Old Feb 14, 2012, 06:21 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Efficiency test : hexTronik DT700 and 24 propellers - GWS 9x5x3 added
24 propellers: 10 APC, 2 EPP, 5 GemFan, 2 Graupner, 4 GWS and one HobbyKing.
Fixed parameters:
Motor: hexTronik DT700 11.1V, max 13A.
Batteries: Turnigy nano-tech 3S 4000mAh 35-70C, fully charged before each test
ESC: Hobbywing Pentium 30A - Timing mode: Middle
Turnigy Servo Tester and GWS Servo Tester MT-1
Junsi PowerLog 6S Wattmeter - LogView software - Soehnle scales
These measuring devices are not lab grade but are suitable for a comparison.
Tests have been made in two steps:
1 - Half throttle, most significant, usually used for hover
2 - WOT, maximum thrust and current
The Turnigy Servo Tester used has a fixed center position giving a 1.486ms pulse.
Max pulse is 1.976ms.
Graupner props were not as efficient as expected with this motor.
They have been tested twice to confirm.
Here is what I've got:
Mortimer is offline Find More Posts by Mortimer
Old Feb 14, 2012, 06:26 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
24 propellers:
Old Feb 14, 2012, 07:47 PM
W,,,,,,,,,,,,,,,,,,,, is offline
Find More Posts by W,,,,,,,,,,,,,,,,,,,,
LoS sUAS AP/V is not a crime.
W,,,,,,,,,,,,,,,,,,,,'s Avatar
Grass Valley, CA
Joined Feb 2008
Great job! Thank you for the useful information.
W,,,,,,,,,,,,,,,,,,,, is offline Find More Posts by W,,,,,,,,,,,,,,,,,,,,
Old Feb 15, 2012, 02:08 AM
thepelell is offline
Find More Posts by thepelell
Italia, Piemonte, Biella
Joined Feb 2011
very good. Thank you. If you have a chance, can you try out Xoar wooden props too? they make 10x5 CW and CCW .
thepelell is offline Find More Posts by thepelell
Old Feb 15, 2012, 03:26 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Do all the props tested come in CW and CCW to suit multi-copters?
Erknie is offline Find More Posts by Erknie
Old Feb 15, 2012, 05:01 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
EndOfDays is offline Find More Posts by EndOfDays
Last edited by EndOfDays; Feb 15, 2012 at 10:08 AM. Reason: gone away, keeping the world perfect.
Old Feb 15, 2012, 06:22 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
very interesting stuff and thank you mr M with those numbers i think i could plan a build rom a whole new angle now TY
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Feb 15, 2012, 08:02 AM
ozanozkok is offline
Find More Posts by ozanozkok
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Thank you Mortimer.Very good job.
may i ask two questions?
1-what about dt700 motors vibration?
2-what about differences with dt750?did you use any dt750?
ozanozkok is offline Find More Posts by ozanozkok
Old Feb 15, 2012, 09:28 AM
Grass Valley, CA
Joined Feb 2008
Knowing what RPM the said prop hits it’s thrust ‘sweet spot’ would be useful but to call Mortimer’s work ‘nut sure if this result is useable’ and ‘nice and interesting to do, but does not help’ is uncalled for.
He spent a lot of time getting these numbers for us, use them or go away.
Old Feb 15, 2012, 09:38 AM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
nothing is usefull. this stats does not make ANY sence in the real life flying.
man1024 is offline Find More Posts by man1024
Old Feb 15, 2012, 09:57 AM
man1024 is offline
man1024's Avatar
Joined Oct 2011
Also GemFan has 12x4.5 version.
Old Feb 15, 2012, 10:24 AM
n3m1s1s is offline
Joined Feb 2007
well if a stupid person were to pick ANY of the above props then look at the thrust numbers and times them by four then build a quad to that weight wouldnt they then hover at center stick? while drawing 4x times the amp draw numbers? meaning they would know which lipo to pick to deliver needed amp draw while staying under a certain weight?
or
times listed thrust by 4 build quad lighter than number you get and know you have built something that DEFINATLY has enough thrust to fly?
looks pretty usefull to me
Old Feb 15, 2012, 10:47 AM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
Great, very useful info
thanks for the efforts
TeeJayBee is offline Find More Posts by TeeJayBee
Old Feb 15, 2012, 10:50 AM
Joined Mar 2011
or
Forgive me but I thought to FLY the weight should not exceed half of the thrust, i.e. 4 x 1000g (max thrust) = 4kg so craft should not be heavier than 2kg ALL UP WEIGHT inc battery, camera etc
Old Feb 15, 2012, 11:20 AM
n3m1s1s is offline
Joined Feb 2007
which is why the data is so good Mortimer did the 1st set of thrust numbers at 50% throttle the other set of numbers are at full throttle
so if you read his post then read my last reply using the 1st set of thrust numbers your good to go
Discussion How the difference hextronik dt700 and Dt750? fabiocr Electric Motor Design and Construction 1 Feb 08, 2012 07:22 PM
Sold 4x Brand New DT700/6246 hexTronik DT700 Brushless Outrunner 700kv daign Aircraft - Electric - Multirotor (FS/W) 3 Sep 22, 2011 01:07 PM
Discussion hexTronik 24 gram motor measurements? shockflyer12345 Multirotor Talk 8 Jul 05, 2011 11:02 PM
Sold 2 NEW hexTronik DT700 Brushless Outrunner 700kv mattyhawk Aircraft - Electric - Power Systems (FS/W) 0 Jun 23, 2009 04:27 PM
