Old Feb 15, 2012, 09:07 PM
Socalfusions is offline
Find More Posts by Socalfusions
Joined Aug 2011
Differences between rc and dc brushless motors?
What are the differences between these two motor types?
Socalfusions is offline Find More Posts by Socalfusions
Old Feb 16, 2012, 02:56 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Not sure what your question is
All electric motors operate by having a set of fixed magnets repel another set of magnets that are free to rotate around a shaft, and are fixed to the shaft so that they turn it. Both sets of magnets can be electro-magnets, but in our hobby motors one set is permanent magnets (don't need any power) and the other set is electro-magnets (need power).
In the simplest of motors, the power to the electro-magnets needs to be reversed twice every revolution so the magnets will always repel each other whatever position the moving ones are in, and keep the motor spinning. In these simple motors, the electro-magnets are rotating, and they get their power through a pair of "brushes" rubbing on a metal ring on the shaft. Reversal of the power during every revolution is achieved because that ring is in two halves, so as it rotates it's alternating which half is in contact with which brush. One weakness of this system is the brushes themselves, which can burn out and, even when new, are a source of electrical inefficiency. These motors are referred to as "brushed" motors or, sometimes, "DC" (direct current) motors because they will run if you simply apply a battery to their two input wires.
Most flyers these days use "brushless" motors. These have the electro-magnets on the static part of the motor, with the permanent magnets on the moving part, so the electro magnets can be connected directly to the power supply without using brushes. But, without any brushes we need another way to reverse the power every revolution, and this is done using an electronic speed controller (ESC) which electronically switches the power in sync with the rotation of the motor. These motors are sometimes referred to as "AC" (alternating current) motors because the power that's supplied to them is alternating. They cannot be run by simply applying a battery to their input wires.
abenn is offline Find More Posts by abenn
Old Feb 16, 2012, 03:38 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
I think you might need to ask your question again.
The brushless motors we use for RC (radio/remote control) models are DC (direct current) brushless motors. More accurately they are electronically commutated motors where the external ESC does the commutation and is supplied with the DC power.
So there's no difference at all unless you meant something else by rc and/or dc ?
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 16, 2012, 03:56 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Do you mean, the difference between AC and DC brushless motors?
An AC brushless motor uses AC (Alternating Current) power to generate a rotating magnetic field, which drags the rotor around with it. This can be done synchronously or asynchronously. A synchronous AC motor runs at a fixed speed, locked in phase with the AC power frequency. One problem with this design is that it is not self starting (it needs some other mechanism to get it up to synchronous speed) and if too much load is applied then it may drop out of sync and stop.
Another type of AC brushless motor is the Induction motor. This has copper wires embedded in the rotor, in which currents are induced by the rotating magnetic field. This current produces magnetism in the rotor itself, which then interacts with the stator field to produce a torque which turns the rotor. Due to this induction process, the rotor does not have to stay in sync with the supply frequency, but can 'slip' to a lower speed under load.
A DC motor has to produce its own rotating magnetic field, by switching current through coils in step with its rotation. In a brushed DC motor this is achieved using a commutator and brushes. A Brushless DC motor works just the same way, but with electronic commutation. A sensored BLDC motor has magnetic or optical sensors that transmit the rotor position to the controller. Essentially it is the same as the brushed motor, except that it uses solid-state switches (transistors) rather than a mechanical switching mechanism (commutator/brushes).
A sensorless BLDC motor has no sensors (obviously!) but the controller manages to read the rotor position by detecting the voltage generated on the third wire (each of the 3 wires is powered alternately in a 6 step sequence, but only two wires are powered at any one time). Unfortunately this doesn't work at very low speed or at rest, because the voltage is too low/zero. Therefore on startup the controller just tries to run the motor asynchronously at a low speed, then checks to see if the generated voltage is in sync. If not then it resets and tries again, which may cause the rotor to jiggle back and forth a few times before starting up.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Feb 16, 2012, 10:40 AM
Joined Aug 2011
Steve
Thanks for all of your replies, to be more specific I was curious to what the major differences in these two types of motors were from the perspective of them being used in rc aircraft and scooter/bike applications.
Old Feb 16, 2012, 12:25 PM
Staffs, UK
Joined Nov 2003
Can you be a bit more precise about what two types of motor you're talking about...perhaps links to where you've seen the terms "dc brushless motor" and "rc brushless motor" used ?
Steve
Old Feb 16, 2012, 02:13 PM
elecfryer is offline
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
United States, CA, Camarillo
Joined Aug 2007
To be clear,
Do a search on DC brushless and you will get results for motors!
Do a search on RC brushless and you get NO RESULTS regarding electic motors.
To the best of my knowledge, NO SUCH THING as a "RC BRUSHLESS MOTOR"
For your application, I am sure a Brushless motor will work fine, you just need to find the correct motor.
Michael
elecfryer is offline Find More Posts by elecfryer
Old Feb 16, 2012, 04:24 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
A lot of electric bike conversions actually use large brushless motors that are sold as RC aircraft motors. The motor doesn't know what it's powering, obviously, so as long as it's used within its electrical and mechanical capabilities it'll do whatever you tell it to. Since most of these conversions use sensorless motors, folks often add Hall effect sensors to gain control at the very low RPMs that these motors may need to run at, namely when starting from a dead stop without pedaling.
For dedicated bike motors such as the brushless hub motors that are gaining popularity, you'll generally see them with lower Kv values and higher pole counts than what most RC applications use. This is because it takes a heck of a lot of torque to run something like a 26" bike wheel in a direct-drive configuration, so very low Kv values and are desirable. Weight is another factor; they'll usually be built with the focus set more on structural strength and durability because bike wheel hubs need to stand up to a lot of abuse. RC planes are a relatively cushy home for them as far as mechanical stress, but we do regularly push them to the edge of their electrical abilities.
From an operational standpoint, they're identical. Both RC aircraft and bike/scooter motors require a source of external commutation in the form of an electronic speed control and both involved fixed windings and rotating permanent magnets.
Piece is offline Find More Posts by Piece
Old Feb 16, 2012, 05:10 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
I'm still wondering why people call the RC brushless motors DC (which I do as well)- they're 3 phase AC!
( tongue only a little in cheek- the differences between brushless DC and brushless AC 3-phase are subtle but there )
CNY_Dave is offline Find More Posts by CNY_Dave
Old Feb 16, 2012, 05:25 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
DC motors are really mechanically commutated ( commutator & brushes ) AC motors.
That is why there is a armature & brushes. To cause switching & repulsion.forces.
DC flows ONLY in 1 direction AND is held at a constant potential..voltage.
AC is everything else.
Edit & a question
Is there REALLY a DC motor ? 1 guess
cyclops2 is offline Find More Posts by cyclops2
Old Feb 16, 2012, 05:37 PM
CNY_Dave is offline
Joined Sep 2010
Old Feb 16, 2012, 08:49 PM
Joined Aug 2011
This is what I was looking for, so wouldn't scooter motors being built to handle the weight of the contraption and the rider themselves while rc plane motors are basically designed for the plane itself? Would the large weight difference cause the rc plane motors used on a scooter/bike to over work itself? Is one more preferable than the other for it's respective application?
Old Feb 16, 2012, 11:27 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
The only major difference is that a motor designed primarily for use in planes will probably need to power your scooter through a chain or belt drive to prevent the motor's bearings from having to support the scooter's weight and absorb shocks from bumps amd such. They can't take physical abuse like that, but electrically the motor will work fine as long as you don't force it to draw more power than it can handle.
Depending on the motor's Kv and the battery used, the drive setup may need to incorporate some reduction gearing.
Old Feb 17, 2012, 10:39 AM
Joined Aug 2011
Excellent thanks for the explanation!
Old Feb 17, 2012, 01:16 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Do any of these threads help if it's a bike orientated question -
Electric Bike
Help! Is this battery suitable for my E-bike?
RC Motors/controllers for E-bike
What would be a good power system for a mountain bike?
eflightray is offline Find More Posts by eflightray
Question Differences between old Super Tigre engine models? JROMA Engines 11 Jul 09, 2014 01:48 PM
Discussion Nimh vs Lipo - differences between them babanan Batteries and Chargers 3 Dec 07, 2011 05:19 AM
Discussion Differences and similarities between iron-on films SBS_Pilot The Builders Workshop 8 Sep 29, 2011 12:49 PM
differences between brushed and brushless motors in Motocalc yclui Power Systems 2 Dec 05, 2003 11:13 PM
