Ipoh, Perak Malaysia
Joined Jul 2006
chewy |
According to the manual 2D mode is 4 flashes & errors are 4 flashes followed by a series of other flashes depending on the fault. With mine it is flashing non stop. Anyhow, in the meantime it has stopped flashing altogether. It lights for 1 sec at power up then goes off ![]() Kev |
Doha, Qatar, Middle East
Joined Jan 2005
Yes all copm ports match
I have since got it to work I found that if i plugged in my data recorder and set up a new model i could then access the hardware tab and choose Guardian from the drop down menu. Everything works just fine now. It seems strange that you would have to do this becasue if i didnt have a Data recorder to plug in then i dont see how i could have accessed the software properly? Any way all sorted now Cheers Maiden tomorrow! Ben |
Solid On ; 3D Mode One repeated blink: 2D Mode Solid Off : Stabilization Disabled 4 repeated blinks: Error condition Pause and then a series of faster blinks 1,5,6 or 7 blinks depending on the error, Are you saying that your LED does nothing at all now even when the battery is first connected? Perhaps you should contact Eagle Treand open a support ticket. Charles |
Joined Jan 2005
one more question guys
Before my maiden tomorrow (parkzone extra 300) I have all the individual gain pots on teh unit set to 50 and i have the master gain attached to aux 3 on my DX8 and the knob set to center which i am also guessing is 50. Do you think this is a good place to start from? Cheers Ben |
Fort Worth, Texas
Joined Nov 2002
Cheers, Blake |
United States, CA, Lakeside
Joined Apr 2010
that was the only way i could get mine working as well, reversed it using hitec programmer on hitec digital servos. in digital servos you can move the pot wires and motor wires to opposite connectors, but get ready to kill a servo figuring it out. several guides online about it.
SC gets $10 to reverse the servo, programers are $20 i think |
I have fired up again this morning and she has gone back to non stop blinks as before. Funny though, seems to work the controls OK. Thanks, I will get onto Eagle Cheers Kev |
Abnomilie , possible firmware glitch
My son has been flying a Guardian 2D /3D from the first production run and has numerious flights on it in his AJ Slick. Wed. he informed me that it was acting very strange all of a sudden so he removed it and dropped it off for me to figure out what ailed it . Turns out that by some mystery means the OnBoard Duel Aileron Mixing Enabled had became changed from on to off.
There is no short cut to this option and he had not entered the Transmitter Programing Mode and had not had it connected to a PC since it was first installed in the Sliick a couple of months or so ago. Posted just as a heads up in case anyone notices that one aileron servo no long functions as it should. They are rare events but I have had ESCs and even Transmitters get their programming scrambled a few times in the pastnot related to Guardian 2D/3D however.. Charles |
Charles |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
