Old Feb 14, 2012, 12:03 AM
munce31 is offline
Find More Posts by munce31
RA-TA-MA-HAT-TA
munce31's Avatar
Melbourne, Australia.
Joined Feb 2010
Stick to Polyurethane, such as the previously mentioned Sika PU glue, as it expands into the foam core and forms a very tight bond. Not much is needed either - just a thin layer.
munce31 is offline Find More Posts by munce31
Old Feb 14, 2012, 12:21 AM
oziflyer is offline
Find More Posts by oziflyer
Sydney Australia
Joined Sep 2004
Are you going with the wing as shown on the plan?
Don't know if you have the original magazine article(I've got it around here somewhere), but I seem to remember that the author mentions that increasing the wing area by 10% over that shown on the plan would be a good idea.
oziflyer is offline Find More Posts by oziflyer
Old Feb 14, 2012, 12:43 AM
Jindivik is offline
Find More Posts by Jindivik
Jindivik's Avatar
Australia, VIC, Croydon
Joined Nov 2006
Yeah, have already had cores cut, but may be able to increase the span a little but not much more than that unfortunately. I have the magazine in a box somewhere, might find it one day. May just build as per the plans and later on get a new set of cores cut with a slightly larger area.
Jindivik is offline Find More Posts by Jindivik
Old Feb 14, 2012, 12:55 AM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Nothing a bit or balsa and a few ribs in the centre section cant fix
EG: build a centre section and make the panels plug in
steve wenban is online now Find More Posts by steve wenban
Old Feb 14, 2012, 04:38 AM
Jindivik is offline
Jindivik's Avatar
Joined Nov 2006
Yeah, I might have a look at it tomorrow. Good thing is I know how much another set of cores will cost and I know I have the balsa to skin them.
Got to say Steve, have been enjoying watching your Boomer' come along. My late Grandfather was a flight test engineer on the Boomerang, CA-15 and Woomera before moving over to GAF after the war. I'll give you a guess at what he designed there. Always enjoy seeing models of the local hardware being built.
Old Feb 14, 2012, 04:42 AM
Joined Dec 2003
yeah I saw the tooling personally covered in dust and hidden away in a corner at Fishermans bend ,worked for the same company
Old Feb 15, 2012, 06:25 AM
Jindivik is offline
Jindivik's Avatar
Joined Nov 2006
Hi Guys,
Just a quick update tonight.
Started shaping the engine pods, one side almost done, one side still to start.
Still thinking about the wings, whether to extend the span or not.
Decisions, decisions.
Old Feb 15, 2012, 06:28 PM
Frenche is offline
Find More Posts by Frenche
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
Looking good, you're making me want to pull out my 50mm one and finish it haha
Frenche is offline Find More Posts by Frenche
Old Feb 17, 2012, 05:23 PM
shanesmadhouse is offline
Find More Posts by shanesmadhouse
Buildings what I enjoy.
Australia, QLD, Witheren
Joined Nov 2007
I have the same planes from Phil and it looks great. I ended up building a hybrid from those and another set of plans as mine is a pusher F-111. One day I will build a EDF with the two 68mm ones I recently purchased.
Your fuse looks terrific so can't wait to see the final product.
Shane
shanesmadhouse is offline Find More Posts by shanesmadhouse
Old Feb 17, 2012, 06:24 PM
Jindivik is offline
Jindivik's Avatar
Joined Nov 2006
Shane
Thanks Shane,
Humidity has been a problem here this week and to top it off on Thursday we had some heavy rain which came into the garage. Fortunately nothing for the model got wet, but I have had to move some stuff around which is making it harder to work on the plane at the moment.
I would love to build a powered model of the Pig, swing wings and all, but after shaping this fuselage so far I don't know if I could put myself through that again. Might wait to see if the rumors of a EDF foamy come true.
Chris
Old Feb 17, 2012, 08:35 PM
salisbug is offline
Find More Posts by salisbug
I failed linkage geometry
salisbug's Avatar
Joined Jun 2002
Hi Jindivik,
Your Pig is looking excellent.
As Steve said I built one from Phil's plans at 150% of the original size.
Stupidly sold it and have been trying to get her back.
I extended the wings to the profile of an F111C. I would suggest doing the same but also increasing the chord a little. Every bit of area helps.
Glenn
salisbug is offline Find More Posts by salisbug
Old Feb 17, 2012, 08:39 PM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
F111C:
F111, the rest:
Note how the C model wing tips reach the horizontal stabilser tips when fully swept.
Old Feb 17, 2012, 10:17 PM
Joined Nov 2007
Glenn,
That is one excellent PIG. I too would be tryin g to get her back.
Detail on her is fantastic.
Well done.
Shane
Old Feb 17, 2012, 10:30 PM
Jindivik is offline
Jindivik's Avatar
Joined Nov 2006
Originally Posted by salisbug View Post
Hi Jindivik,
Glenn
Hi Glenn,
Was going to send you a PM and then you appear here
I found a couple of photos of your Pig on here and it was those photos that reminded me of the plans.
I am thinking I might extend the span a bit to more resemble a C as I am planning on painting it as A8-132 in the ARDU colours. I dont know if there is much I can do with the chord with the cores though, but as I said earlier, I can always get another set cut in the future and have a couple of wing sets.
I was going to ask you Glenn, how did you tackle the tailplanes? Did you stick to the plans or did you use a different method? I was going to use carbon fibre tube to join them and some brass tube through the balsa sides and foam engine nacelles as a bearing.
I would really appreciate any tips you could give me for this plane Glenn. Have been really enjoying getting back into building, looking forward to being able to take it for a TFR run along a slope.
Would you consider building another one, or do you want the old one back for sentimental reasons?
Chris
Old Feb 18, 2012, 12:53 AM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
Actually the G's had the extended wings as well. But they did at various times experiment with using shorter wings on the C's due to the fuselage stress issues prominent in there later years. They were very strictly G limited and any over G (around +4 from memory) required extensive inspections before any further flights. It was shown that the use of shorter wings transferred less stress through to the fuselage wing carry through box, and instead just stressed the wings of which plenty of the shorter varients could be sourced easily. So it wasn't unheard of to see a C getting around with shorter wings fitted.
luke352 is offline Find More Posts by luke352
Discussion Whistle Pig Illini_Rob Flying Wings 6 Sep 20, 2011 09:18 PM
Contest Build off II; F-111 "Pig" 93" Glong-flyer Scale Kit/Scratch Built 16 Dec 18, 2007 09:49 PM
Discussion How light can you build an E Flite P47..or..Pig on a diet barmonkey Electric Warbirds 52 Sep 09, 2006 10:42 PM
