I have tried in vain to get the news out. There are many forum and sub-forum areas here on RC Groups. If one post a question in the most appropiate forum then a correct answer is more likely.
It seems that Goggle ,Chrome, MS, and all other Search Engines bring all answer sseekers to this B & C Forum . Go here and post your question if you can not first find an answer there by using the Search perhaps. http://www.rcgroups.com/micro-edf-je...r-systems-650/ Charles |
Well as you have already found out there are not any 35-65C 120-160 or even 180-240 LiPolys available as yet. The Micro EDF guys are the ones in the know . I have tested several 25C 1S and 2S LiPolys in the 120 to 240 mAh range and posted the results.
The Battery Graph Vault seems to remain completely unknow to many. ![]() Smallest ProPowers I have used are 850 and smallest I have tested extensively is the 2250. TP Pro Power 45C smallest is 325 Seems like 325 is the smalest high C TP has. http://rclipos.com/ThunderPowerPro45C.htm Same with TP Pro Power 65C http://rclipos.com/ThunderPowerPro65C.htm Charles |
| Thread Tools | |
| Discussion Best Charger For Multiple 1S Micro Heli/Airplane Lipo's | a1seller2you | Batteries and Chargers | 3 | Jan 26, 2012 12:38 PM |
| Sold Eflite celectra 1s 3.7 variable rate charger and two Eflite 1s 200mah 25c lipo's $21 | nitrodude71 | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Jan 06, 2012 07:59 PM |
| Sold Eflite celectra 1s 3.7 variable rate charger and two Eflite 1s 200mah 25c lipo's $20 | nitrodude71 | Aircraft - Electric - Helis (FS/W) | 6 | Jan 06, 2012 08:32 AM |
| Discussion Whats the um 1s battery that has the highest c rating? | skarface | Batteries and Chargers | 6 | Sep 22, 2011 06:35 AM |
| Sold Highest Offer Gets it. 1S DC Lipo Charger | SYMAWD | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Sep 10, 2011 07:17 PM |
