But when training you will fly 2D anyway and the GAIN channel pot lets you "challenge" the student progressively. Therefore I wanted to assign the free channel to GAIN but then I lose the neat switch-flicking trim reset function. BTW, I found that setting the initial trim calibration with the PC was quite challenging (in the end I used a spirit level) to achieve no control surface movement between Guardian ON and OFF. |
United States, CA, Santa Clara
Joined Mar 2011
Joined Jul 2009
But for the T-28, taking off with it turned off is certainly possible. For a tail dragger, I haven't really thought out the issue of rotation, as maybe once the tail is up & the Guardian is happy with the level flight position, it will just fly off with some added up elevator. Has that been the experience of those using 3D HH when taking off a tail dragger with the Guardian on? Jed |
Joined Mar 2011
I can see, however, where someone with a larger, more scale plane taking off asphalt may want a longer roll with the tail up for aesthetic reasons or if the plane needs to gain speed. In that case it seems like 2D HH would work better if you can get the level attitude set right, then a gentle pull on the stick for lift-off. |
To help with the take-off you can program some up elevator into a mix on a switch. This will tell the Guardian to maintain a climb angle for take-off. The mix can also be used in flight to either climb or to maintain altitude when the throttle is reduced. Test it at altitude to check how much up elevator to program into the mix. When the amount is correct the plane will lift off by itself and look very scale. I program three switches where each adds about 5% up elevator. Then I can decide how much I want by using one or more switches. Just before the take-off run move the aileron/elevator stick to set the Guardian heading hold. That will help keep the take-off straight. You can still use the rudder to keep it straight. Steve |
Joined Mar 2011
This is mode dependent. In 3D Direct, the up elevator will be telling the Guardian to maintain a mild rate of loop! It will feed in as much elevator as it needs to achieve that rate, most likely resulting in a stall if you don't correct it first.
Normaly Rudder is or can be set to full servo range as in full CW ,full CCW and ofcourse cetered. These are the same outputs required to reset Trims on Guardian 2D/3D so........... Seems one could disconnect Rudder signal from Guardian to receiver and plug Guardian Mod. lead into Receiver make Trim Reset and then switch leads back. Yes it is a pain bvut should work I believe. It seems one could also use a spare receiver and receiver battery and connect this receiver to the Guardian 2D/3D Mode channel and along the same lines a servo tester should work also. Perhaps Bill or John will comment on these ideas. Charles |
Also, when in heading hold turn off the Guardian when retrieving your plane or stir the sticks if you change heading . |
Joined Mar 2011
To elaborate; You are getting ready to fly. You have the plane in your left hand and the tx in your right hand, preferably on a neck strap. As part of your pre-flight you turn on 3D mode. As you walk to your launch point, Guardian is moving the surfaces trying to maintain the attitude that was locked in when you turned 3D on. This is most likely not a useful attitude as you were carrying the plane, possibly straight up, down, or sideways. When you are at your launch point, you are ready to set the plane down for a ROG or toss the plane for a hand launch. As a final pre-flight step, you point the plane in the direction and attitude you want for climb out and "stir the stick". Any movement of the aileron or elevator will reset the locked-in attitude in G to the current position. Now you are ready for takeoff. On the ground or by hand, all you need do is apply throttle and G will fly the plane where you had it pointed. You could just wait until you have the plane in climb-out attitude before activating 3D. I find it more convenient, however, to set all my switches ahead of time. Since I'm holding the plane in my left hand, it's easier to reach the right stick with my right hand than the mode switch on the left side of the tx. In any case your pre-flight after setting the climb-out attitude should include wiggling the plane around and observing that G is moving your surfaces properly. You don't want to hit full throttle for launch and discover, for instance, that your gain was all the way down and G isn't flying the plane ![]() As Prof suggested, it's generally not good to carry the plane around much before or after flight with G active. It will be trying to "fly" the plane and will be moving the surfaces, probably to maximum. It could overdrive a servo doing this. I haven't found this to be a problem on any of my planes so I have become somewhat careless on this point. If you are careful to verify the limits when installing G and, if necessary, set the G travel limits with a PC (not the tx travel limits) it should never be a problem. Hope this helped clarify things. |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
