This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Sep 05, 2012, 10:36 PM
Falcon's rc
DanielMadrigal's Avatar
USA, GA, Byron
Joined Apr 2009
Thanks John.T I just did that : ) I hope this fix it
DanielMadrigal is offline Find More Posts by DanielMadrigal
Old Sep 06, 2012, 04:26 AM
Norway
Joined Mar 2005
Hi all, just signing up for the thread as i am avaiting my new 2d/3d ET.
iceman3 is offline Find More Posts by iceman3
Old Sep 06, 2012, 09:07 AM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by simmons1a View Post
I turned OFF the 'Auto Turn Coordination', and when trying to correct a non control input generated roll, the rudder no longer moves opposing the aileons...in fact the rudder does not move at all!
I managed to work out that the 'Master Gain' does default to around 40%, and have setup a MIX on DX6i to give me -100% OFF / -0% MEDIUM and +80% gain on MIX1.
Is there a way that anyone knows of setting the default MASTER gain to something other than the 40%?
What do you mean by "Master Gain does default to 40%"?
Prof100 is offline Find More Posts by Prof100
Old Sep 06, 2012, 09:47 AM
Doha, Qatar, Middle East
Joined Jan 2005
Hi Guys
I am hoping to maiden my PZ Extra 300 after installing a Guardian,
How critical is the mouting in relation to the CoG of the plane?
Due to the way the battery mounts in the PZ Extra i can only mount the Guardian a far way back from the CG but still within the wing chord is this OK?
CG is close to the wing spar you can see in the picture so Guardian is mounted maybe 75-100mm back from that.
Please see pics attached.
Any hints or tips before my first flight?
Cheers
Ben
wazzer is offline Find More Posts by wazzer
Old Sep 06, 2012, 10:57 AM
Prof100's Avatar
Joined Jul 2007
You will be fine. I mounted a Guardian in delta elevon scratch built 6 inches behind the cg and it flys great with it. I posted videos of it in this thread.
Bill
Old Sep 06, 2012, 11:18 AM
Joined Jan 2005
Awesome Thanks!
I will not have time to go through the PC setup before i fly the plane will i be OK on "Out Of The Box" defaults for my first few flights?
I have set all the gains to 50% on the pots and using the gear channel to switch between 2D and 3D.
Does anyone know how to mix in the F.Mode switch on a DX7 so i can use the 3 position switch to allow 2D, OFF and 3D modes?
Cheers
Ben
Old Sep 06, 2012, 01:20 PM
Prof100's Avatar
Joined Jul 2007
Originally Posted by wazzer View Post
Awesome Thanks!
Cheers
Ben
Ben,
Go to post 1573 if you want to map the gear channel to the 3 position flap switch. The step by step how-to is in blue.
Bill
Old Sep 06, 2012, 02:35 PM
Joined Aug 2012
See earlier post #1742. When the gain is disconnected (no input) the manual states that master gain defaults to 100 % whereas previous posts on this forum stated that the default master gain was 40%.
simmons1a is offline Find More Posts by simmons1a
Old Sep 06, 2012, 02:49 PM
Prof100's Avatar
Joined Jul 2007
And the correct answer is??? My DX7 does not have a slider or knob for master gain settings.
Old Sep 06, 2012, 05:13 PM
Joined Dec 2009
Another 3 position Sw???
I am using a DX8 and an airplane with flaps so I need to program another 3 position switch. Flight mode would be good, but no options in the program that I can find. Any ideas or other 3 position switch ?
RWHanson is offline Find More Posts by RWHanson
Old Sep 06, 2012, 07:16 PM
Prof100's Avatar
Joined Jul 2007
OK, I don't have a DX8 but the principle is the same. Which channel will you plug in the MOD plug from the Guardian? You need to assign a spare 3 position switch to that channel.
Old Sep 06, 2012, 08:01 PM
Great White North
Joined Jun 2008
Originally Posted by Crist Rigotti View Post
Yes, it is between the OSD and the servos. I'm using rudder for RTH and not ailerons. My FY-20A worked perfectly with this set up so I bought the ET Guardian 2D/3D hoping that it will be a much better unit. I'm an ET fan. Of course I'm only using it in the 2D mode.
Great to hear it works that way as well. Yes i am a fan too the 2d/3d is really versatile
PS - i am still using the booster metthod you describe a while back - i love it ! Cheap / easy and versatile - currently using it on futaba 10c with spektrum module - so no internal changes at all. Module to 15ft cable to attenuate and give me room to hand launch and get in to my car (canada is cold after all) booster on the roof with fpv antenna stuff
Al
alros_100 is offline Find More Posts by alros_100
Old Sep 06, 2012, 08:06 PM
Great White North
Joined Jun 2008
Awesome Thanks!
Cheers
Ben
Have you gone thru the gesture menus at least and do you have the mode switch set up so you can zero trims and set level ?
Make sure it has defaulted corretly and the surfaces move and compensate in correct directions
The software is actually the fastest way to do all that
Al
Old Sep 06, 2012, 10:28 PM
First to go over 106K feet
Crist Rigotti's Avatar
USA, IA, North Liberty
Joined Mar 2008
Al
I did some flying tonight. wind near calm. Everything worked very well. I had to turn up thr roll pot nearly all the way up to keep it from rocking back and forth. Next time out I'll turn on the heading hold function to see how that affects my set up.
Glad your booster system is working well. I got a DL at a very good price, so I sold mine.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Sep 07, 2012, 01:19 AM
Joined Aug 2012
40%. I have set gear channel with mix1 on my dx6i so that I effectively have a three position setting available on for the gain input on the Guardian
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 6 May 02, 2013 04:41 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
