Old Feb 17, 2012, 10:36 AM
alexf1852 is offline
Find More Posts by alexf1852
alexf1852's Avatar
United States, FL, Inverness
Joined Jan 2010
PL8 and parallel charging
I must be overlooking a setting.
I have 4 6S 3300mah packs in parallel that I want to charge at 25A. I set my input power supply settings at 27A and with a 28V supply, it should easily be capable to charge at 25A to these packs (according to the online calculator).
My preset has:
Parallel Packs: 4P
Charge Amps: 6.25A (I'm assuming the PL8 will multiply # of packs by charge current.)
But the PL8 will only charge at 10A. It thinks that my single lipo is to charge at 2.5A.
What setting is wrong on my preset?
alexf1852 is offline Find More Posts by alexf1852
Old Feb 17, 2012, 10:56 AM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
My preset has:
Parallel Packs: 4P
Hi:
You need to use a preset with the words "High Power" in it. All the others are limited to max 10A charge current. Try that first. Let me know how you make out.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Question 1S parallel charging (vs Serial Charging) with Cellpro Multi4 demiluk Batteries and Chargers 30 Feb 08, 2012 06:55 PM
Discussion PL8 (V2) True Parallel Balance Charging? HahnSolo FMA Direct 5 Nov 24, 2011 09:14 PM
Discussion PL8 gets "tired" charging 6S Stumblebee FMA Direct 11 Nov 11, 2011 08:42 AM
Discussion Charging deep cycles with PL8, what settings? RevToTheRedlin Batteries and Chargers 2 May 12, 2011 06:41 PM
Question PL8 max charge current parallel 1S zapadoo FMA Direct 2 Jan 18, 2011 06:51 PM
