Old Feb 15, 2012, 10:16 AM
Frazz is offline
Find More Posts by Frazz
Sardinia, Italy
Joined May 2009
Nunchuck stand alone TX
Hi, guys.
I build this arduino super simple nunchuck r/c stand alone TX compatibile with futaba modules and based on Flytron's Lay-Z open source project.
I made it with an arduino nano , a case and some junk that i had at home.
It works fine with all the Futaba compatible module that I have except Spektrum. The strange thing is that module works if I use it on my 9c and I send the PPM signal by the trainer port
What do you think? Melih from Flytron says that probably depends on the channel count because spektrum module accepts only and entirely 8ch. I tried to increase it on the code without success...
sandro
http://www.flytron.com/pdf/layz_nunchuck_rc.zip
http://www.flytron.com/open-source-h...lus-board.html
Frazz is offline Find More Posts by Frazz
Old Feb 20, 2012, 05:42 AM
yurip is offline
Find More Posts by yurip
Moscow, Russia
Joined Dec 2006
Futaba transmitters in PPM mode only have 8 channels. Spectrum modules can be understood 6,7,8 and 9 channels, look in the thread http://www.rcgroups.com/forums/showt...1147689&page=4 , maybe it depends on the firmware version of the module
yurip is offline Find More Posts by yurip
Old Feb 21, 2012, 04:51 AM
Frazz is offline
Sardinia, Italy
Joined May 2009
Thank you, Yurip. I'm thinkin too that's the problem is channel count, but nothing changes after I modify code increasing channels to 8 (lay-z send default 6ch because the 6 possible controls on the nunchuck) .
Maybe I'm doing something wrong.
I'll do more tests and report here.
sandro
Old Dec 15, 2013, 09:46 AM
geofrancis is offline
Find More Posts by geofrancis
nothing is unfixable
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
what wires go where to use the flytron firmware with an arduino board? or do you have a photo of the underside of your pcb?
geofrancis is offline Find More Posts by geofrancis
Old Nov 17, 2014, 12:37 PM
Avioron is offline
Find More Posts by Avioron
Joined Nov 2014
Hi frazz can u give as the scheme to the layout , and the code ?
I would like to build one .
Thanks .
Avioron is offline Find More Posts by Avioron
Old Dec 02, 2014, 02:38 AM
pierrotm777 is offline
Find More Posts by pierrotm777
pierrotm777's Avatar
France, Aquitaine, Villenave-d'Ornon
Joined May 2014
Very nice project
pierrotm777 is offline Find More Posts by pierrotm777
Question Stand-alone Telemetry system? bigdealaerospace UAV - Unmanned Aerial Vehicles 2 Oct 21, 2011 05:57 PM
Discussion Setting up a stand alone pitch controller redboat219 Submarines 2 Sep 18, 2011 11:49 PM
Question Stand alone fail safe unit (failsafe) igorek82 Radios 5 Jul 01, 2011 09:24 AM
Question Stand alone fail safe unit (failsafe) igorek82 FPV Talk 0 Jun 30, 2011 11:23 AM
Discussion What isthe best stand alone gimbal gyro? milo12 Aerial Photography 1 May 30, 2011 02:25 PM
