This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Sep 10, 2012, 10:54 PM
abhaypawar is offline
Find More Posts by abhaypawar
Joined Feb 2009
Need info...
I got 2 units of the Guardian, and mounted one of them on my calmato sport.
When I power on the guardian, the aileron surface moves all the way up and then comes back down to neutral position.
Is this normal?
If not is there some way of resetting the unit?
Is there a default with position or boot sequence?
abhaypawar is offline Find More Posts by abhaypawar
Old Sep 10, 2012, 11:22 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Is this normal?
It happens on all of mine. It happens when I turn on the receiver before the transmitter and sometimes even if the transmitter is on first and it takes a few seconds for the receiver to connect to the transmitter. It doesn't seem to hurt anything.
Steve
Floater73 is offline Find More Posts by Floater73
Old Sep 11, 2012, 12:22 AM
Bodolf is offline
Find More Posts by Bodolf
Left the trainer phase
Danmark, Hovedstaden, Værløse
Joined Jul 2011
Steve
I have five Guardian 2D-3D mounted in different planes. They all behave like that most of the time when I connect to the flightpack.
Bodolf is offline Find More Posts by Bodolf
Old Sep 11, 2012, 09:27 AM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
Suggestion:
I'd like to have the programming option to change my 3 position flap switch (mode) from:
2D - off - 3D
To:
3D, heading hold off, rate on - off - 3D, heading hold on, rate on.
t.edwards is offline Find More Posts by t.edwards
Old Sep 11, 2012, 09:57 AM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
Originally Posted by t.edwards View Post
Suggestion:
2D - off - 3D
To:
Its a difficult choice of what to have selected before flight!!!!! Ive found flying in 2D mode can be amazing with my Extra 260 as I can just throw the sticks anywhere, perform countless snap rolls, flat spins and many other heart in mouth moments and know if I let the sticks go Im safe!!!!! I prefer to do ground takeoffs in direct rate 3D and hand launches in heading hold, normal flying around in direct rate and learning 3D in heading hold. Making the choice before flight is proving to be a challenge !!!!!!!
Simon2504 is offline Find More Posts by Simon2504
Old Sep 11, 2012, 10:45 AM
Joined Aug 2005
I have easier choices, I haven't found a 2D setting(s) I like so it's just 3D. 3D heading hold is plenty, 2D just seems "odd" even with the "box" size minimized.
Old Sep 11, 2012, 12:05 PM
ronj10 is offline
Find More Posts by ronj10
I like Golden Age
ronj10's Avatar
Joined Apr 2007
minimal rudder movement from guardian
Hello
I have my new guardian and I installed it in a chipmunk. I am using a a DX6i with a Ar8000 receiver.
I have the gain set all the way on all three axis.
I have the rudder set to full throw in the transmitter setup.
I do not have dual rates or any other feature set up in the radio.
Simple, straightforward 3 axis fixed wing setup.
The guardian blinks for a 2D setting.
Anyway, when I twirl the plane in its various axis I get good movement in pitch and roll but just a smidge in rudder. Not sure why.
I do get full rudder throw with my stick.
I expected the rudder to move similar to the pitch and roll. It does not. It deflects so little I doubt that it would do much good. I was hoping it would be useful for my takeoffs with my tail draggers.
Any ideas? how do I get the guardian to give more yaw movement to the rudder?
ronj10 is offline Find More Posts by ronj10
Old Sep 11, 2012, 01:36 PM
Bodolf is offline
Joined Jul 2011
Originally Posted by ronj10 View Post
Hello
I have found that if you enable some strong head holding in 2D, the Guardian counteracts the rudder with the ailerons to stay on course, and it does it very efficiently. If you disable head holding, it turns nicely with the rudder.
Old Sep 11, 2012, 01:53 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Land on day when the wind is gusting to 30 mph. You will like 2D.
Prof100 is offline Find More Posts by Prof100
Old Sep 11, 2012, 01:58 PM
Joined Dec 2011
+1 I set level flight to slightly nose up I can now bring in the Extra 260 down just using throttle for the perfect 3 point landing and not worry a bit about crosswind throwing it around
Old Sep 11, 2012, 02:04 PM
Bodolf is offline
Joined Jul 2011
Maybe a "newbie comment", but I love the combo of 2D-3D. The 2D has saved my planes from crashing many times when I have pushed myself to the limits of my experience learning acrobatics: As soon as I can't handle it I engage 2D, and the plane levels out immediately. I learn much faster with this "safety net" under my planes, without being punished by ending up with a wreck and a lost flying day for each serious mistake. And I love 2D for landing in wind.
Old Sep 11, 2012, 03:13 PM
Joined Aug 2005
3D heading hold, high alpha harrier, and just catch the plane.
Old Sep 13, 2012, 01:28 AM
Berkie is online now
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Hi all
Am just attempting a hook up of my first Guardian
Apart from having to reverse all the gains so that the controls go the right way, it seem,s to work OK, but the LED is blinking continuously i.e. no pauses at all, & a continuously blinking LED is not listed anywhere in the manual.
Does anyone know what this may mean?
Kev
Berkie is online now Find More Posts by Berkie
Old Sep 13, 2012, 04:19 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Help, ET Software not Recognizing Guardian
Hi Guys
I have just tried to connect my Guardian to my PC but the ET software doesn't seem to recognize the unit.
I have uninstalled previous versions of the ET software and loaded the Beta Version 10.43
I start the program and it asks me to go through the Recorder Configuration Wizard
At this stage i have already connected the guardian and the computer has been though its auto detection routine and all is fine there.
The Guadian is also showing the 3 flash code for being connected to USB.
I have tried from USB power only and i have tried with the main flight pack also connected to the system and there is no difference.
The ET software doesn't recognize the Guardian and the Next button stays grayed out and i cant move forward.
What am I doing wrong Gents?
Any pointers will be gratefully received
Cheers
Ben
Borneoben is offline Find More Posts by Borneoben
Old Sep 13, 2012, 06:15 AM
Joined Feb 2009
Need info to connect 2 servos on elevator
Can i connect the AUX to the second elevator servo, this setup is required for my gasoline plane.
Where as the aileron can be managed by using a Y connector.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
