Old Feb 13, 2012, 06:36 PM
rallyon is offline
Find More Posts by rallyon
rallyon's Avatar
Joined Dec 2011
Rallyon's Flamewheel build and set up for FPV
Hi all, I hope its OK to start a thread about my own personal setup and experience, I didn't know if I should post this in the FPV, Aerial vid, Multi, naza... threads, so i just started this one.
Basic F450 kit:
DJI Flame Wheel first flight (7 min 28 sec)
Flying the Flamewheel FPV (5 min 45 sec)
Week #2 flying FPV (4 min 37 sec)
Roll stabilization (0 min 26 sec)
Gotta say, I LOVE this new dimension to RC hobby! It' so fun to be able to explore new places with this thing. I'm excited to try new things and for it to get WARMER!
Thanks for all the info on this forum! Lots of knowledge here, and most of it is given out graciously I hope in my turn I am able to contribute something useful back into the community.
Ryan
rallyon is offline Find More Posts by rallyon
Old Feb 13, 2012, 07:27 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Outstanding build Ryan, keep the videos coming.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Feb 13, 2012, 07:34 PM
SeniorSpan is offline
Find More Posts by SeniorSpan
SeniorSpan's Avatar
Colorado
Joined Nov 2004
Excellent Ryan, thanks. I have the F450 kit; just about ready to bind/calibrate and program the electrics. Yours is the first video I've seen with the Spektrum radio which is what I'm using.
Did you use the gear switch as your "two position switch" to change between attitude and manual?
Additionally, the leg extensions are great.
Thanks for your time.
SeniorSpan is offline Find More Posts by SeniorSpan
Old Feb 13, 2012, 07:42 PM
Tarro is offline
Joined Jun 2008
I am loving the Flame wheel frame, I have a WKM mounted on mine all FPV tricked out with a Range Video OSD. I feel like I am doing a special OP's mission when I fly it with all the telemetry info and AHI.
Old Feb 13, 2012, 07:53 PM
rallyon is offline
rallyon's Avatar
Joined Dec 2011
Senior, I did use the GEAR channel for the ATTI/MAN switch, I have been mostly leaving it in ATTI as I creep around getting familiar with FPV flying. I like the stability, I have rallied around on MAN and its pretty fun, but I have been really eager to do the FPV for now.
Old Feb 13, 2012, 07:57 PM
rallyon is offline
rallyon's Avatar
Joined Dec 2011
Tarro - Yes, position hold would be sweet! But I fear dji has no motivation to make GPS for NAZA since they already have WKM. There is likely a Hex in my future though, so I may try some higher-end systems.
Old Feb 13, 2012, 08:54 PM
SeniorSpan's Avatar
Colorado
Joined Nov 2004
Thx Ryan. I'm looking forward to getting it into the air. Had a binding problem with the radio but it it turned out to me not the radio. Just need to do the electrics and adjustments, then clean up the wire bundles and put the top plate on.
I appreciate your time.
Cheers
Bob
Old Feb 13, 2012, 11:50 PM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
Awesome setup. I want one exactly like yours
What video tx are you using and what kind of antenna is that ?
Also, I see you have your receiver running off the main battery, do you also have the FPV camera and TX running off the main battery?
I have range video equipment that's a few years old and lost the 900mhz 500mw TX when my plane crashed.
Tried to get another one from Vova but he won't return my emails so I need to find another TX and maybe not 900mhz this time.
Bought a HPQ-1 and waiting for it in the mail.
But already wanting to build a F450 with NAZA for FPV
jasper7821 is offline Find More Posts by jasper7821
Old Feb 15, 2012, 10:48 AM
rallyon is offline
rallyon's Avatar
Joined Dec 2011
Thanks for the comments guys, I'm loving this!
Some still frames from this mornings flight, would have flown longer but my transmitter battery was getting low! I'll get some video uploaded sometime soon.
jasper - Video is lawmate 300mw 1.3 with Blue Beam Antenna set. Check out ReadyMadeRC. I had a patch, but I like this Omni-directional way better because I like to fly all around me, look up IBcrazy's antenna designs on RCG, good stuff.
enjoy!
Ryan
Old Feb 15, 2012, 02:46 PM
Nerm is offline
Find More Posts by Nerm
Quads Helis Planes Cars
Nerm's Avatar
Canada, ON, Brampton
Joined Aug 2009
Excellent video. One of the best.
I've got the same frame. How did you do your lg extensions?
Nerm is offline Find More Posts by Nerm
Old Feb 15, 2012, 03:01 PM
Joined Mar 2008
I too want those same leg extension. They look great.
Old Feb 15, 2012, 03:20 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
My, what a big deck you have...
Nice video and build
MCrites is offline Find More Posts by MCrites
Old Feb 15, 2012, 04:18 PM
rallyon is offline
rallyon's Avatar
Joined Dec 2011
Leg extensions are just 3/16 carbon flat stock TIGHTLY ziptied to the inside and outside of each "landing pad". I use the small zipties because they are more elastic and I feel i can get them tighter. I pre-drilled and put one screw to hold them from sliding down, working great so far, the bottoms are held together with a little rubber nipple used to seal off automotive vacuum ports. I was going to glue them in place but the have stayed put nicely!
Very happy with them, visually they flow with the stock frame and I think simple is best!
MCrites - Yes deck is bigger then my "house" !
Old Feb 17, 2012, 08:03 PM
rallyon is offline
rallyon's Avatar
Joined Dec 2011
I balanced my motor bells and used some of these avionics mounts that we had around the hangar to whip up a prototype mount today. plan to use carbon or abs sheet soon soon, just wanted to try these dampers out. I was having random jello with my GoPro and wanted it gone for good.
Initial tests look real good, but I think the harmonics from the wind were part of the jello problem so when its stop raining I will test.
Old Feb 18, 2012, 08:59 AM
Add1ct3dd is offline
Find More Posts by Add1ct3dd
Add1ct3dd's Avatar
United Kingdom, England, Worcester
Joined May 2010
Looks good, can you provide a full spec list? I'm looking for a basic quadcopter FPV setup so I can get flying, and this looks perfect
Matt
Add1ct3dd is offline Find More Posts by Add1ct3dd
Discussion Help with how to set up the DX6I for s-cub and champ etc. video fishycomics Radios 0 Jan 13, 2012 03:49 PM
Sold Fpv total set up for large e-heli trade (600+) Maydog FPV Equipment (FS/W) 2 Oct 13, 2011 03:37 PM
Help! Radio Set Up - what's the best set up for a number of 1/5th & 1/8th scale bikes? PUMA937 Motorcycles 4 Mar 03, 2011 11:34 AM
Discussion Wobby's FPV truck set up merlin703 FPV Talk 11 Sep 29, 2010 11:01 PM
Discussion want to build - for a fpv set up. X3n0 Foamies (Scratchbuilt) 7 Dec 07, 2009 01:33 PM
