Espritmodel.com Heli Air
This thread is privately moderated by timecop, who may elect to delete unwanted replies.
Old Mar 27, 2012, 10:51 AM
Autodidact
Joined Jan 2012
Is it possible for the gyros to get reversed on this board? (Like I've read can happen on a kk board?)
TEDious is offline Find More Posts by TEDious
Old Mar 27, 2012, 11:08 AM
United States, TX
Joined Dec 2011
you can check in MWII GUI in values of the gyro to see if it is giving you wrong values.
pilot006 is offline Find More Posts by pilot006
Old Mar 27, 2012, 11:22 AM
TruckBasher's Avatar
Joined Oct 2011
Originally Posted by timecop View Post
OK, done.
Thanks TC, I think I need to buy another board hehehe
looking good so far but I will try nicodh PID specially the level.
TruckBasher is offline Find More Posts by TruckBasher
Old Mar 27, 2012, 12:20 PM
Pirate des Caraïbes
CapitaineHaddock's Avatar
Curacao
Joined Feb 2012
Originally Posted by sbaron View Post
No, since I'm really in love with the naze32 board
I'm just running a modified drv_pwm.c to connect my ppm receiver on PA8 (pwm_motor1), so I need TIM1_CH1 to handle the ppm decoding.
I'm doing this because I have an hobbyking HK-T6A-V2 which outpout +5V ...
Most input pins of the STM32 are 5V tolerant. Which input pins of the Naze32 are not 5V tolerant?
I will check in the STM32 Reference Manual which is not near me at the moment.
It would be nice if this was indicated in the Naze32 manual.
Which receiver are you using with the HK-T6A-V2? It seems that the latest receivers do not output CPPM any longer.
CapitaineHaddock is offline Find More Posts by CapitaineHaddock
Old Mar 27, 2012, 01:01 PM
France
Joined Sep 2011
It would be nice if this was indicated in the Naze32 manual..
See the STM32F103x8/STM32F103xB datasheet page 27-31: pins 1-19 are not 5V tolerant. That means that all the ppm/pwm input pins on the naze32 board should not be used at +5v.
Edit: these posts already mentions this:
http://www.rcgroups.com/forums/showt...9#post21007848
http://www.rcgroups.com/forums/showt...9#post21008129
I'm using this one - It support CPPM on the 'bat' pin, even if that's not documented.
sbaron is offline Find More Posts by sbaron
Old Mar 27, 2012, 01:07 PM
CrazyLittle's Avatar
United States, CA, SF
Joined Sep 2011
This is also the same thing, with CPPM output on the battery plug:
http://www.hobbypartz.com/79p-r6b-receiver.html
CrazyLittle is offline Find More Posts by CrazyLittle
Old Mar 27, 2012, 01:16 PM
rimshotcopter's Avatar
Joined Aug 2009
I am using this same one, appears to be working great so far.
Off-Topic question: Have you found the RSSI pin on this RX?
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 27, 2012, 01:24 PM
Joined Sep 2011
As far as I know there is no RSSI "pin" on it. You might find a pad on the board itself if you feel like getting that deep into it. If you want fancier features than a $9 rx gives, then frsky is a good alternative.
Old Mar 27, 2012, 01:26 PM
France
Joined Sep 2011
No, I'm not even sure it has one. Maybe someone else could answer?
Old Mar 27, 2012, 01:41 PM
Joined Aug 2009
Thank you, I really need to look into this now.
Old Mar 27, 2012, 01:43 PM
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
default settings, rise P if using fast esc, otherwise flies fine on defaults. upgrade to latest firmware, reset to defaults ("defaults" in cli), fly. never messed with I or D on anything im flying, so no advice there.
Did as you advised but same behavior as always.
Naze32 acc problem (0 min 26 sec)
Hope you can see how it rolls. Any advise appreciated.
Christian
LazyZero is offline Find More Posts by LazyZero
Old Mar 27, 2012, 01:56 PM
Joined Jan 2011
What's your settings? It seems like I is to high.
nicodh is offline Find More Posts by nicodh
Old Mar 27, 2012, 02:03 PM
Master of Flash
LazyZero's Avatar
Joined Jun 2005
That video was with default as suggested by TC. I did later a flight with P = 7.5 I= 0.005 D=25 but no big change. The think is there is not I2C error but a little error in MultiWiiConf of ~60 see the attached screenshot on the bottom left.
Christian
Old Mar 27, 2012, 02:35 PM
Joined Aug 2009
Christian
Try dropping the LEVEL D to about 20 for starters.
Old Mar 27, 2012, 02:46 PM
United States, TX, Dallas
Joined Dec 2010
Hi, sbaron
I have the same Rx (almost -different brand) and it works great using the PPM signal on the battery connector. So, now I wonder if it's 3V or 5V and if it's Ok to use it.
thebgrian is offline Find More Posts by thebgrian
Discussion Sen. Coburn $9 Trillion plan- Now we're talking SPEED-E-FLYER Life, The Universe, and Politics 7 Jul 20, 2011 04:43 PM
