Mar 02, 2012, 01:41 PM
Rancho Santa Margarita, CA
Joined May 2006
Originally Posted by WDuck
I just did my first Spektrum install in something other than park flyer size plane. My impression / thought is - these receivers should come with a 12" extension from the start! If you have to snake the satellite cable at all, you just can't them get them that far apart. The Best Practices for installation says you want the remotes "far" apart. Can't see how you can do that with a 6"? cable....
As far as spacing goes, my thought is the length of the wing saddle would be ideal, one receiver near the leading and trailing edge. That should give you a nice spacing between the main and satellite. Looking at your install, my feeling would be to get the satellite farther back, behind the last servo so it is out there by itself.
Chuck
Chuck,
I agree. I guess its hard to not spend $10 for a little piece of mind. I'm probably gonna hit the LHS at lunch. I am going to put it back in the fuse past the trailing edge on the side of the fuse.
Wish I could get this $1 cable for less than $10.
Doug
