Old Feb 14, 2012, 11:37 PM
Micheal81 is offline
Find More Posts by Micheal81
Georgia
Joined Jan 2009
Question
Slowing Down a Servo
I'm adding flaps to my Parkzone T-28. I'm going to use the Ch 5 switch on my DX5e. I know something like a DX6 would probably be better.
I saw a video where someone used some kind of servo rate reducer to slow down the flap servos. Does anyone here have experience with these? Which would be a good one to get? Will it work fine with the DX5?
Thank you for the help.
Micheal81 is offline Find More Posts by Micheal81
Old Feb 15, 2012, 12:30 AM
Herman Munster is online now
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
Here ya go, last item on the page, the servo go slow. It also can reverse one servo so it might suit both your needs in one unit. I am using this on an aircraft to control the flaps. It's a nice unit, you can control both the deploy speedc and the retract speed independently.
http://www.emsjomar.com/SearchResult.aspx?CategoryID=6
Just noticed, you have to go to page 2, then the item at the bottom
Herman Munster is online now Find More Posts by Herman Munster
Old Feb 15, 2012, 03:08 AM
H2SO4 is offline
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Here's a similar unit to consider:
http://www.hobbyking.com/hobbyking/s...Regulator.html
Just by the way, a DX6i can't do "servo slow".
DX8 does have that functionality. I don't know about the DX7s.
H2SO4 is offline Find More Posts by H2SO4
Old Feb 15, 2012, 03:27 AM
npowell28 is offline
Find More Posts by npowell28
Joined Nov 2010
So do you have to have a certain type of transmitter before you can use a servo slow down unit???? I only ask because i wanted to get one for retracts.
npowell28 is offline Find More Posts by npowell28
Old Feb 15, 2012, 03:32 AM
H2SO4 is offline
H2SO4's Avatar
Joined Jan 2011
You only need the external gizmo if your Tx doesn't have "servo slow" functionality built in.
To get back to the DX6i example, the flaps and gear channels are instant on/off. There's nothing that can be done within the Tx's programming to delay the deployment time to say 3 seconds, and use of those external units - placed in the plane, between the Rx and the relevant servo(s) - is one way to compensate for the Tx's lack of functionality in this area.
A DX8 can delay servo travel according to configured parameters. The Tx itself will slow flaps/gear/whatever deployment by any value up to 15 or 30 seconds (I forget which). The external unit is not needed at all.
Old Feb 15, 2012, 04:12 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
No, you can use any Tx with a separate servo slow device. BUT, servo slow devices only work with standard servos not retract servos.
On my Spit I have used a standard heavy duty servo, (not a retract one), and a Turnigy servo slow.
Here's a link to one - Turnigy 3 Channel Servo Speed/Direction Regulator
If you already have a retract servo, sorry they cannot be slowed.
eflightray is offline Find More Posts by eflightray
Old Feb 15, 2012, 11:47 AM
Georgia
Joined Jan 2009
Thanks for the responses. I believe I'll be getting one for the T-28 flaps. What type of plug do I need. Is it the Futaba J, or JR/Hitec/Z? I think I need the JR/Hitec/Z plug.
Old Feb 15, 2012, 12:26 PM
Glacier Girl is online now
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Only difference in the plug ends is the Futaba has a locator tab on it, so you can only plug it in one way. If you have a JR/Spektrum rx, you just trim off the tab with a razor blade.
Note: if you go with the Hobby King one, you will need one lead with female plugs on both ends, to connect it to your rx.
Glacier Girl is online now Find More Posts by Glacier Girl
Old Feb 15, 2012, 12:41 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Is this for a Parkzone T-28? It doesn't need flaps... dropping the flaps on it will really screw it up. I would suggest getting a better radio anyway if you want to do this kind of thing... I don't even think you can actually do flaps on a T-28 with your radio... how are you going to make both servos go the same way? They are programmed to go in opposite directions and you can't change that.
The DX8 and JR9503 support slow servo movement... if you are wanting to do things like flaps on your planes, you need a radio like that. To sum up... flaps won't do anything worthwhile on your plane, you can't do it with your radio anyway, and a servo-slowdown device mounted to your aileron servo would ALWAYS slow it down, and that would be bad. If you are planning to add two new surfaces and use that for flaps, you still have a problem... you will have to do it with one servo. You need a better radio - there isn't really much of a way around that.
jasmine2501 is offline Find More Posts by jasmine2501
Old Feb 15, 2012, 12:48 PM
Mikey 68 is offline
Find More Posts by Mikey 68
Field of Dreams Flyer
Mikey 68's Avatar
United States, CA, LA
Joined Sep 2004
Yes you can use 2 servos. Theres 3 ways to use 2 servos. 1 is you can buy a reversing servo or 2 you can flip the servo so its facing the same direction like the other one or 3 use a reversing Y connector. That dx 5 has a switch for flaps.
This would be the thing to get because it reverses the servo and slows it down
Mikey 68 is offline Find More Posts by Mikey 68
Old Feb 15, 2012, 12:50 PM
Mikey 68 is offline
Mikey 68's Avatar
Joined Sep 2004
The DX7s also has servo slow down. Flaps are fun on any airplane
Old Feb 15, 2012, 12:55 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Are you sure ?, my Dx7 doesn't.
Old Feb 15, 2012, 12:58 PM
Mikey 68 is offline
Mikey 68's Avatar
Joined Sep 2004
Or you can take a normal servo and reverse it your self
http://web.archive.org/web/200708300...oReversing.pdf
Old Feb 15, 2012, 01:22 PM
Rocket Programmer
Joined Jul 2007
The DX7S is a new radio. The old DX7 didn't have this feature. I believe the DX5 "gear" channel is non-adjustable... so, if you use it for flaps, you're going to have to use it with a separate servo and surface than the ailerons, and you're not going to be able to fine-tune the travel, so your mechanical setup might be more tricky. With a DX6i or better, your ailerons can be the flaps and you can adjust everything so it works exactly like you want.
Old Feb 15, 2012, 01:44 PM
Mikey 68 is offline
Mikey 68's Avatar
Joined Sep 2004
DX7s not DX7
Discussion Slowing Down Electric Retracts jptonks Radios 1 Jan 07, 2012 04:11 PM
Discussion Problem with P40- Engine slowing down at full throttle thercguru Power Systems 21 Sep 18, 2011 04:21 PM
Discussion Slowing down servo's? primer Electric Heli Talk 9 Dec 24, 2009 07:01 AM
