Better Yet i will send the buy site to my kids for a x-mas gift for ME . : And you thought i was realy going to buy it myself . lmao joe
Central Arkansas
Joined May 2010
![]() TonyS |
joe
What are the thoughts on Glue... I am thinking Epoxy... but am open to suggestions... Cannot seem to find UHU Por around here...
As to a motor.. i will use either this one.. http://www.hobbyking.com/hobbyking/s...dProduct=14739 Which does a nice job on my heavy FFF versions, or this one.. http://www.hobbyking.com/hobbyking/s...idProduct=2069 Which I have on my lighter $tree foam version.... With an 800ma battery this motor gives about a 25 minute flight... |
As to glue choice, the perfect match for EPP is polyurethane glue (Gorilla Glue in your country). When set, it is hard. While curing it expands and grows into the foam, thus improving adherence between non-smooth adjoining surfaces. Hot wire cut surfaces, though, tend to be shiny and smooth which need to be sanded finely to break the surface and allow the expanding glue to enter the material. |
Central Arkansas
Joined May 2010
I agree with Pigeonflyer, I have successfully used Gorilla Glue "Dries White" (not the standard brown) for EPP slo flyers, and a couple of larger EPP planes as well. I have also used thick foam safe CA and cool melt glue. TonyS |
Magnum Reloaded kit
Well, I guess this will have to go into the "Kit" threads now, but here are the pictures of the kit I promised from WM park flyers.
I am going to try to get started on it today so I can have it ready for indoor flying this Wed. But seeing as how this is my first foamy kit, I will take it as it comes and fly when it's ready. ![]() I plan on using hot glue for the build. I want to use magnets to hold on the floats instead of the supplied rubber bands. I am going to look for a figure to place in the cockpit, as wild figures are kind of expected in these planes. I am thinking Snoopy with his WW1 fighter gear and scarf. ![]() I'll post updates as it goes along. |
Very happy to see this kit available. Mine was an act of desparation.
Ken
Latest blog entry: MPF M6 Mermaid Scratch and Kit Built
![]() So I started my own build, then ran into questions like, thrust angle and foam type / thickness, etc. and just gave up until I saw the kit finally available. I am pretty excited about getting started, and if I am right and this plane turns out to be as much fun as it looks like on the 'net.....it won't be my last one.
Pilots and Glue
On my first build I used Owens Corning Fanfold (1/4" 6mm) foam and a lot of hot Glue as well as brown gorilla glue and Titebond II wood glue.. both of which dried brown... that is ok if you are careful... Hot glue adds a ton of weight.. so use it sparingly... Subsequent builds I used 3/4" high density foam for the center core of the fuse and pontoons and the wheel/pontoon supports... made things much quicker and lighter. On the last build I used light weight bead board (3/4") for the center cores and Dollar tree foam board with paper removed (4-5mm) for the outer coverings. Also I used Loc-Tite seal and stick contact glue. The end result was a very light and durable plane.
For pilots, I went to WalMart toy section and got the little soft plastic creatures, which I used in the closed cabin models.. for #5.. the open cockpit model I went to the Family Dollar and got "Trixie" With long blond Hair... In my biplane I made a foam Snoopy from Chara's thread. Here are some pictures of my pilots... If you want the link to snoopy let me know and I will find it for you... All of the various pilots seem to be able to fly the crafts very nicely... Trixie likes to hit the shore... Here is a 1.6 minute video showing the problem with magnets holding on the pontoons... I have had good luck with magnets, but some times it takes a little more...
One more comment.. Motor angle is very critical on this model (perhaps on all models)... each of my five have taken a lot of washers added under the motor mounts to get it right... but when landing on the water, it sure is nice to have the correct thrust angle... I assume on the kit it will not be a lot different, as each builder will mount the motor a little differently, esp if using hot glue which is my preference for motor mounting... but so using, the seam between the foam and the wood will vary in thickness from one side to the other, necessitating some washers to be added to adjust the angle..
Another tip... be sure before your first maiden flight that your CG is in the right place.... My first one was way off and it was almost her two flights in one (First and Last) |
| Thread Tools | |
| Discussion magnum reloaded epp fun plane | Flymax12 | Waterplanes | 26 | Jan 30, 2013 01:42 PM |
| Discussion Magnum Reloaded | BigD1961 | Foamies (Scratchbuilt) | 36 | Feb 26, 2012 07:21 PM |
| Discussion Big Swamp Buggy - RELOADED- for electric power | MarcAntonio | Dock Talk | 4 | Mar 18, 2011 01:08 PM |
