This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Sep 30, 2012, 05:36 AM
Hansschroeder is offline
Find More Posts by Hansschroeder
Joined Sep 2012
Rateoneturn thank you very much. Really appreciate your help. How stupid can I be!!!
But easy to mix up micro with mini! Hans
Hansschroeder is offline Find More Posts by Hansschroeder
Old Sep 30, 2012, 05:45 AM
Joined Sep 2012
A BIG THANK YOU to all you guys who tried to help me. I have the WRONG CABLE
I bought the Mini USB-B and not the MICRO USB-B !!! Hans
Old Sep 30, 2012, 06:49 AM
rateoneturn is offline
Find More Posts by rateoneturn
Joined Nov 2010
hans,
even easier is having a micro-b but not looking quite close enough to make sure it's oriented in the proper direction (up or down) before plugging it in.
no need to ask... it's not one of my prouder moments.
have fun,
rateoneturn
rateoneturn is offline Find More Posts by rateoneturn
Old Sep 30, 2012, 05:01 PM
boiko is online now
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Originally Posted by Hansschroeder View Post
I am an old RC'er. Just got the Eagle Tree Guardian 2D/3D installed in my Extra 300 EXP. The system moves the control surfaces o.k., but I want to fine tune on my computer. Bought a Radio Shack cable USB-A to Mini USB-B usable for mobile phones and cameras. Downloaded the Data Recorder. When I click the DR icon it asks to connect the USB cable. I did that very carefully at the Guardian end, but no connection was made and no 3 blinks at the Guardian LED. Does anyone had a similar experience? Is the USB plug at the Guardian defective? Appreciate greatly any comments. Hans
In the picture link below, Mini-B cable is on the left and the Micro-B cable is on the right. Given that they are totally different in size..is it correct to assume that you were never able to connect the USB cable on the Guardian side?
Was just a bit confused by your statement... "When I click the DR icon it asks to connect the USB cable. I did that very carefully at the Guardian end, but no connection was made and no 3 blinks at the Guardian LED..."
It almost seems from your statement, that you were able to connect to the Guardian with the cable you had.
Sorry if I have it wrong.
-mike-
http://blackberryrocks.com/wp-conten...-connector.jpg
boiko is online now Find More Posts by boiko
Old Oct 01, 2012, 08:53 AM
ldsanders2807 is offline
Find More Posts by ldsanders2807
ldsanders2807's Avatar
Urbandale, IA
Joined Mar 2009
Has anyone set up the Guardian to use with elevons? The Guardian moves the elevons as expected. I have the gain control connected to the VR2 knob on my Eclipse 7 transmitter. And, it does control the sensitivity as expected from no control to very responsive. However, when you change the gain, it also changes the trim on the elevons. This is in 2D or 3D mode. Is that an expected result?
ldsanders2807 is offline Find More Posts by ldsanders2807
Old Oct 01, 2012, 10:51 AM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
How do you know the trim is changing?
I have a Guardian on two elevon planes. It works great. I have seen no such behavior where changing gain using the gain pot changes trim. However, I do not use a Master Gain Control.
Prof100 is online now Find More Posts by Prof100
Old Oct 01, 2012, 12:48 PM
wazoo22 is offline
Find More Posts by wazoo22
wazoo22's Avatar
France, Bourgogne, Nevers
Joined Feb 2012
Originally Posted by BJM-Maxx View Post
2D mode is more complicated and I have not played with it as much. I want to confirm a couple of things.
I think you are you saying you have define safe servo limits?
Not sure what you mean.I f I understand correctly, servo limits set in the tx won't prevent the guardian from running to the stops, so there is no way to limit the travel in the tx- only in the pulse width limits.
When your accident occurred, are you saying the Guardian made an unexpected course change that put you in a tree? The reason I ask is I remember learning to fly and even if the Guardian had been available I know I could have hit a tree without knowing why.
What got me was the radical difference in elevator travel I wrote about above. Not a good thing to cope with on final, over a line of trees.That said, --yes, I certainly have been known to prang it for many stupid reasons, but the elevator travel ought to be the same- not change wildly when the mode switch is flipped.[/
B]
Spent a couple hours today on the problem-- no luck yet. Thanks for the efforts.
wazoo22 is offline Find More Posts by wazoo22
Old Oct 01, 2012, 01:04 PM
Urbandale, IA
Joined Mar 2009
Trim probably was not the correct term to use. When I adjust the master gain control, the left elevon moves up or down depending on the knob direction. The right elevon does not.
Old Oct 01, 2012, 01:22 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
ldsanders2807
You do have Elevon mixing turned off in the transmitter and turned on (enabled) in the Guardian ,correct?
Charles
Old Oct 01, 2012, 02:20 PM
BJM-Maxx is offline
Find More Posts by BJM-Maxx
BJM-Maxx's Avatar
Joined Sep 2007
Setting the servo limits in teh EagleTree PC software prevents servo damage, it does not limit the range of pulsewidths that it receives from your Tx.
For the elevator movement, greater movement in 2D is not necesarily an issue, but try 3D with the heading hold off and with direct rate mode off. That should look very similar to off mode. If it does not look similar then you may have a problem.
BJM-Maxx is offline Find More Posts by BJM-Maxx
Old Oct 01, 2012, 02:29 PM
Urbandale, IA
Joined Mar 2009
Originally Posted by everydayflyer View Post
ldsanders2807
Charles
Yes, Elevon mixing off in transmitter and on in the Guardian. The transmitter is controlling the elevons thru the Guardian correctly.
Old Oct 01, 2012, 03:21 PM
RRutledge is offline
Find More Posts by RRutledge
R Rutledge
Joined Sep 2006
Guardin used with DX8
I would like to know if any one can tell me how to program my spektrum DX8 radio using a AR8000 DSMX Rec. for the Guardin 2D/3D I am using it on a plane with four servos duel ail with rudder and elevator i'am sure it is in the thread somewhere but I can't find it.
RRutledge
RRutledge is offline Find More Posts by RRutledge
Old Oct 01, 2012, 07:09 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
RRutledge
Just plug your second Ail channel into the Guardian aux channel. Complete the setup per the manual.
Options include:
  • Plug the G mod into your flap channel for 2D-Off-3D
  • Plug the G gain channel into your aux2(?), the channel with the knob for airborne gain control
choochoo22 is online now Find More Posts by choochoo22
Old Oct 01, 2012, 10:00 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Alternatively plug Gyro mode into Aux2 and the Gyro gain into Aux3 (the Knob) That way both controls are together on the top right hand side of the Tx.
A nice addition is to set up a mix that forces 2D mode and assign it to the Gear switch (1). See post 1650.
That way you have a panic switch in the very top right hand corner where it is impossible to miss and easy to engage.
You can still use the Mix or Flap or Flight Mode switches for gear if you need to.
This configuration groups all the gyro controls in the one place on a DX8.
Options include:
jj604 is online now Find More Posts by jj604
Old Oct 02, 2012, 05:05 AM
Southern Pride
Links to some Transmitter programing suggestions.
http://www.rcgroups.com/forums/showp...postcount=1651
Perhaps he will respond or you could PM him.
I posted lnks here to some Trans. programming and offered to add addational proven to work ones but no one has responded as yet.
Charles
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
