This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Aug 11, 2012, 07:23 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
It seems the solution for dual elevators at the moment is programmable digitals.
At $120 a piece you want to make sure they work.
Would the Guardian cope with 5x 65gram digital servos that draw 3.5 amps each at stall? Would it require special setup?
jayb1rdz is offline Find More Posts by jayb1rdz
Old Aug 11, 2012, 07:26 PM
RoryG is offline
Find More Posts by RoryG
The Shetland Flyer
RoryG's Avatar
United Kingdom, Scotland, Lerwick
Joined Jun 2008
Guardian in my Cessna, great camera ship
Cessna at the Knab (9 min 12 sec)
Amazing water flights today with the Icon - vid later
Cheers,
Rory
RoryG is offline Find More Posts by RoryG
Latest blog entry: Aith in Springtime
Old Aug 11, 2012, 08:00 PM
9XTremist is online now
Find More Posts by 9XTremist
San Bernacesspool
9XTremist's Avatar
United States, CA, San Bernardino
Joined Feb 2010
guardian says,
if your servos are going to pull more than 5amps you should be using a "y" cable ..., i think the deal is they don't want over 5amps through those flimsy wires, it's in the supplied instructions
how about axis assignable aux input, that way it could be in an update and not an upgrade
if you follow the 80% rule... it should be 4 amps max
mc
9XTremist is online now Find More Posts by 9XTremist
Old Aug 12, 2012, 05:25 AM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
here is a .pdf of all of the pages of this thread since 2/17/12 thru today 8/12/12, just under 4mB's in total size searchable content if you get one of those little freeware apps.
these pdf's show 100 post per pdf page
michael clyde
this is a portable version, no installation needed, just unpack the zip file and click on the ,exe file. this freeware is the best thing i've found for searching inside pdf files, such as this thread contained in these 2 pdf files
"The FREE PDF viewer download of the PDF-XChange Viewer may be used without limitation for Private, Commercial, Government and all uses, provided it is not -: incorporated or distributed for profit/commercial gain with other software or media distribution of any type - without first gaining permission."
Old Aug 12, 2012, 05:56 AM
lesodell is offline
Find More Posts by lesodell
good till the first drop
lesodell's Avatar
michigan usa
Joined Jan 2005
On my plane with 2 elev servos i just use to servo from diffant mangf that went in diffrent direction to start with like a jr on one side and futaba on the other
lesodell is offline Find More Posts by lesodell
Old Aug 12, 2012, 07:53 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I have the Equalizer II on a giant scale P-47 (No gyros though) and they are $44 each. Like anything, it's a cost benifit thing.
I fully understand the complexities of getting two Elev. servo to work in perfect harmony. I have watched pattern flyers spend hours tweaking Transmitter adjustments to prevent mis tracking during a simple (?) inside loop.
I guess my real issue is that if one is flying what I consider a fairly expensive to purchase,assemble and equip aircraft then why should they be so concerned with whatever addational electronics it requires to fine tune it? I shy away from larger / more expensive aircraft myself. I am content to fly up to 52" aircraft which cost perhaps $600 max. . Given these limits the Guardian as is does a fantastic job. If all of the previusly mentioned feactures were added to a V2(?) version the cost may well put it out of reach (budget) of those of us who want something extremly cost effective for its; capabilities.
Who knows RC electronics are advancing so fast that perhaps in the not to distant futhure one can purchase a 32 channel radio system with matching aircraft RTF with full stabilization ,auto pilot, pre programed precession manuvers all available out of the box. Things sure have changed during the 49 years I have been in RC!
I am currently flying primarely a Blade 130 X and while its' AS3X (flybarless) system is no where near what the Guardian is capable of it makes the heli about 10,000 times easier to fly and maintain than the Concept 30 helis I first learned to fly over 20 years.
For clarification : Guardian is not being used in this or any other Heli by me at this point in time. ET has stated that a heli version is in the plans but no timeframe has been mentioned.
I have a blade 400 that could use a more dump thumbs proof safety device and have seriously considered converting it to flay bar less . My son converted a Blade 450 to FBL a few weeks ago for around $100 and it is truely impressive.
Next logical question perhaps is would Guardian be compatible with a FBL heli and would pero compensation be included?
Charles
Old Aug 12, 2012, 10:06 AM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
JR & spectrum digitals can be bought in "Reverse" configuration. Hitec are programmable & they have several programmers 1 of which can be used to test out the servo without using the radio.
DavidN is offline Find More Posts by DavidN
Old Aug 12, 2012, 12:55 PM
Southern Pride
Way back when Transmitters did not have servo reversing and a 4 Ch. came with 3 standard rotation and 1 reversed one everyone planned their installation with care. Myself and others who understood how servos worked and could solder well reversed many servos for fellow club members. I even installed duel rates on many transmitters without this feacture.
Old Aug 12, 2012, 01:32 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
billpa,
Can you add a wizard similar to the RTH wizard for the OSD pro to set the the servo deflections on the Servo Config Tab? It's not very easy to do the trial and error method to set each one.
Steve
Floater73 is offline Find More Posts by Floater73
Old Aug 12, 2012, 04:35 PM
Southern Pride
Checked at Servo City and a hitec HS 5485HB digital servo is like $25
http://www.servocity.com/html/hs-5485hb_servo.html
and their programmer is like $70
http://www.servocity.com/html/hfp-25...rogrammer.html
Old Aug 12, 2012, 06:42 PM
ForceFedDSM is offline
Find More Posts by ForceFedDSM
ForceFedDSM's Avatar
Massachusetts
Joined Jun 2008
Is this unit only sold direct through ET?
ForceFedDSM is offline Find More Posts by ForceFedDSM
Old Aug 12, 2012, 07:13 PM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
readymaderc.com
dpcav.com
rctoys.com
to name a few, also more on e/t's website
michael
** This poster was Awarded 1 point for... wait this isn't hobbyking, never mind
Old Aug 12, 2012, 08:33 PM
Aerocowboy is offline
Find More Posts by Aerocowboy
Aerocowboy's Avatar
United States, TX, College Station
Joined Jun 2012
I got mine from hobbywireless.com. Last week when I ordered they were the only dealer with the Guardian in stock (and they still show stock).
Aerocowboy is offline Find More Posts by Aerocowboy
Old Aug 12, 2012, 09:02 PM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
aerocowboy,
i called h/wireless a couple of months ago when the guardian was shipping to see if they would have any units and all i got was a recording of a mexican fellow (sounded like a good ole mom and pop set up) and after hearing his voice and being from south teXas, it made me so homesick i called back five times just to listen, he picked up the last time so i hung up , embarrassed.
i see you live in the big metroplex of bryan-college station... l_l gig-em
michael clyde
Old Aug 12, 2012, 09:22 PM
Aerocowboy's Avatar
Joined Jun 2012
Hah. Yeah, I was excited that the only Guardian source I could find was in San Antonio - cheap shipping was quick, for sure!
Gig 'Em!
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
