| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Guest
Posts: n/a
[EFLT] Tequila Sunrise
This message from JKC0943@aol.com brought to you by EFLIGHT!
Has anyone converted a 25 size Tequila Sunrise from glow to electric? What would be a good motor - battery combo for it. I would rather have too much power than not enough? Thanks in advance for any help I can get. Jim Couser --- StripMime Report -- processed MIME parts --- multipart/alternative text/plain (text body -- kept) text/html --- *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#2 |
Guest
Posts: n/a
RE: [EFLT] Tequila Sunrise
This message from "Chuck Baker" <indyrcpilot@comcast.net> brought to you by EFLIGHT!
I've flown a glow powered version, and wouldn't recommend it for electric. The airframe is too heavy and the wing too small/thin... My $0.02 worth... Chuck in Indy -----Original Message----- From: owner-eflight@ezonemag.com [mailto wner-eflight@ezonemag.com] OnBehalf Of JKC0943@aol.com Sent: Monday, October 13, 2003 5:56 PM To: eflight@ezonemag.com; sfrc@airage.com Subject: [EFLT] Tequila Sunrise This message from JKC0943@aol.com brought to you by EFLIGHT! Has anyone converted a 25 size Tequila Sunrise from glow to electric? What would be a good motor - battery combo for it. I would rather have too much power than not enough? Thanks in advance for any help I can get. Jim Couser --- StripMime Report -- processed MIME parts --- multipart/alternative text/plain (text body -- kept) text/html --- *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#3 |
Guest
Posts: n/a
Re: [EFLT] Tequila Sunrise
This message from LVRCFlyer@aol.com brought to you by EFLIGHT!
Unfortunately, I think the Tequila Sunrise 25 is far too heavy to make a good electric. Even as glow its already heavy for its size, and as an electric, even with LiPos, itll be around .5lb heavier. Most 25 ARFs built today are much better suited conversions because they are built lighter and generally a tad larger. If you do decide to convert anyway, an 8-10 cell (or 3s LiPos) set up will be the way go. Something like the Aveox 27/26 series motors, Mega 22/20/2 or 3 or a Hacker B40/C40 motor geared would all work quite well. Id suggest gearing them 4:1 or up to 6:1 on 10 cells. Power would be like that of a good 25-40 engine, but it would still be heavier than glow by .5lb on LiPos or almost 1 full pound on NiCad/NiMh sub Cs. Its a good idea to download Motocalc and run some numbers to find what you like: http://www.motocalc.com Good luck! Jason *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#4 |
Guest
Posts: n/a
In a message dated 10/13/2003 7:03:06 PM Central Standard Time, LVRCFlyer@aol.com writes: > Its a good idea to download Motocalc and run some numbers to find what you > like: Thanks for the thoughts Jason. I did check and found that if I can keep it about 59 oz, it should fly. The plane was crashed by its previous owner before I got it, and I have cleaned the inside of the fuse pretty good. However its still a bit too hevy with the heavy tail feathers and fin on the bottom.. The wing seems a little too heavy also. Thanks for your reply. Oh BTW I was thinking of using a Astro 15, with 12 cells. what do you think. Jim Couser --- StripMime Report -- processed MIME parts --- multipart/alternative text/plain (text body -- kept) text/html --- *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#5 |
Guest
Posts: n/a
This message from "John Snider" <torkit@mindspring.com> brought to you by EFLIGHT!
You might consider a 75mhz radio for the 'Sunrise. It would save a little weight. (but not enough) *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#6 |
Guest
Posts: n/a
This message from Paul Goelz <pgoelz@eaglequest.com> brought to you by EFLIGHT!
At 07:55 AM 10/14/2003, you wrote: >You might consider a 75mhz radio for the 'Sunrise. It would save a little >weight. (but not enough) At about 7 grams the Berg4 is about as good as it gets on 72 MHz. Paul Paul Goelz Rochester Hills MI USA pgoelz@eaglequest.com http://www.pgoelz.com *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#7 |
Guest
Posts: n/a
This message from Pete Foss <petefoss@yahoo.com> brought to you by EFLIGHT!
--- John Snider <torkit@mindspring.com> wrote: > This message from "John Snider" <torkit@mindspring.com> brought to > you by EFLIGHT! > > You might consider a 75mhz radio for the 'Sunrise. It would save a > little > weight. (but not enough) > > Why would a surface use only radio be lighter than a legal aircraft radio? ===== Pete Foss Skymasters RC of Michigan http://www.skymasters.org *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#8 |
Guest
Posts: n/a
This message from Erica and or Rob <elfwreck@idiom.com> brought to you by EFLIGHT!
On Tue, 14 Oct 2003, Pete Foss wrote: > --- John Snider <torkit@mindspring.com> wrote: > > You might consider a 75mhz radio for the 'Sunrise. It would save a > > little weight. (but not enough) > > Why would a surface use only radio be lighter than a legal aircraft radio? Hey now, Because he's building a car with wings? RobII *'`'*.,.*'`'*.,.*'`'*.,.*'`'*.,.*'`'*.,.*'`'*.,.*' `'*.,.*'`'*.,.* elfwreck@idiom.com Erica Frank & Rob Carter II "It ain't gonna fly Orville" -Wilbur Wright *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#9 |
Guest
Posts: n/a
This message from "Ted Temer" <temer@c-zone.net> brought to you by EFLIGHT!
Rob: Sadly--I have to agree with you. It will be a car with wings. And it must be one of those Chevy "rock" things they talk about on TV. A quick check shows a wing loading of somewhere between 25 and 30 ounces per sq.ft. on a tiny little wing whose Reynolds's Number must be appalling. I am quickly learning that once one gets past the novelty and ease of use, electric airplanes are like any other. Sometimes we tend to get carried away with the electric part and forget about basic aerodynamics. The old axiom of aviation that bigger flys better still holds so very true. Has to do with how far we push those air molecules around. 25 oz/sq.ft. on a 500 sq. in. ship would be no big deal. But on 280 sq, in. that wing loading will be a tip stalling killer. Any little excess of "up-elevator" and the ship goes nuts. I would certainly advise that if one likes the design--then scale it up about 150% and use foam as the prime construction medium. And for goodness sake, give that poor airfoil some thickness to work with. An overpriced two cents worth ... Best wishes Ted Temer AMA 86837 Pres. Anderson Park Flyers Temercraft Designs Redding, CA temer@c-zone.net www.temercraft.com/novels/ www.andersonparkflyers.org > > Hey now, > Because he's building a car with wings? > RobII > *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#10 |
Guest
Posts: n/a
This message from "John Swetland" <jbswetland@msn.com> brought to you by EFLIGHT!
It will be a car with wings. And it must be one of those Chevy "rock" things they talk about on TV. Ted, that was very good. John S. --- StripMime Report -- processed MIME parts --- multipart/alternative text/plain (text body -- kept) text/html --- *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
#11 |
Guest
Posts: n/a
In a message dated 10/14/2003 11:41:41 AM Central Standard Time, temer@c-zone.net writes: > 25 oz/sq.ft. on a 500 sq. in. ship would be no big deal. But on 280 sq, in. > that wing loading will be a tip stalling killer. Any little excess of > "up-elevator" and the ship goes nuts. > Hello All - this is the kind of honesty I was hoping for. My thanks to all that gave their 2 cents on the Tequila Sunrise. I am positive you have saved me time - money and frustration. It's a cute airplane, but not that cute. Thank You all again Jim Couser --- StripMime Report -- processed MIME parts --- multipart/alternative text/plain (text body -- kept) text/html --- *** Any complaints or problems? Send an email to monitor@ezonemag.com *** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm *** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm |
| Thread Tools | |
| Global Tequila Sunrise electric conv. | tomi | Sport Planes | 5 | Oct 21, 2003 09:02 AM |
| global tequila sunrise .40 arf | 48chebbie | Sport Planes | 1 | Apr 19, 2003 09:52 PM |
| global Tequila Sunrise 25 e-conversion? | DEATHspiral | Sport Planes | 1 | Apr 15, 2003 09:35 PM |
| Tequila Sunrise 40 balance point | Tom G. | rec.models.rc.air | 0 | Jan 09, 2003 10:42 AM |
| System for Tequila Sunrise | rroback | Power Systems | 3 | Dec 02, 2002 12:58 PM |
