Joined Apr 2007
I have installed a Guardian in a Precision Areobatics addiction X. I have flown 4 packs now on the guardian and in 2d mode everything is ok. However in 3d mode I have an issue. When in straight and level trimmed flight when 3d is engaged the plane will aileron roll to the right or clockwise. I have completly removed my right thumb from the stick so I know that I'm not the cause of the roll. It does the same thing in knife edge. Guardian allows the plane to roll clockwise out of knife edge. I have adjusted the gain some but that did not help. Guardian is mounted on velcro next to the receiver and I fly Futaba. Also when I put the plane into a hover and engage 3d mode it will nose over to the right requiring a constant left rudder input to maintain the hover. The addiction x is a very easy airplane to hover so I do not know what is going on. I bought the guardian to help me get over my fear of hovering close to the ground so hopefully it will be able to help me acomplish this with the proper adjustments.
United States, CA, Santa Clara
Joined Mar 2011
I think what is happening is that you have some trim dialed in. In 3D mode Guardian will interpret right trim as a command to continue rolling slowly to the right. |
Joined Apr 2007
I now notice that when I try to reset the level flight and trim (1 toggle of the mode sw within 15 sec of power up) I do not get a twitch of the ailerons. I tried about a dozen times. I even tried increasing the end points from 100 to 125 on the channel that controls the mode switch.When sitting level on a table there is a deflection of the ailerons and elevator when the mode switch is put into 2d or 3d. Thats the reason I tried the level and trim reset
Joined Apr 2007
Joined Mar 2011
It's good practice to make mechanical adjustments on your surfaces and fly with no trim even without a Guardian. Guardian requires us not to be lazy on this. |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
