This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Oct 04, 2012, 08:04 AM
Flyindude is offline
Find More Posts by Flyindude
Dirtnap Certified
Flyindude's Avatar
Joined Aug 2012
@abhay
What about all the other configuration settings? I wouldn't be starting with all gains on 100% either. Most here seem to be running 30-50% on these. I would be working up rather than working down individual gains. What happens at 30% pot gains? If the plane starts to roll that indicates that your level set may not have been done correctly. I would check that carefully. Maybe your switch config between 2D and 3D isn't working as you think.
Flyindude is offline Find More Posts by Flyindude
Old Oct 04, 2012, 12:14 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
First off set the gains (Pots) to approx. 10 or 2 O clock as a starting point and even that may be to much if remote gain is turned up past 50%.
FYI All gyros are subject to vibrations ,some more so than others. Heli pilots are more versed on anti-vibration measures than the average fixed wing flyer. I have a fair amount of heli experience and tail gyros were often a problem vibration wise and now that I have gone Fly Bar Less ( 3 axis) gyros vibrations are even a bigger no no plus with a belt tail drive static electricity is another issue.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Oct 04, 2012, 05:58 PM
WILLIAM M is offline
Find More Posts by WILLIAM M
GOTTA FLY STRIGHT UP
WILLIAM M's Avatar
United States, FL, Lake City
Joined Jun 2012
PROF100
Originally Posted by Prof100 View Post
Hobbyking sells the Eagletree Guardian. I know, I bought two, and they are legitimate. I don't know where he gets free shipping but maybe he will tell us. I actually bought them when they first hit Hobbyking and sold for $50 each.
Sorry about the free shipping, I was thinking of hobbypartz.com that ships free on orders over $50
Bill
WILLIAM M is offline Find More Posts by WILLIAM M
Old Oct 04, 2012, 07:13 PM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
Originally Posted by flightdeck View Post
Probably has a voltage regulator on the board.Most do.Its when you over volt a regulator that it doesn't like and goes "poof".Same symptom of putting a 3s lipo to power a Turnigy 9X transmitter, it burns out the regulator
Turnigy 9x: If you reverse the polarity, yes it will smoke!
Galand is offline Find More Posts by Galand
Old Oct 05, 2012, 11:29 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Hi, I just finished setting up one of the 2 G2/3D that I bought quite some time ago on my pretty beat-up HK Yak54. Will probably fly it this Sunday.
chewy
chewytm is offline Find More Posts by chewytm
Old Oct 05, 2012, 08:41 PM
jsfrench is offline
Find More Posts by jsfrench
jsfrench's Avatar
United States, WA, Olympia
Joined Nov 2002
as advertised
Thanks to all the early adopters for posting.
The user manual leaves something to desired.
When I was in the Army, the first instruction in our test equipment manuals was:
"Turn the On-Off switch to the On position"
I followed everydayflyer's KISS advice on setting up and using.
My Bug has elevons and rudder and I used the mixing in the Guardian.
I set the individual gains so that the surfaces just deflected a little bit.
The master gain was put on a knob and the 2D - 3d on a 3 way switch.
On the ground, I propped up the Bug with pitch and roll level, and set the trims.
When I switched to 2D in the air, it flew straight and level with no trim required.
I got a chance to fly in an almost 90 deg crosswind today and it worked great.
John
jsfrench is offline Find More Posts by jsfrench
Old Oct 05, 2012, 08:50 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
John
John,
Great news. Remember to reset the trims if you adjust radio trims.
Bill
Prof100 is online now Find More Posts by Prof100
Old Oct 06, 2012, 03:05 AM
Dirtnap Certified
Flyindude's Avatar
Joined Aug 2012
Love that bug, where do you get such a thing/insect? More pics please!
Old Oct 06, 2012, 08:46 AM
Prof100's Avatar
Joined Jul 2007
Exceed RC FA18 now has a Guardian
I have a great little 70 mm EDF that's designed by ExceedRC and was sold by Nitroplanes. It's great flyer except its tendency to pitch up when being slowed down. It's kind of a flying challenge to land because you have gradually push down on the elevator to get the darn thing to land without stalling. So, I installed a Guardian and either 2D wing leveling or 3D with heading hold should correct the problem . This weekend is a bit cold, rainy and blustery to test fly it, but I will when it clears up and report back with video.
BELOW IS THE "BEFORE" GUARDIAN INSTALLATION VIDEO where it balloons on landing slow down or simply climbs when throttled back.
FA18 with Takeoff and 2 ballooning landings._10-1-12 (1 min 48 sec)
Old Oct 06, 2012, 04:07 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
Normal airframe. I am using a 6 channel receiver. Ch6 is for flaps and Ch5 will be GAIN. I have no free channel for the MOD switch so I have set 2D as default.
How do I reset trims after power-up since there is no MOD switch to toggle?
Old Oct 06, 2012, 04:16 PM
Prof100's Avatar
Joined Jul 2007
Connect it to your computer and click the reset trim button in the program. Done.
Old Oct 06, 2012, 05:11 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
I did that, but I was hoping to be able to do that in the field since it seems to be recommended to reset Guardian trims after doing radio trimming.
Old Oct 06, 2012, 05:19 PM
Prof100's Avatar
Joined Jul 2007
No mode switch no reset of trims. Bring your laptop to the field.
Old Oct 06, 2012, 07:38 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
A friend of mine decided to buy a grim reaper.
He hasn't flown for quite a few years, so the reaper turned out to be a handful
It was not exactly easy for me to fly.
He flew it a couple of time, and took my advice to get the 2d/3d.
I just maidened it with stabilization, and trimmed it out.
"wow"... What a difference.
That wing is so predictable, and easy to fly now, that he will have no problems flying it around, even with limited stick time.
I was glad to get a little stick time with the 2d/3d. It's quite impressive.
m_beeson is offline Find More Posts by m_beeson
Old Oct 06, 2012, 07:49 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
Not only bring a laptop, you also have to get the unit out to hook up the USB cable. Depending on where it is mounted, not fun.
If I have it right when doing this, the Guardian has to sit dead level with the flight attitude. If not the control surfaces will move between Guardian On and Guardian Off.
So practically speaking, this stabilizer locks up two receiver channels one channel/switch dedicated to MODE and one channel/pot dedicated to GAIN.
Thanks for the clarifications. Prof were you the SkySurfer guru?
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
