United Kingdom, England, Ripon
Joined Dec 2011
er9x, er9x
i've got to where now i take off in 2d or 3d mode. that way if by some chance i did screw something up, i'm only 3 feet off the ground and i'm still going slow. being x amount of mistakes high is no good if your x + 1 mistakes high, ask jedorme, he tried to recover all the way to the ground. by the time he got there he had a nice head of steam built up. after all, you can't call it a lawn dart if it doesn't stick. making sure the correction direction is right is a no brainer. it's easier than regular gyro setup. if you raise the right wing up, the a/lon should go up. it doesn't matter if your in front, behind or to the side. if you move any part of the plane,l wing, r wing, tail up, tail down, tail left, tail right, the control surface should move the same way. period. michael clyde |
United States, ME, Wells
Joined May 2008
eFlite Habu 32 EDF Solo WIth Help of Guardian
Just a quick note to express my appreciation for all the help I received (directly and indirectly) from this forum on setting up the Guardian unit.
I had a Habu 32 EDF that was crashed several times by a very experienced RC pilot (and full-scale jet pilot). It was getting expensive to repair it and I had not landed it, by my self, and only flown on a buddy box. To make a long story short, I installed a Guardian unit (third one, now) and set the plane up for dual ailerons (CROW, reduced by advancing the throttle), elevator and rudder. I estimated the level attitude and had trims from before the last crash, so did a ground set of level and trims. I set the gain to about 30 - 40% (0 - 100% scale), but took off with Guardian off. Quickly, I could see I was overcontrolling the bird, so I switched on 3D mode and it smoothed everything out. I did some experimenting with 2D, verifying level and no oscillations. I then made a greaser landing in 3D mode and was able to observe that the ailerons were being manipulated by the Guardian. This would not have been possible without all the help I received from the forum as well as the outstanding Guardian product. Michael |
first plane saved due to this guardian.
got a new mini spitfire (fms h/k clone) a nightmare to get flying correctly,my last one so beat up needed replacing. set cog up as 45mm wahhhhhhh to nose heavy control surfaces way to sensitive,thank god for 2d mode..4 batterys later finally got it,set cog at 56mm finally got it flying how i wanted it.. a lot different to the fms spitfire cog was 45mm thank goodness for that 2d mode saved it from trying to resemble a fence post
Really hope the 3D modes can be toggled remotely in a future update. |
what if you set level flight and trims with the plane vertical in 2d mode, then switch to off or to 3d mode to take off and then when near vertical, switch to 2d mode and crank up the gain, then when roll axis was touched it wouldn't disable the other axis? does that even sound feasible?
has anybody come up with a way around the 3d hh disengaging all 3 axis when the roll axis is touched syndrome? too bad you can't have two 2d modes, one with level flight set level and one set with level in the vertical position. michael clyde |
Michael, Why would you want to set level flight and trims with the plane vertical? ![]() Bill |
| Thread Tools | |
| Discussion Can I control Guardian stabilizer with DX6i? | njwxyz | Eagle Tree Systems | 6 | May 02, 2013 04:41 PM |
| Discussion GPS 2D Plots incomplete, 3D OK | jackerbes | Eagle Tree Systems | 1 | Oct 23, 2011 09:42 PM |
| Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit | lanternfly | RC Kites | 0 | Oct 05, 2011 09:42 PM |
| Data 2d or 3d wing ribs? | Marty7n | Beginner Training Area (Aircraft-Electric) | 56 | Sep 22, 2011 04:06 PM |
| Discussion 3View to 3D to 2d | techasist | CAD/CAM | 0 | Mar 27, 2011 12:19 AM |
