct 20, 2012, 07:30 AM
schummie is offline
Find More Posts by schummie
Joined Feb 2009
Al,
Thank you. I now understand what eagletree support tried to explain to me.
However I did not change trims at any point. I'm in the installing fase. However, it is possible that I turned the gain on the rudder and did not reset the trims. There also may be a mix working somewhere. Thats why tonight I start from scratch with a new model in the transmitter and a factory reset on the Eagle tree.
If I'm out of trouble, I'll let you know.
regards, Eric Schumacher
schummie is offline Find More Posts by schummie
Old Oct 20, 2012, 08:00 AM
Tim Green is offline
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by schummie View Post
Al,
Please remember that resetting the trims only works during the first 15 seconds after the Guardian is powered up.
Tim Green is offline Find More Posts by Tim Green
Old Oct 20, 2012, 08:14 AM
aero1960 is offline
Find More Posts by aero1960
Joined Sep 2010
Will Guardian work with ESC/motor?
billpa:
I wanted to do a VTO which means the Guardian would have to be hooked up to the 2 Esc/motors in the 3D mode. Is this possible?
In the past, I have tried receiver, different gyros,Esc,motor hookup and always ended up with motor/s sputtering, probably not syncing and causing a crash.
aero1960 is offline Find More Posts by aero1960
Old Oct 20, 2012, 10:52 AM
DavidN is online now
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Eric I think there are 2 parts to the instructions:-
1) When adjusting the transmitter trims, the guardian should be off
2) When toggling to transfer this to the Guardian, start with the switch in the OFF position.
Your info didn't show you live in Nederlands, isn't the internet cool.
DavidN is online now Find More Posts by DavidN
Old Oct 20, 2012, 11:26 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Any rumors as to when these will be back in stock? I've had one on order since August 31st.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Oct 20, 2012, 11:37 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Unless the software has been changed again that would be
Start with Switch in either 2D or 3D , would it not?.
Not being able to tresit trims with a 2 position switch whic is used for either 2D and Off or 3D and Off is one of the points some have complaned about.
Set Level and Reset Trims both require going from nonimal 1.10 to 1.90 based on 1.50 being cetered and yes I know Futuba and some other in fact use 1.520 as cetered.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Oct 20, 2012, 12:04 PM
schummie is offline
Joined Feb 2009
Yes, it is DavidN.
When toggling I start with the three position switch up, or down. This is in the manual. However it's worth a try. I found out that when toggling once from 3D back and forth, and then after the 15 seconds to 2D, elevator direction is good. When switching back then again to 3D de direction is again reversed.
Further, when performing the reset level flight and trims procedure, my servo's don't twitch. However I only have the rudder and elevator servo connected. The elevator servo slowly moves up, and then back to centre.
Which takes me to the following: could the airlon and aux servos not being connected in this testing fase have anything to do with it?
I also get the impression that I'm not going into 3D mode at all. In both cases when yawing the plane from left too right, the rudder moves counterwise shortly and then returns to the center position.
Old Oct 20, 2012, 02:57 PM
Southern Pride
3D mode LED should be solid on.
I guess you can not see the LED then ,that is why I wish it was on a remot lead so that it could be positioned thru the side of the fuse.
To check 3D switch to Off point nose up on a 45n degree angle,flip to 3D control surfaces should stay netural, now lower the nose and elevator should go to up. If you roll fuse to right then you should get aile. correction to the left , left up right down.
Charles
Old Oct 20, 2012, 10:13 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Originally Posted by Silverexpress View Post
When it comes to fast heavy funjets I seem to find more examples of pilots using some type of launcher on youtube. The exceptions being the super powerful that can be hand launched vertically. The launchers tend to be bungee types.
For my own FUnjet, I took the route of Jurgen Heilig, and his pursuit of a lightweight and highly manueverable Funjet. Here is a video of him flying his vectored Funjet at night.
http://www.youtube.com/watch?v=5j98OCyrZqE
His builds dot the internet if you do a search for "Lightweight Funjet".
Then there are the examples of vector and gyros by other pilots...
http://www.youtube.com/watch?v=nak9WWjy2Zc
If you go lightweight you should experience the same performance (vector unit though has been out of production since 2009 - but you might score one used). With the Guardian on board it will be light years ahead of any single axis gyro, and hand launching will be no issue. Just something to consider for your next build.
Hi SilverExpress I took your advise, I glued the mount back on, no way was it gonna be able to handle the torque from my MEGA setup, so I pulled everything and installed a low power setup
Here she is in high winds. Had a blast
Check out this video on YouTube:<br/><br/>
10 20 12 Light FunJet Ultra (1 min 43 sec)
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Oct 21, 2012, 12:22 AM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Check out this video on YouTube:<br/><br/>http://youtu.be/A-TygvJC6Bg
FCA
Smmooooth!
Silverexpress is offline Find More Posts by Silverexpress
Old Oct 21, 2012, 05:28 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Hi folks,
I had a blast today and last Sunday with the Guardian 2d/3d installed on the EPO HK Yak54. I was doing hands-off prop-hanging. The FB's were quite impressed with the Guardian. Once the throttle has been adjusted to hold the plane up, it just hung there, correcting for the wind and torque by itself.
The only problem I faced was with the HK Nanotech batteries. Oh, they worked fine and have good power and retain the voltage well. A little too well, that's the problem. It dropped off pretty fast at the end of the discharge curve and the plane did not have enough power to get back to the landing field. I had a hard landing on the tarmac and just missed going into a monsoon drain. The nose broke off again. This has happened quite a few times already, and I consider it a weak spot in this otherwise good flying plane. With a heavy motor TGY SK3 4250 and a 3300mAH 35-70C 4S in the nose, the small area of foam (minus the canopy) is insufficient to take the load of a hard landing. Btw, I have replaced the stock soft wire landing gear with a set of nice C.F. landing gear.
I don't normally fly 3D as I like warbirds. However, this Guardian has enabled me to prop-hang with the best of them. I am going to get another one for a 26cc Extra 260 I am putting together.
chewy
chewytm is offline Find More Posts by chewytm
Old Oct 21, 2012, 08:52 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Can someone tell me the length of the Guardian wire harness? I couldn't find the length in the manual, they look to be 3" but I want to be for sure. I have one on the way should be here this week, I'm presetting up the location in my plane now and need to know the length of the harness.
BadLemon is offline Find More Posts by BadLemon
Old Oct 21, 2012, 10:31 AM
simages is offline
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
Just under 5", plug end to plug end one of mine measure 4 3/4".
simages is offline Find More Posts by simages
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Oct 21, 2012, 12:11 PM
Southern Pride
3-7/8" wire length and the black connectots are standard servo ends.
There was a request for longer leafds and I believe that ET said they would have some made up but have not heard any more on this. You can extend them using stamdard servo extensions and as 5 of them are single lead (signal only) modifued extensions would not be a weight issue with the + and - leads removed.
Charles
Old Oct 21, 2012, 01:24 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Thanks guys That will help me out I shouldn't have to extend the wires I'm putting the guardian in a 60mm Alfa Ta-183 Huckebein jet. I lost my first Ta-183 after a stall while in to steep of a turn. The Ta-183 also had a tendency to loop on take off so I'm hoping the Guardian will prevent this from happening with my new Ta-183. I also have a 90mm Ta-183 kit I want to use the Guardian in as well.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
