Old Feb 17, 2012, 07:48 AM
miss5031 is offline
Find More Posts by miss5031
Joined Nov 2011
Ppm & pcm
What is PPM and PCM, Exponential, swash AFR mixes, etc. when talking about tx and rx.
miss5031 is offline Find More Posts by miss5031
Old Feb 17, 2012, 09:22 AM
mighty9 is offline
Find More Posts by mighty9
United States, AZ, Cochise
Joined Sep 2011
http://www.easyrc.com/index.html read away .
mighty9 is offline Find More Posts by mighty9
Old Feb 17, 2012, 01:06 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by miss5031 View Post
What is PPM and PCM, Exponential, swash AFR mixes, etc. when talking about tx and rx(
Question is so wide ranging, it is easier to refer to existing readily available information e.g.
. AM, FM, PCM & Spread Spectrum radios - FAQ re differences
. Beginners guide to RC - The original
. Beginners Guide to R/C Flight
. Videos - How to and DIY 101 Setup for EP & Heli
and much more under sub sections
"FAQ = Answers for Beginners and Advanced RC'ers"
"RC system FAQ Tutorials, how the systems work."
"Radio Systems, Accessories, Alterations and FAQ."
at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Feb 17, 2012, 06:52 PM
miss5031 is offline
Joined Nov 2011
Thanx for the info. You guys really are helpfull. These links are great, very informative.
Old Feb 17, 2012, 09:17 PM
Mauricio2346 is offline
Find More Posts by Mauricio2346
Mauricio2346's Avatar
Medellín, Colombia
Joined Jan 2010
PPM and PCM are only two ways of sending information from the transmitter to receiver using RF wideband. using first one or second one should not be inportant to modeller, what its important is that the receiver actually can read the information well without problems (something that Futaba for example has develop for their products).
PPM is Pulse Position Modulation and PCM is pulse code modulation. PPM works changing pulse period of a signal for every channel, so if you see PPM signal from your RC radio, yo will see some square pulses, in which each one corresponds to every channel and if you move the sticks, the period for that "channel pulse" will change. receiver reads the variation of pulse width and changes by the same rate the servo of the channel.
PCM is quite diferent. every channel is represented by some bits depending on resolution of the radio (10 bits, 12 bits, 16 bits). so, every channel value will be represented by that amount of bits. if channel range is -100, 100 for example, you will have 200 "steps" of movement for that channel, so, if your radio is 12 bits, you will have 4096 posible steps, in the range, 200/4096 or 0.048 step/bit.
if stick value is 100, so data value will be 4095. ir the stick is on the middle data value will be 2047 and so. that number should be represented by binary codes ans send it trough the radio module.
which one is better?. depends on Radio Technology. most of 2.4Ghz radio modules works with PPM, and some FM modules works with PCM.
is the best way i found to explain PPM and PCM.
Exponentials, dual rates, etc, are bassically math functions applied to sticks to change behavior of receiver signals respect to stick movements. they're usefull to change flying characteristics of the model.
Regards;
Mauricio
Mauricio2346 is offline Find More Posts by Mauricio2346
Old Feb 18, 2012, 06:27 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Only AM/FM can work with PPM. None of the commercial 2.4GHz modules use FM/AM, they are all digital. Therefore 2.4GHz transmission is some sort of PCM. Of course you can build an FM 2.4GHz tx, but there is no point except for the fun of it.
Of course most of the 2.4 modules accept PPM as input, but they don't directly modulate it like an FM/AM module, instead transform the PPM into digital code, transmit it, then in the rx the code is directly split into channels, no ppm there.
Zen09 is offline Find More Posts by Zen09
Old Feb 18, 2012, 07:53 AM
Medellín, Colombia
Joined Jan 2010
of course, 2.4Ghz module accepts PPM as input (i referred that point). modulation protocols depends on what manufacturers want to use for their products. FASST for Futaba (continous frecuency shifting), DSMX for JR, etc. all protocols based on PCM modulation for 2.4Ghz, and (i dont really know), FSK for FM modules.
what is a fact is that 2.4Ghz send acknowledgement bytes every sample period for all channels. receiver espects to receive that binary code (8 bytes, 16 bytes) and unique to each transmitter. that's why you need to bind the radio to each receiver to make a "link" to receiver.
Old Feb 18, 2012, 09:45 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
No, 2.4g radios do not universally send acks. Most of them are essentially 1-way systems except perhaps during the bind process.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Feb 18, 2012, 11:49 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
And binding is necessary so the receiver knows which transmitter to listen to.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 24, 2012, 01:16 AM
Medellín, Colombia
Joined Jan 2010
Andy
most of them are one way radios but transmitter always sends aditional information (transmitter name) to receiver. so, if dont, how receiver can recognize always the same transmitter?
binding process resets the receiver and store a new "transmitter name" until binding is done and binding plug is removed.
Found JR~PPM-PCM module E-MO Aircraft - General - Radio Equipment (FS/W) 3 May 13, 2011 04:27 PM
Question JR PCM and PPM operation NIKOS5113 Radios 8 Apr 12, 2011 03:11 PM
Discussion PPM or PCM for fpv? MaximumBob FPV Talk 5 Apr 10, 2011 08:46 PM
Help! PPM to PCM freak out! ripdog Electric Power Cars 2 Mar 31, 2011 11:06 PM
Help! Ppm to pcm freak out ripdog Radios 6 Mar 29, 2011 12:51 AM
