This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Oct 06, 2012, 08:17 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by Galand View Post
Not only bring a laptop, you also have to get the unit out to hook up the USB cable. Depending on where it is mounted, not fun.
If I have it right when doing this, the Guardian has to sit dead level with the flight attitude. If not the control surfaces will move between Guardian On and Guardian Off.
So practically speaking, this stabilizer locks up two receiver channels one channel/switch dedicated to MODE and one channel/pot dedicated to GAIN.
Thanks for the clarifications. Prof were you the SkySurfer guru?
Last first, yes, I posted a lot on the Skysurfer thread and still follow the thread but everyone knows how to mod them now. All the necessay mods are common knowledge and I let others pass on the info.
With the Guardian you should consider ditching the remote gain slider or pot. It's nice but not necessary. Which radio do you have? You can use any switch for 2D and 3D and assign another as an on-off switch. You just have to be creative with programming.
Prof100 is online now Find More Posts by Prof100
Old Oct 06, 2012, 08:43 PM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
I use Flysky 9Ch with Er9x firmware, so I can program any switch/mix I can think of.
The issue came up because I had only a 6Ch spare receiver.
I will order some 8Ch Rx's, they are only $13.00 or so.
I build four Skysurfers and I learned a lot from that thread and from you. Destroyed two and am still flying the other two, both with flaps and an FY-20A stabilizer.They are great models.
Galand is offline Find More Posts by Galand
Old Oct 06, 2012, 08:46 PM
Prof100's Avatar
Joined Jul 2007
I will PM you, we are getting off topic here.
Old Oct 06, 2012, 10:57 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
I was trying to adjust the pots in the depths of a small plane. It made me wish for better visibility of the mid position on the case marking( ?RED? line), and the same for the mark on the pot screw(perhaps BLACK line). The plastic film case was pressed askew by wiring so the dots were hard to see.
DavidN is offline Find More Posts by DavidN
Old Oct 07, 2012, 03:07 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I center the Pots and then take a tooth pick ,transfere a bit of red paint to its' tip and mark the Pot slot that is lined up with the 12 O clock (center) position.
I agree that they are difficult enought even when they are out in the open and when buried in a Fuse. they would be a real pain. Guess one needs to give a lot of thought to where they get mounted.
Charles
Old Oct 07, 2012, 04:18 PM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
Had one of my Guardian's die on me today, didnt even get up in the air. Walking down to the strip and could smell burning popped the canopy off and both rudder servo and guardian were smoking, not a clue whats happened
Simon2504 is offline Find More Posts by Simon2504
Old Oct 07, 2012, 04:22 PM
Prof100's Avatar
Joined Jul 2007
That's a new failure mode we have never heard before. Did you shorten the wires at all?
Old Oct 07, 2012, 08:06 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Probably too late to tell - did you set the Guardian to correctly operate your servo?
Silverexpress is offline Find More Posts by Silverexpress
Old Oct 08, 2012, 08:07 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
I'm starting to get pretty comftorable flying my plane, but i notice in the wind the guardian gives me an aileron wobble when the wind hits us. it's just a little 48" telink foamie. is this normal looking or should i be tuning for better? these were half way up on the gain dial,,,,, when i'd move it up higher it seemed worse. The gyro is burried in the fuse, but i think last i touched em was half way on all of the dials.....
sorrento proximity (8 min 48 sec)
sorrento pad & gap (3 min 46 sec)
Kloner is offline Find More Posts by Kloner
Old Oct 08, 2012, 08:10 AM
Southern Pride
Had you checked / verified that non of the servos could reach stalled state while Guardian was one in either 2D or 3D mode?
Was Guardian in 2D or 3D mode while aircarft was being carried ?
My SOP with any gyro is to either have it turned off while carrying (Guardian) or switched to Rate Mode ,Heli tail or FBL systems.
Charles
Old Oct 08, 2012, 08:24 AM
Prof100's Avatar
Joined Jul 2007
Charles
Charles,
Right on. Carrying a plane with 2D or 3d on can be a problem if the orientation is different than the last time sticks were centered. It could stall a servos if the throws are excessive.
Old Oct 08, 2012, 11:09 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
I had 2 very nice and stable flights with my Guardian 2/3D this past Sunday. 2D mode works great for recovery and landing. 3D mode with HH works, but I think Imay have to reduce the window a bit as it seems to be fighting my sticks. I will also have to reset trims for the next week end.
The last landing of the day, I tested landing without any power to the motor for the HK Yak. The plane was stable all the way until it stalled due to excessively slow speed. The stall was straight ahead - the wings were level but it was a hard landing. Anyway, the nose ahead of the wing broke off (not for the 1st time). I have had to repair similar breaks a number of times. I think I will add a few flat strips of CF to bridge the weak point.
Anyway, very nice gadget.
chewy
chewytm is offline Find More Posts by chewytm
Old Oct 08, 2012, 11:19 AM
DavidN is offline
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
mode & gain on 5 channels
Flew my old Park Zone Spitfire, the older one with the white foam & peeling covering; but a brushless conversion. After adjusting down the throws it flies nicely. I got thinking that although it only has a 5 channel Rx I am not using the rudder channel, so perhaps I could have both MODE & GAIN if I move it to my DX8. Any one done this
Old Oct 08, 2012, 02:12 PM
John.T is offline
Find More Posts by John.T
Guardian Stabilizer
Joined Feb 2012
Yikes. This is a new one. It sounds like either a wire / connector shorted or your servo has shorted internally. Can you confirm that there aren't any shorted wires in your setup? If you aren't able to find any obvious causes, could you open a ticket here and reference this post?
http://ticket.eagletreesystems.com
Thanks!
John
John.T is offline Find More Posts by John.T
Old Oct 08, 2012, 02:58 PM
Joined Dec 2011
I have not had chance to investigate any further yet. I checked all wires at the site, no damage to be seen, it was on 3D direct rate mode with servo speed set to 150ms ive used a lot of these servo's with no problems (http://www.hobbyking.com/hobbyking/s...sec_11_5g.html)
Its just a worry that if you do have a servo fail that it will take the Guardian with it!!!!! Ive got 4 of them so far in different planes. I didnt have another servo the same size with me so need to get one tomorrow and have another look at it all
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
