I switched to Press N' Seal instesd of plastic wrap or wax paper. You can stick it down on the plans and it stays put. It also doesn't lift up making it difficult to read the plans. Used it on my last 2 builds. Good stuff.
As for the CA for holding sheeting to the spar. .. No big deal there. I wouldn't use it on the main structure of the spar. You are good. Your doing a great job. Kurt |
United States, ND, Fargo
Joined Aug 2007
to reference something that got covered. Quote:
I have no idea where to find lead bars. I'm just worried my airfoil will be slightly off and blah blah crash snap etc. I really would like to know what I should be using to bevel the trailing edge. the sanding block is definitely not the best solution. It works, but it isn't accurate or uniform by any means. Should see some progress tonight or the next two nights depending on my energy level. |
Clearlake, CA. USA
Joined Jun 2000
Hi You couldn't have made a better choice than the L.Bird... Your gonna love how it flies. Build per plan but trial fit as mentioned early... the paper moves due to the weather etc... the laser cut parts are cut exactly.. just ensure that both halves are the same....
Wylie |
| Thread Tools | |
| Discussion Looking for a good 2M Lil Bird build thread. | johnwohl | Thermal | 2 | Feb 14, 2012 06:11 PM |
| Help! Lil Bird 2M: sheeting and leading edge mystery | kurtenstein | Thermal | 8 | Feb 08, 2012 11:45 PM |
| Help! Lil Bird 2M: sheeting and leading edge mystery | kurtenstein | Sailplane Talk | 10 | Feb 08, 2012 07:08 PM |
| Help! 2M Lil Bird wing construction, help needed! | kurtenstein | Sailplane Talk | 4 | Feb 04, 2012 05:01 PM |
| Help! Building a Lil Bird 2M | kurtenstein | Sailplane Talk | 5 | Jan 19, 2012 11:10 PM |
