If the plane is pitching up for no reason without TX imputs then something is definately wrong!
I'm not liking this I will be using DX6i which I know you do as well Bob; what TX are others using whom are having issues? If the plane was loosing speed or going to slow and stalling, would the nose not go down and then into a dive or flat spin maybe? That's what my F86 Jpower POS did! Are the fan units good and secure, thrust angle not off? Bob For a test Somehow afix the aircraft on a desk, run the unit as if you were flying and record what the RX unit is doing Perhaps do this; but also as a range test as well! |
Latest blog entry: Estes Rubber Band Condor gets powered...
I hope mine isnt like this or I'll be pissed right off
I thought this was supposed to be a good flyer even without as3x? You would think that the claim of "slow flying ability" would mean it has a low and not high stall rate I really hope these are isolated incidents |
Hey guys,
From watching your videos and reading everyone's flight descriptions I believe you are encountering an issue I had while trying to low speed Harrier the F86. What I believe was happening is the wing is blanking out the elevator at a specific speed and angle of attack. To correct this I have added some ventral fins to the bottom of the fuse. RJ gritter and myself added these to our F86s at efest while exploring the flight envolope ![]() I attached some pictures to better explain what we did. Give them a shot and take it up high to play with the low speed characteristics to get a better feel for it. I will try to take some video of mine soon. ![]() Devin McGrath Sent from my Android |
Canada, ON, Muskoka
Joined Jul 2011
![]() Glen |
Mine flew great from the first launch. Pay attention to airspeed and AOA when you fly and there won't be a problem. It's really a very gentle airplane overall. In some of these videos it's unclear to me whether the pilot is controlling the plane or whether the plane is controlling the pilot. If the pilot gets behind the plane you can't blame the plane since the pilot isn't on top of it. Maybe it's a CG issue....?
United States, TN, Jackson
Joined Mar 2007
...Ventral fins will help with directional yaw stability if the vertical stab is blanked out at high AOA but I don't see them doing anything for the horizontal stab/elevator...The larger ducted fan versions of the Sabre that I've owned didn't have this problem...On landing the Sabre elevator was very responsive even with full flaps deployed...My guess for some of the issues described here is that the plane is stalling due to too much elevator combined with a slightly aft CG placement... Kevin |
I'm going to try this first,,, I don't care for planes that use the elevator to hold the nose down I like mine to be used to hold the nose up,, that way if the elevator gets blanked out by the wing the nose will drop and pick up speed lowing the AOA and regaining flying speed and not pitch up into a stall..
On my scale stock battery is 13.47g, Hyperion 240 is 16.08g and the HK 400 is 22.78g. Yes the canopy still fits.. CG isn't really moved that much but I'm still checking it.. |
That is correct but you have to look at why it is tail heavy at that point it is tail heavy because the elevator is no longer acting like a lifting surface. The center of lift is just as important as the center of gravity. You are changing the center of lift while in flight so drasticly that you would have to add a ton of nose weight to compensate and then you have another problem. You are flying around 99.9% of the time with an airplane that is unhappily nose heavy
Also The ventral fins because of there angle in relation to the direction of flight, help to push the airplane back into its normal AOA when you have gone to far. Please excuse my poor explanation typeing on your phone never comes across correctly.Devin McGrath Sent from my android |
| Thread Tools | |
| New Product Great Planes 30mm Brushless Micro EDF F-86 Sabre! | NitroCharged | Micro EDF Jets and Power Systems | 2336 | May 19, 2013 09:01 PM |
| Article Great Planes F-86 Sabre Micro EDF with AnyLink Review | CSpaced | Micro EDF Jets and Power Systems | 242 | Mar 24, 2013 03:14 AM |
| Article FIRST SIGHTING: Great Planes F-86 Micro Sabre at the Arizona Electric Festival | Michael Heer | Micro RTF | 31 | Jan 09, 2013 06:49 PM |
