This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Aug 31, 2012, 11:44 AM
Gordonq is offline
Find More Posts by Gordonq
Not an avatar... I'm not Hindu
Gordonq's Avatar
Joined Oct 2007
Anyone using a 4 channel receiver?
I have some small planes (you know, ones that really could use some stabilization) and use 4 channel receivers for their weight savings. It appears that the 2D/3D stabilizer can be used in this configuration, but I won't have the mode/gain channels available. Can anyone offer their experience here? Like how to set initial trim? Any caveats? Thx
Gordonq is offline Find More Posts by Gordonq
Old Aug 31, 2012, 11:54 AM
BJM-Maxx is offline
Find More Posts by BJM-Maxx
BJM-Maxx's Avatar
Joined Sep 2007
Originally Posted by Tatonka View Post
BJM-Maxx, I have the Guardian on my Buck Huck, and have been testing it out for a couple weeks now.....For me, the HH mode just felt weird, did not want to get accustomed to flying that way since none of my other planes have a Guardian, 3D direct rate mode feels the most natural......I have found that I can now fly in much higher wind, biggest advantage is landing since our club field is set up in such a way that there is frequently a cross wind.....Guardian makes landing a non-event now.
Did you have to raise the speed rate from the default with direct rate mode on?
Originally Posted by Melnic View Post
Reset your center & Trims. It's in the manual and on the video in post #1(toggle the Mode switch after power up)
I don't like Heading Hold, I prefer Rate mode. (Heading Hold disabled).
I did toggle reset several times. It resets just fine, but after waving it around in the air if winds up wanting to fly tilted. Now there is a big difference compared to flying, I am waving it around sideways in a way that never happens in the air. I will have to try flying it obviously. I don't use 2D mode on my FY-20A except for fun anyway.
BJM-Maxx is offline Find More Posts by BJM-Maxx
Old Aug 31, 2012, 12:33 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
Power distribution buss?
Does anyone have a line on a (CHEAP!) power distribution buss to hook servos up to? Might just make my own, but the Guardian setup is really only good for smaller servo setups. I have a prime stick with 5 high torque servos that would overpower the single (rather small gauge at that) power wire of the guardian.
Eagletree should offer a higher power version!
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Aug 31, 2012, 01:34 PM
Tatonka is offline
Find More Posts by Tatonka
Buffalos have wings
Tatonka's Avatar
Vancouver Washington
Joined Nov 2007
I have not messed with that, may look into it now that you mentioned it
Tatonka is offline Find More Posts by Tatonka
Old Aug 31, 2012, 02:29 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Here's one I saw but was not sure if it was what I wanted
http://www.skookumrobotics.com/shop/...fd0r76q2sb85r0
If you find other ones let me know.
OOh, here's the manual
http://www.skookumrobotics.com/downl...PWR_Manual.pdf
HobbyKing should make some of this guy's stuff:
http://www.rcgroups.com/forums/member.php?u=24181
Oh, HERE YA GO! (note standard price is a kit you solder up yourself)
http://www.servocity.com/html/servo_power_boards.html
Melnic is offline Find More Posts by Melnic
Old Aug 31, 2012, 03:03 PM
Joined May 2010
Awesome, thanks. I also saw this from one of your links.
Old Aug 31, 2012, 03:32 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
New, lost cost airplane stabilizer
Here is one that works great and be had for "chicken feed."
Below is an excellent video explanation and demo.
http://www.youtube.com/watch?feature=player_embedded&v=sXUeO3auRZg
Prof100 is offline Find More Posts by Prof100
Old Aug 31, 2012, 03:46 PM
choochoo22 is offline
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
.... after waving it around in the air if winds up wanting to fly tilted. Now there is a big difference compared to flying, I am waving it around sideways in a way that never happens in the air. I will have to try flying it obviously.
I went through exactly the same exercise and with the same puzzled outcome. It was pointed out to me that the Guardian, unlike simpler systems, actually tries to hold the heading in 2D by banking the plane just like a pilot would. This means that after gyrating the plane around, if your heading isn't the same as you started with the Guardian will try to bank you back on course. This is a good thing.
To verify if this is what you are observing, make note of the straight and level heading before you start gyrating. Afterwards, bringing the plane back to this same orientation should bring all surfaces back to neutral, no bank/tilt. In flight this would be a non issue as the plane would just come back on course and stabilize. You can also check this by shutting off the 2D heading hold with the software and it will just level the plane on whatever heading.
choochoo22 is offline Find More Posts by choochoo22
Old Aug 31, 2012, 04:24 PM
BJM-Maxx is offline
BJM-Maxx's Avatar
Joined Sep 2007
I noticed that if I simply yawed the plane the rudder and the ailerons would move, if I "flew" it the way it wanted it mostly wound up level and for the most part aimed close to where it started. I am pretty sure I also had times where it was wanted to be on a tilt. I am sure it will fly fine, I just need to get it in the air.
Old Aug 31, 2012, 04:26 PM
BJM-Maxx is offline
BJM-Maxx's Avatar
Joined Sep 2007
Could you tell me what your gains are set to, that would save me some trial and error.
Old Aug 31, 2012, 06:28 PM
Gordonq is offline
Gordonq's Avatar
Joined Oct 2007
Re: 4 channel only receiver - I see that the trim can be reset with the software provided; no need for a mode channel connection to the Guardian. Just might want to have a laptop at the field.
Old Sep 01, 2012, 05:23 AM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Originally Posted by boiko View Post
What is the latest PC Software (For Guardian 2D/3D) and Firmware version now available?
-mike-
For reference to anyone else....current PC Software Version is 10.43 and current Guardian 2D/3D Firmware Version is 1.17
As of this posting...
-mike-
boiko is offline Find More Posts by boiko
Old Sep 01, 2012, 11:08 AM
simages is offline
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
Just Ordered 2.....
Hope they make it in for batch 3 or 4 .....
simages is offline Find More Posts by simages
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Sep 01, 2012, 12:27 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Looks Like Tower Hobbies is gonna be getting some in late September
Price is only $65.99 as listed on towers website
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Sep 01, 2012, 01:02 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
I'll take my chances with eagle tree
Price is only $65.99 as listed on towers website FCA
or.... if anyone has one for sale...
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
