This thread is privately moderated by Rat Brother 1, who may elect to delete unwanted replies.
Old Feb 13, 2012, 05:53 PM
Rat Brother 1 is offline
Find More Posts by Rat Brother 1
Rat Brother 1's Avatar
United States, AZ, Phoenix
Joined Jun 2011
Build Log
SebArt Pilatus PC-21
Getting all the parts together for this beautiful airframe.
Motor: Hacker A50-14S V2 Outrunner 425kV
ESC: Hacker X-70-SB-PRO
Battery: Thunder Power 5S-4400mAh 25C
Prop: APC 16x12E
Servos: Hitec HS-5496MH HV Digital (all around)
Retracts: E-flite 25-46 tricycle, SebArt stock struts
Pilots: (2) Pete's Pilots 1/9 scale jet bust
Rat Brother 1 is offline Find More Posts by Rat Brother 1
Old Feb 14, 2012, 03:28 PM
Joined Jun 2011
Ailerons installed. Manual says to use medium CA but I used thin as I feel it makes for a stronger bond and does not clump up at hinge center where I want easy flexing. Horns installed with medium CA per instructions. Servos centered and rubber grommets installed with brass sleeves flat side down. After screwing down I unscrewed them and added thin CA to the wood to give added strength.
Old Feb 14, 2012, 03:58 PM
Joined Jun 2011
Step 014
The hardware kit comes with 8 small washers. The assembly manual doesn't indicate where they go but I'm using them against the control horn as shown. Once tightened down I'll drop a dab of medium CA onto the nut to keep it in place.
Old Feb 16, 2012, 02:14 PM
Joined Jun 2011
Installing E-flite 25 - 46 Electric Retracts - mains completed
These should offer trouble-free landings. Well worth the added effort!
Old Feb 19, 2012, 09:03 PM
Joined Jun 2011
Nosegear Install - retract comparison
The nosegear retract supplied with the kit mounts from the bottom whereas the E-flite retract mounts from the top. In addition the E-flite is considerable larger. I have spent the better part of the day cutting and trimming the existing mount to fit the E-flite retract. I'll post photos of the the modifications to the pocket and new mounting rails in a day or two.
Old Feb 20, 2012, 06:55 PM
Joined Jun 2011
Retract weight data.
Old Feb 21, 2012, 10:05 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Looks great! Just finished mine, White and blue version. Should be flying it any day now.
Bob
bruff is offline Find More Posts by bruff
Old Feb 22, 2012, 04:23 PM
Joined Jun 2011
Thanks Bob. It was a toss up between the blue and white or the red and white as both color schemes look fantastic on this airframe. My final choice was more of 'keep it in the family' as my fleet is predominately red and white.
Good luck with your maiden flight!
Robert
Old Feb 25, 2012, 02:49 PM
Joined Jun 2011
Nosegear Install - continued
After much trial and error I feel that I'm nearing completion on this phase of the build
Before testing your servo to steering arm connection I strongly suggest that you set up a mix for the nosegear servo. This will cut power to the servo when the landing gear is up. Set up as follows.
I'm using a Spektrum DX7s transmitter.
Mix 1
RUD > AX2
Rate: 100%
100%
Offset: 0%
Trim: Inh
Sw: Gear0
Old Feb 27, 2012, 03:30 PM
Joined Jun 2011
Vertical Stabilizer and Rudder
Straightforward per the assembly manual.
Old Feb 27, 2012, 03:57 PM
Joined Jun 2011
Reinforce the bridge between the two elevator parts
I saw this done on another build thread and... 'an ounce of prevention is worth a pound of cure'.
Old Mar 01, 2012, 12:50 PM
Joined Jun 2011
Elevator install
Installing the stock hinges did not go well. One of the hinges nearest to the fuselage got hung up and just would not go in completely leaving me with a uneven gap. CA can be very unforgiving. I let it dry overnight and cut and trimmed the hinges flush with the surface and made new slots for Du-Bro small nylon pin hinges No. 118. Test fit them to make sure they would seat properly; had to trim back part of the hinge to get it into the stabilizer section before mixing up some 30 min. epoxy. Tip: before using epoxy on pin hinges bush a little Vaseline on the pin hinge portion and melt it with a heat gun to prevent the epoxy from getting into the hinge area and binding up the hinge.
New Product New ECOMRC Pilatus PC-21 from TBM scatsob Scale ARF/RTF 474 May 15, 2016 03:28 AM
Video Pilatus PC-21 1/5 Scale - Club Bitaches tatoespinosa Fuel Plane Talk 1 Jan 20, 2012 07:28 PM
Cool VIDEO: 1/5 Scale Pilatus PC-21 - Club Bitaches tatoespinosa Fuel Warbirds 0 Dec 23, 2011 11:40 AM
Data Free Pilatus plans: PC-12, PC-21, etc joe_crash Foamies (Scratchbuilt) 2 Nov 08, 2011 04:34 PM
