near Chicago
Joined Apr 2008
MicroTelemaster Kit V2 Build Log
I haven't built a balsa airplane in a long time and I thought it time to do it again. So I looked around & discovered there aren't many kit manufacturers left. The few that are around seem to have some interesting kits. Just about all of them are laser cut balsa & plywood. Foamies are the other big kit group. After a lot of research & waiting for stuff to get back in stock, I finally decided to try the Hobby Lobby International Micro Telemaster V2 high wing 3 channel electric power park flyer trainer.
http://www.hobby-lobby.com/micro_tel...37165_prd1.htm It has a 34 ½” wing span, it’s 24” long, has a flying weight of 6-9 oz, a wing area of 186 sq in. The recommended power plant is a park 250 brushless motor, a 8 x 3.8 APC prop & a 2 cell (7.4v) 800 mAH LiPo battery. So I ordered it on their website and in a few short days I had it. The kit was in a box with a lot of packing material and arrived safely. I couldn’t wait to get going! Please see the pictures I’ve included for a lot more detail. I built it in my spare time, evenings and weekends. This build log does not include covering the model as this is covered (pun intended!) elsewhere in great detail. I will add some pics of the covered model when I finally get it done. The biggest deviation I did from the instructions was to not use CA for the glue. I’ve always used Ambroid and I happen to have a couple of tubes laying around and decided to use them. I will say the next kit I build I will try the CA because I had forgotten how difficult it was to clamp balsa while the glue was drying. It’s an extremely soft wood and breaks, crushes and deforms pretty easily. On the other hand, it is extremely easy to work with and repair. There’s always trade offs! This is a list of the tools I used to build the kit. You may not need them all. I already owned them so I used them. Hobby knife with a lot of #11 blades Razor saw and miter box Ambroid liquid cement Various grades of sandpaper & a couple of different sandpaper blocks Straight pins Flat surface building board that will accept pins being pushed into it Pencil A small metal square Small woodworkers plane (I used a Stanley) Small files for working on the plywood Wax paper to glue over the plans A sturdy work table with plenty of room! A note on the pins: the instructions said to use push pins. The ones I had are for use on corkboards & the pin side was pretty thick & split the thin balsa. There are thin push pins available but I had hundreds of straight pins that work just as well. A pair of small needle nose pliers or equivalent will help drive the pins into the building board I had previewed the build manual on line before I bought the kit so I knew what I was getting into. However, I believe this is a new version of the kit and there where some rough edges showing. I’ll describe those as I go along the build. First I’ll start with the instructions. On the site they were in color. In the box, they were a laser printed copy in black & white! The pictures where a bit fuzzy and I wished I had a laptop to bring into the workshop to view the online manual. Besides the manual there was an Inventory Check Off sheet, a Part Locator sheet, a full size plan drawing and an errata sheet for the full size plans As suggested in the manual, I took an inventory of the parts against the kits parts list. Everything was there. However, the pushrod wire was listed as 0.047” & the wire in the kit was 0.031”. An email to the vendor went unanswered for a week when I sent a 2nd one about more problems. That one was answered. 27FEB12 NOTE: I just spoke to the model MFR who said the error was the 0.031" wire & is sending evertbody the CORRECT 0.047" wire! 1MAR12 Update = got the replacement pushrod today & it's the WRONG SIZE!! What ever happened to quality? Let me warn you before you start that the manual says the laser cut parts are easy to remove from the carrier; in fact some can just be pushed out by flexing. DON’T DO IT!! The backside of the balsa was not cut all the way into the corners and if you just flex & push on the pieces, there is a strong likelihood you will break the piece. Use the hobby knife to score both sides of the piece you’re trying to remove – don’t skip this step! The website was pretty vague about what does and does not come with the kit. There is no covering material. There are no electrics. However, there is all the hardware you’ll need including the pushrods, the landing gear wire, the servo horns, servo pushrod connectors and the servo horn connectors. The wheels are included and are made out of foam which needs to be glued together and shaped. The wheel hubs are laser cut plywood. Here are some of the problems I found almost right out of the box. 1. Step 3 shows a “Building Square” made out of plywood. It was not in the box. The vendor said to use the leading edge gauge for the square. I used a nice metal one that wouldn’t get glued to the airplane! 2. Step 11 a. the fuselage bottom sheet cutouts for the landing gear were off so I had to make them larger to get the piece to fit. I later added a small filler of scrap to make it look neat when I covered it b. before trying to fit this piece, squeeze the tail end sections together & you’ll notice the bracing is too thick. A little careful sanding allowed the 2 pieces to join properly 3. There was a step missing to glue in the angled wing braces (g). Do this before you remove the wing from the building board 4. There were some parts that were called the same initials but where 2 different parts. And then there where initials that were for the wrong part. Just follow the pictures & double check on the full size drawing for what they are and how they fit 5. There were parts left over when the instructions ran out! a. FBB – never told to glue it on the bottom inside of the fuse. I don’t know what this piece does but I put it in b. ND (nose doubler) – never told to glue these in. I did near the end of the build 6. This being labeled as a beginners kit, I expected a lot of info on finishing the model. There was none. There was nothing about hinges or mounting the electrics or setting up the airplane. 7. [NOTE: my mistake there are cutouts for the rudder. I could not find them with the covering on. So please note their location when covering the tail. I apologize for this mistake! clp} 8. There is a short section about balance and center of gravity. 9. Cut or sand a small notch in the fuselage magnet holder piece (RWM) to match the curve of the wing to make the magnets work. Do this after covering the wings. 10. I added some extra support for the fuselage top piece. See pic The build went quickly and with only minor problems mostly caused by me. I can recommend this as a build kit. However, I built it in the dead of winter with cold & snow & winds so I have not flown it yet. I will post a link to the maiden flight when that happens. Comments and questions are always welcome. The 1st pic is the build almost complete! Chuck |
| Thread Tools | |
| Build Log Z55 V2 Build & Flight Log | KJMDES | Slope | 68 | Dec 25, 2012 06:28 AM |
| Discussion 5 CH 2.4GHz BlitzRCWorks A-10 Warthog Thunderbold II V2 ) - Build Log | Robert410 | Foamy EDFs | 4 | Mar 12, 2012 07:30 AM |
| Discussion Piper Cub Build Log (Dumas Kit) | iCurtis | Free Flight | 8 | Oct 04, 2011 08:22 PM |
