Old May 12, 2012, 02:22 PM
Visitor from Reality
United States, IL, Chicago
Joined Dec 1996
Hi Deebee
Short tail moments - have used it a lot. Given that you have to have enough tailplane area to compensate for the short moment arm, it works just fine. Not as pattern perfect as FAI aerobatics would demand, but fine for Sunday sports flying aerobaticificating.
If you really went for 'scale', getting in a bulkier control system than a bellcrank could be fun inducing Fitting a much larger fuel tank - otherwise often called a 'LiPo battery' - could be even more fun, especially with a mid-wing layout.
Joker - recall it vaguely from days gone by. Forget three channel, if you mean rudder/ele/throttle. It really demands ailerons and rudder, though you could get by with no rudder and hand toss/bellyflop for take-offs and landings. Put two very small servos, depending on model size, in the wings to waggle the ailerons. If still tight inside, consider a wing mounted RX, for another way out. 'Full size' could be real fun getting stuff inside.
But if you wanted an easy hobby, you'd buy an iSpendPhone
D
Dereck is offline Find More Posts by Dereck
Discussion Convert Control Line to R/C vwtrey Fuel Plane Talk 4 Jan 11, 2010 11:58 PM
Discussion Control line to R/C conversions War Bird Radio Fuel Plane Talk 10 Feb 19, 2009 12:21 AM
Control Line to R/C conversion - who has done it? crashsiegel Electric Plane Talk 68 Feb 08, 2009 01:32 PM
Help! Wanted - Goldberg P-40 R/C or Control Line Plans dwhit593 Control Line 1 Dec 22, 2008 05:02 PM
Wanted Goldberg P-40 R/C or Control Line dwhit593 Aircraft - Fuel - Airplanes (FS/W) 0 Oct 20, 2008 08:28 AM
