This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Sep 28, 2012, 12:29 AM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Originally Posted by alros_100 View Post
Ben,
You are describing the behaviour of centre stick stabilization perfectly.
Some history: the guardian add on version has no 3D rate mode. Only 2D and off. So you could not do loops and full rolls in 2D mode as there was a max angle being enforced (just like 2d mode with stand alone now). So your options were to fly sedate 2d, then turn off to do aerobatics. Some of us requested a feature that would allow rolls amd loops, but if you got in trouble, you would centre stick, and it would immediately level the plane. So centre stick stabilization was born. The box size became how much you could move the stick before 2d turned off, but as you point out there is somewhat of an abrupt change once you leave the box since inside the box you have to hold the stick deflected to keep a bank angle, but as soon as you leave the box, you are no longer in 2d mode so if you held the stick defelected the plane would roll (or loop) . The challenge occurs when you are trying to keep a certain high bank angle - but to do this you need to enter and leave the box repeatidly. This was problematic for me as it felt un-natural - but it does allow you to roll and loop then let go of stick and perfectly stabilize
So in a long winded manner, i think your observations are spot on and are the trade off with using centre stick mode. In the end, i adjusted box size between large and small until i found a level that flew most natural to me.
With guardian standalone - i just love the 3d mode. It allows you to do what ever you want, and i fllick switch to 2d mode to save me if i get in trouble. So i am not using centre stick mode any more
Al
You are right on!
Steve
Floater73 is offline Find More Posts by Floater73
Old Sep 28, 2012, 01:25 PM
harrye is offline
Find More Posts by harrye
United States, CA, Pleasanton
Joined Apr 2002
Sport Flying Set UP Question
Guys,
I want to start using my Guardian on a 4 channel electric sport flyer.
I will be using the plane to practice basic (not real 3D) aerobatic maneuvers (split-s, knife edge, inverted flight, 4 point rolls, etc).
My Tx will be set up with the recommended 3-pos 2D / 3D switch and a master gain control.
After reading the manual several times please tell me if this makes sense:
When "just flying around" in gusty conditions I will use the 2D mode with heading hold enabled.
When I am flying aerobatics I will switch to 3D mode with "direct rate" enabled.
The manual seems to suggest that using the 3D mode is preferable to using the 2D mode and enabling the "center stick stabilize mode".
Does this make sense..???
TIA for any tips, advice and suggestions.
:harry
harrye is offline Find More Posts by harrye
Old Sep 28, 2012, 01:54 PM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
3D mode is just as resistant to turbulance as 2D, there's not much need to switch over. I do prefer 2D for landing and it does have other applications but 3D feels more natural most of the time. Since you have it on a switch, don't over think it, just try both and use what you like.
Generally, yes.
choochoo22 is online now Find More Posts by choochoo22
Old Sep 28, 2012, 03:21 PM
BJM-Maxx is offline
Find More Posts by BJM-Maxx
BJM-Maxx's Avatar
Joined Sep 2007
Guys,
:harry
If you are learning 3D moves of any sort then you already know how to fly. You will never need 2D for anything. I play with it once in a while but I don't bother with it for anything. 3D mode does everything you want to compensate for gusts while landing. I don't use 3D heading hold mode myself so I can learn to fly better.
BJM-Maxx is offline Find More Posts by BJM-Maxx
Old Sep 28, 2012, 04:20 PM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
I dont agree about 2D mode ive had a lot of fun with it on my Extra 260 and lets me push way beyond extreme, Im no way brave or quick enough to do what it lets me do. I can throw it into violent snap roll after snap roll followed by insane tumbles and as soon as it gets close to the floor let the sticks go for instant recovery. If I do multiple snaps and tumbles without it I loose orientation after about 5 rolls with 2D on im letting the plane do upto 30 rolls
Simon2504 is offline Find More Posts by Simon2504
Old Sep 28, 2012, 04:43 PM
Hansschroeder is offline
Find More Posts by Hansschroeder
Joined Sep 2012
Announcing the Guardian 2D/3D stabilizer
I am an old RC'er. Just got the Eagle Tree Guardian 2D/3D installed in my Extra 300 EXP. The system moves the control surfaces o.k., but I want to fine tune on my computer. Bought a Radio Shack cable USB-A to Mini USB-B usable for mobile phones and cameras. Downloaded the Data Recorder. When I click the DR icon it asks to connect the USB cable. I did that very carefully at the Guardian end, but no connection was made and no 3 blinks at the Guardian LED. Does anyone had a similar experience? Is the USB plug at the Guardian defective? Appreciate greatly any comments. Hans
Hansschroeder is offline Find More Posts by Hansschroeder
Old Sep 28, 2012, 05:08 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
First, try another USB port in your PC if it has more than one, just to ensure it is not the USB port in the PC.
ricoalonso is offline Find More Posts by ricoalonso
Old Sep 28, 2012, 06:30 PM
Joined Sep 2012
Tried it. Still no luck. Thanks Hans
Old Sep 28, 2012, 06:37 PM
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
In that case, reseat and make sure the USB at the Guardian end is properly seated. If that still does not help, it may be better to contact EagleTree SYstem directly or BillPA here.
BTW, do you know that you can also tune and setup the Guardian using the Tx sticks? It is in the manual. If you just want to tune the settings, I find it useful too.
Old Sep 28, 2012, 08:37 PM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
USB Hub vs. Direct Port
One other thing to try is to plug the USB cable directly into a port on your computer with no intervening hub - powered or unpowered.
That worked for me. Subsequently, I wound up with an inexpensive Radio Shack GigaWare hub, tried it, and it worked, but the original hub behaved as the original poster described.
Michael
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Sep 28, 2012, 08:43 PM
Rick
Joined Mar 2011
It's worth getting the PC link to work correctly but still, it seems you are trying to tune something without knowing what tuning is necessary. The things that are most important can be done at the field with the transmitter. While you are sorting out the USB issue, fly the plane.
Old Sep 29, 2012, 06:41 AM
FinnCat is offline
Find More Posts by FinnCat
Joined May 2012
1) Check that the cable works. You must have some other gadgets like camera or a memory bank or some other that uses the same mini usb -connection. Or borrow one of neighbors, you should hear a "bling" sound a few seconds after connecting the device to computer. Some cheap cables may be DOA, dead on arrival. A broken UBS connector is a possibility also.
2) Check that you have the version of Eagle Tree Data Recorder that supports Guardian 2D/3D. A while ago it was not the standard but a beta release.
Programming Guardian 2D/3D with transmitter is possible, but my opinion is that it is the second option for field use. I use it mainly to set servo calibration. With computer you can see online how Guardian sees horizontal and vertical position, you can see exactly the settings of potentiometers etc. I have a good quality 9 feet USB -extension cable + USB-to mini/micro USB -cables and they have proven to be great help when programming different flight controllers, inc. Guardian.
FinnCat is offline Find More Posts by FinnCat
Old Sep 29, 2012, 04:45 PM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
First, what version of the ET Data Recorder/Windows Application have to downloaded and installed on your PC?
Let's make sure you have the correct version number.
-mike-
boiko is offline Find More Posts by boiko
Old Sep 30, 2012, 02:22 AM
rateoneturn is offline
Find More Posts by rateoneturn
Joined Nov 2010
hans,
you have the WRONG cable. mini-b is a different size than micro-b (the correct size)
rateoneturn
rateoneturn is offline Find More Posts by rateoneturn
Old Sep 30, 2012, 03:05 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Ben,
So in a long winded manner ( on my part !), i think your observations are spot on and are the trade off with using centre stick mode. In the end, i adjusted box size between large and small until i found a level that flew most natural to me.
Al
OK great
Thanks for that, so i seem to be understanding how it all works.
What i tried at the field this weekend was to make the box as large as i could and increase and decrease the gains until i found the right "feeling"
All of this was to avoid the abrupt change from stabilised to no stabilisation.
I couldnt find anything that works for me.
What i think i need to do is to make the box as small as possible (or turn it off)
as this should get rid of that "step" in control.
Thanks for the pointers guys it has helped me clarify a few things
Will report back when i have had chance to give it ago.
Ben
Borneoben is offline Find More Posts by Borneoben
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
