Old Feb 16, 2012, 12:32 PM
woode is offline
Find More Posts by woode
woode's Avatar
Joined Mar 2011
Cure time between layups...HELP!
In the midst of a 6 ply layup using MGS L285/285 an emergency arose and I had to stop the layup. Thankfuly I was able to cover it in peelply and bag. My emergency worked out OK and now I hope my layup can be saved.
I cannot find any MGS documentation about resuming a layup. How quick can I get back on the layup and finish applying the last 3 plys?
Thanks for your QUICK reply
woode is offline Find More Posts by woode
Old Feb 16, 2012, 12:51 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Let it fully cure (24h @ room temp), then peel off the peelply (do not touch, sand or attempt to "clean" the surface in any way. It is as good as it will ever get right after removing the peelply.) and continue with the rest of layup. If you try to remove peelply from a soft layup, there is a risk of delamination.
jkettu is offline Find More Posts by jkettu
Discussion Wait time between motor runs? hidaven Electric Plane Talk 19 Oct 17, 2011 07:47 AM
Help! Please Help Cure Illiteracy rdwoebke Multi Task F3X 18 Aug 14, 2011 10:13 AM
Discussion Plug repair between mold half layups flyonline Composites Fabrication 2 Jun 19, 2011 10:17 PM
Question Hey there guys need help in setting pitch cure and throtal cure eskyruben Large Electric Helis 29 Jun 08, 2010 09:44 AM
Need help deciding between upon brushless setup for '2m Mini Bird of Time' Hogster Power Systems 1 Oct 10, 2004 05:17 AM
