Old Feb 15, 2012, 07:35 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Scratch Built Balsa Wing (Build Log)
Hello everyone, I thought I'd like to try building a balsa wing.
I chose a Sipkill 1.7/10B foil.
Ive got the planform drawn out, ribs cut and starting on assembling the wing .
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Feb 15, 2012, 08:46 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Are you building without a jig? It's hard to get all the ribs aligned vertically without one. Could cause some control problems.
--Norm
nmasters is offline Find More Posts by nmasters
Old Feb 17, 2012, 05:58 AM
Joined Jul 2007
--Norm
The notches in the ribs are nice and firm when the strips and slotted in,
I then use a square angle to adjust each one while putting a little glue on to lock it and stop it from moving.
Old Feb 17, 2012, 11:13 PM
bd5wingnut is offline
Find More Posts by bd5wingnut
bd5wingnut's Avatar
Austin, Texas
Joined Dec 2005
You are doing fine, don't let the ney-sayers stop you. It is nice to see someone taking up the challenge/fun of an old school build. The rib alignment is not that critical, good tight glue joints are. Do not compensate for a poor fit with glue, it just adds weight and very little strength. Looks like a decent amount of wing area for a nice stable flyer.
Best of luck.
Peace, Wolf
bd5wingnut is offline Find More Posts by bd5wingnut
Old Feb 18, 2012, 11:47 AM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Best of luck.
Peace, Wolf
I'm not sure if you are saying that Norm is a ney-sayers. I can tell you first hand that is definitely not the case. I can also tell you first hand that rib alignment can be very critical on swept flying wings. Not trying to pick a fight just adding my two cents.
I too like the "old school" wood build. Take a look at some of my build and you'll see that's the case.
Cheers!
Brian
cpdude is offline Find More Posts by cpdude
Old Feb 18, 2012, 12:32 PM
grumman5277 is offline
Find More Posts by grumman5277
grumman5277's Avatar
Troy ,OH
Joined Jan 2004
sure you may already know this ,but what Norm is referring to is the dihedral/ anhedral as well as and twist that should be there.I have played with this airfoil a long time ago and it does very well with symmetric profile. it doesn't need twist if using winglet's,but twist may not be a bad thing ether.
Not sure how this would do built flat.
Good luck,glad to see the old school balsa as well.
grumman5277 is offline Find More Posts by grumman5277
Old Feb 19, 2012, 01:39 AM
bd5wingnut's Avatar
Austin, Texas
Joined Dec 2005
Someone (Norm) said he would need a jig to get the ribs aligned correctly, that is just plain bull... Yes, the leading and trailing edges need to be aligned properly but that does not require anything more than simple blocks placed under either the leading or trailing edge. I built for decades without a jig for the rib placement. matters not whether the wing is straight, swept, tailless, etc.. If they are eyeball straight then go for it, if they look crooked then adjust till they look right. The important thing is tight glue joints.
A warp free wing is simple and does not require anything complicated to achieve. Just knowledge.
Proper washout? Peice-o-cake, no rib jig in sight.
Old Feb 19, 2012, 08:38 AM
Joined Jul 2007
Originally Posted by cpdude View Post
I too like the "old school" wood build. Cheers!
Brian
Yea I know what you mean.
To many people will buy a radian ( Or whatever ) slot the wing halves in place, then slide the tail in while they proceede to tell everyone that it was
an "Easy Build" despite the fact that they didn't actually build anything!
Planes like this get alot more attention at the field than store purchaced ones.
One thing that I've found is that the glue can warp the frame when its drying, so I always pin it in place.
Next step is the Winglets!
Old Feb 19, 2012, 09:16 PM
bd5wingnut's Avatar
Austin, Texas
Joined Dec 2005
Pins are a good idea for sure, but if the glue joints are free of slop then there should not be any movement. Are you using aliphatic resin or...? CA's will help speed things along.
I agree that true "builds" do garner more attention, especially from those who have never done one.
Old Feb 20, 2012, 01:50 AM
Joined Jul 2007
As I mentioned in an pervious post, the joints are tight.
When your joining 2mm balsa, even a tight joint will still let it "pivot".
Im not sure what type of glue it is that I'm using ( Its not here with me)
but its called C23 Balsa Cement.
Ive used it on 4 scratch builds Ive done in the past and its been good.
Old Feb 20, 2012, 05:42 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
C23 is the good stuff
looking good so far.
Robbie d is offline Find More Posts by Robbie d
Old Feb 20, 2012, 10:18 PM
Autotechwagon is offline
Find More Posts by Autotechwagon
Autotechwagon's Avatar
Colorful Colorado Springs, CO
Joined Dec 2010
Do you have a copy of the plans for this? I would be interested in a build of this nature.
Autotechwagon is offline Find More Posts by Autotechwagon
Old Feb 21, 2012, 12:12 AM
bd5wingnut's Avatar
Austin, Texas
Joined Dec 2005
looking good.
But if I may give some advice, you got a little overboard on the amount of glue around the center section. In the close-up, there are some very large glue fillets and the glue covering the aluminum stiffener is just adding weight without any additional strength. Large glue fillets just add weight and very little strength. Adhesives are there to bond two surfaces together and by themselves have no inherent strength.
Rock on.
A thin CA would work much better for most of your work, nice attention to detail on the joints.
Old Feb 21, 2012, 05:34 AM
Joined Jul 2007
No plans exist sorry, its a true Scratch Build!
The closest thing to plans would be the Planform I Used to line the ribs up
which can be seen in the first photo.
you will see that the wing size was actually dictated by the size of paper
that I had to draw on.
Old Feb 21, 2012, 05:42 AM
Joined Jul 2007
looking good.
Rock on.
I used a 5 min epoxy that I don't normally use for the alloy stiffener, it started setting before I was fully ready to apply it so I just slapped it on
as quick as I could!
I prefer the gel epoxys because they don't flow.
You might have noticed the notches in the ribs, thats for when I run the
servo leads.
You may also notice some of the ribs have been sanded incorrectly by
mistake, this has been fixed.
Discussion Scratch build Balsa 20* inch /50CM Delta-wing stonerscolony Flying Wings 24 Mar 14, 2012 06:15 AM
Discussion My scratch built Balsa with carbon fibre Straight Wing (log) The_RattleSnake Flying Wings 20 May 04, 2011 08:29 AM
Discussion Scratch built Depron Ki-61 Hien "Tony" plans and build log Low Pass Foamies (Scratchbuilt) 68 Mar 28, 2010 01:56 AM
Build Log Parkzone Brick Scratch Built Build Log cobra command Scratchbuilt Indoor and Micro Models 41 Aug 28, 2007 07:48 AM
New CF/balsa scratch built wing and scratch mini IFO results... e-sailpilot86 Parkflyers 4 Sep 05, 2002 11:25 PM
